Public KeyDB Disc Submissions
That means the keydb.cfg file isn’t being used. HK downloads have nothing at all to do with keydb.
keydb_helper
I'm glad to hear you were able to rip your discs. But if the keydb.cfg file were correctly installed you wouldn't actually need the latest HK files to rip those discs. The keydb.cfg file and the native MakeMKV HKs perform equivalent functions, so I'd recommend trying to sort that out when you get a chance.anon.eh.mous.user wrote: Thu Mar 26, 2026 12:18 pm I figured out the problem. My ISP blocks downloading the HKs, so even though I had the latest keydb.cfg, out of date HKs was causing the problem. I had to use a VPN to successfully download the latest HKs and then the disc rips. I will follow that process in the future. Thanks again!
anon.eh.mous.user
Will do.keydb_helper wrote: Thu Mar 26, 2026 12:35 pmI'm glad to hear you were able to rip your discs. But if the keydb.cfg file were correctly installed you wouldn't actually need the latest HK files to rip those discs. The keydb.cfg file and the native MakeMKV HKs perform equivalent functions, so I'd recommend trying to sort that out when you get a chance.anon.eh.mous.user wrote: Thu Mar 26, 2026 12:18 pm I figured out the problem. My ISP blocks downloading the HKs, so even though I had the latest keydb.cfg, out of date HKs was causing the problem. I had to use a VPN to successfully download the latest HKs and then the disc rips. I will follow that process in the future. Thanks again!
anon.eh.mous.user
❯ curl -o keydb.zip -L0 "http://fvonline-db.bplaced.net/fv_download.php?lang=eng"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 0
100 21.10M 100 21.10M 0 0 33312 0 11:04 11:04 38728
❯ unzip ./keydb.zip
Archive: ./keydb.zip
inflating: keydb.cfg
❯ mv ./keydb.cfg ~/.MakeMKV
❯ cat ~/.MakeMKV/keydb.cfg | grep "0xD0B73588A895ED9A8CE4FEF68A0A2ABA9AA95754"
0xD0B73588A895ED9A8CE4FEF68A0A2ABA9AA95754 = STRANGENEWWORLDS_SEASON3 (Star Trek: Strange New Worlds - Season 3 (Disc 1)) | D | 2026-03-05 | M | 0x3BF37B428418F8F90633CD3D184F9BF8 | I | 0x0BE6636E316B52B02F5ADD21BE67E67D | V | 0x163ECB52D73734626867B203B972EA81 | U | 1-0x8CFBB695D0A2D17B04733F4CDED92F49 ; MKBv82/BEE/FindVUK 1.82 - VolumeSize: 95952961536 (UHD)
keydb_helper
Could you please post the output of running:
ls -l ~/.MakeMKV/
Hey barnstarmer, that is a fair question. My intention with this thread is to ensure the public keydb has as many 'complete' records as possible. A complete record contains all four of the media key, volume ID, volume unique key, and unit key(s).barnstarmer wrote: Wed Mar 25, 2026 7:27 pm @keydb_helper
Is it okay to submit discs that already are in the database, but only have the UK and no VUK?
So if the public keydb has a unit key-only record, or a volume ID + unit key record, or any other combination of records other than my definition of 'complete' I'm happy for the dump file and MKB_RO.inf file to be posted to this thread.
Regardless of a discs keydb status, I still recommend users take the time to email their disc dump files to MakeMKV team. The forum team have been nice enough to allow this thread and I don't want the public keydb to compromise the continued growth of MakeMKV's native title support.
Disc Type: UHD
Disc ID: 0xECD702E3C3C14AC2DD6B20D57B5C3AE4F6EAAEA8
Disc Dump Filename: MKB20_v82_Geschichten_aus_der_Schattenwelt_96CF,tgz
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1pRt_CI ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1Z_MEzi ... sp=sharing
Unit Keys (1):
[1] 0x582FAF23C545B1C82D4135183C08E54C
KeyDB Status:
Status : not found
Drive: BW-1601HT
Unit Keys (1):
KeyDB Status:
Status : not found
anon.eh.mous.user
keydb_helper wrote: Thu Mar 26, 2026 1:54 pmCould you please post the output of running:If you changed your MakeMKV data directory so that disc dump files aren't being written to that folder you'll need to move the keydb.cfg file accordingly.Code: Select all
ls -l ~/.MakeMKV/
❯ ls -lah ~/.MakeMKV
total 75M
drwxrwxr-x 1 myusername myusername 182 Mar 26 09:48 .
drwxr-x--- 1 myusername myusername 1.7K Mar 26 09:48 ..
