Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper » Fri Mar 27, 2026 7:18 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v76_Hard_Target_58E1
MKB20_v77_Blazing_Saddles_9A55
MKB20_v82_Dogma_UHD_9393
MKB20_v82_Geschichten_aus_der_Schattenwelt_96CF
*MKB20_v82_The_Return_of_the_Pink_Panther_9CF8
avaka_71 wrote: Thu Mar 26, 2026 11:32 pm Dumps for
Starship troopers traitor of the mars
hard target
blazing saddles
Hey avaka_71, you'll need to provide the full MKB_RO.inf file from the discs AACS folder in order for Starship Troopers: Traitor of Mars to be added to the public keydb. The MKB_RO.inf file in your disc dump was not the full file, so please don't extract it from the TGZ file and upload it. The full MKB_RO.inf should be at least several megabytes in size. If anything is unclear, please read the opening post of this thread.
(Your other two titles utilise media keys which are already known to the public keydb, so nothing else is required for Hard Target or Blazing Saddles)
Grahamdoh
Post by Grahamdoh » Fri Mar 27, 2026 10:39 am
Spellbinder and City on fire Imprint releases.
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
kasko
Post by kasko » Fri Mar 27, 2026 3:34 pm
MrPenguin
Post by MrPenguin » Fri Mar 27, 2026 3:51 pm
kasko wrote: Fri Mar 27, 2026 3:34 pm MKB20_v82_ProjektA_UHD_20B1
MKB20_v82_ProjektB_UHD_A479
Can you also upload the MKB_RO.inf files from these actual UHD disks please? The copies of these files inside the TGZ dump files have been truncated to only 56 bytes, which makes them unusable to anyone except MakeMKV itself.
avaka_71
Post by avaka_71 » Fri Mar 27, 2026 5:32 pm
Thank you for the indication keydb_helper.
Please find the correct files using the following links
For starship troopers
https://uploadnow.io/f/RHWvzVr
For hard target
https://uploadnow.io/f/2l5JZ9z
For blazing saddles
https://uploadnow.io/f/gxLJGXQ
kasko
Post by kasko » Fri Mar 27, 2026 8:39 pm
LaunderedShirt
Post by LaunderedShirt » Fri Mar 27, 2026 10:11 pm
Disc type: UHD
Disc ID: 49a757a86b9eb9c536295ab9019c35e87e7350aa
Disc dump filename: MKB20_v77_ALIENS_62BB
Drive: BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://www.dropbox.com/scl/fi/pjzmptn7 ... 3cmhl&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/sqkuv52u ... 2p2f6&dl=0
MKVDUDE
Post by MKVDUDE » Fri Mar 27, 2026 10:13 pm
Another 2 please -
Disc type: UHD
Disc dump filenames:
MKB20_v82_Blood_From_The_Mummy's_Tomb_D208.tgz
MKB20_v82_Demons_Of_The_Mind_894A.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-Oir2ymGjOZzA4yoo
Many thanks!
bonga2000
Post by bonga2000 » Sat Mar 28, 2026 10:45 am
Here is my dump, hope you can help to decrypt
https://drive.google.com/file/d/10P3iDM ... p=drivesdk
PConnors
Post by PConnors » Sat Mar 28, 2026 12:51 pm
Salem's Lot (mini-series) - Arrow Video
(Someone else posted for this disc but it seems the disc dump wasn't uploaded correctly)
Disc type: UHD
Disc ID: 868595B4DE91F3D9E2665B5BAE9D296145728B9E
Disc dump filename: MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2.tgz
Drive: BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/HAP4W6HWS8#o1HiEJ6XSvXA
Disc dump link: https://drive.proton.me/urls/6CC16CAM9G#ZaL1zDYLzXCt
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 1:00 pm
PConnors wrote: Sat Mar 28, 2026 12:51 pm Salem's Lot (mini-series) - Arrow Video
This disk already has a complete entry in the latest KEYDB.cfg file.
Falafil
Post by Falafil » Sat Mar 28, 2026 3:13 pm
Disc type: UHD
Disc ID: 0x962C61FCB2F169A2A408C06DC68128D60DC2DA79
Disc dump filename: MKB20_v82_Per_Qualche_Dollaro_in_Più_-_UHD_B524
MKB_RO.inf link: https://filebin.net/xn64biowphl07ncy
Disc dump link: https://filebin.net/8owfpd8cr5m6ugqd
HCR666
Post by HCR666 » Sat Mar 28, 2026 4:27 pm
I'm struggling with this one:
Arcane season 2
I'm very very new to this so if there's anything else you need please let me know (and maybe tell me what I need to do after this is 'added'? :) ) will I need to send this for each individual disk in the 9 episode box set? (they are all named the same so I'm not sure if that means you just need the one file)
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 4:46 pm
HCR666 wrote: Sat Mar 28, 2026 4:27 pm I'm very very new to this so if there's anything else you need please let me know (and maybe tell me what I need to do after this is 'added'? :)
Can you adjust the "Sharing" option for that file please, so that people can download it?
HCR666
Post by HCR666 » Sat Mar 28, 2026 4:53 pm
my bad I'll do that now!