-rw------- 1 myusername myusername 60M Mar 26 2026 keydb.cfg
-rw-rw-r-- 1 myusername myusername 2.0M Jan 7 11:20 makemkv_sdf.bin
-rw-rw-rw- 1 myusername myusername 15K Jan 24 13:42 MKB_v8_save.tgz
-rw-rw-rw- 1 myusername myusername 13M Mar 25 16:16 _private_data.tar
-rw-rw-rw- 1 myusername myusername 594 Mar 25 16:16 screen.conf
-rw-rw-rw- 1 myusername myusername 636 Mar 25 16:12 settings.conf
-rw-rw-rw- 1 myusername myusername 194 Mar 25 16:13 update.conf
Pretty sure I should be fine going forward. Probably just a user error the first time I downloaded the keydb.cfg and couldn't rip those 3 discs. I'll be sure to confirm the disc isn't present in the db and the HKs are updated before I submit again in the future. I'm going to write a shell script to download the latest, unpack, grep to confirm the disc isn't present, and run makemkvcon to confirm it can't decrypt. I'll share the source for anyone else who wants to use it / modify it for their use.
Thanks again!
You're using Linux, so the file literally needs to be named "KEYDB.cfg", and not "keydb.cfg".anon.eh.mous.user wrote: Thu Mar 26, 2026 2:59 pmCode: Select all
❯ ls -lah ~/.MakeMKV total 75M drwxrwxr-x 1 myusername myusername 182 Mar 26 09:48 . drwxr-x--- 1 myusername myusername 1.7K Mar 26 09:48 .. -rw------- 1 myusername myusername 60M Mar 26 2026 keydb.cfg -rw-rw-r-- 1 myusername myusername 2.0M Jan 7 11:20 makemkv_sdf.bin -rw-rw-rw- 1 myusername myusername 15K Jan 24 13:42 MKB_v8_save.tgz -rw-rw-rw- 1 myusername myusername 13M Mar 25 16:16 _private_data.tar -rw-rw-rw- 1 myusername myusername 594 Mar 25 16:16 screen.conf -rw-rw-rw- 1 myusername myusername 636 Mar 25 16:12 settings.conf -rw-rw-rw- 1 myusername myusername 194 Mar 25 16:13 update.conf
anon.eh.mous.user
Ah, THAT's why it didn't pick it up. The first time I updated the db, I copied the file twice into that directory, one lowercase, one uppercase - and it worked to rip the UK version of The Astronaut. I didn't do that when I tried these 3 discs. Good to know. I'll make sure the script I write accounts for that. Thanks!MrPenguin wrote: Thu Mar 26, 2026 3:05 pmYou're using Linux, so the file literally needs to be named "KEYDB.cfg", and not "keydb.cfg".anon.eh.mous.user wrote: Thu Mar 26, 2026 2:59 pmCode: Select all
That's not correct. I'm running Linux and it works fine even if I use "keydb.cfg" and not "KEYDB.cfg", at least when put in the MakeMKV folder.MrPenguin wrote: Thu Mar 26, 2026 3:05 pmYou're using Linux, so the file literally needs to be named "KEYDB.cfg", and not "keydb.cfg".anon.eh.mous.user wrote: Thu Mar 26, 2026 2:59 pmCode: Select all
Well, it apparently wasn't working, and there wasn't any other possibility... Which file-system are you using for your .MakeMVK folder? Are you using ext4 with "casefold" enabled?Toad King wrote: Thu Mar 26, 2026 10:41 pm That's not correct. I'm running Linux and it works fine even if I use "keydb.cfg" and not "KEYDB.cfg", at least when put in the MakeMKV folder.
Return of the Pink Panther UHD
Disc type: UHD
Disc ID: 0x 38e155f366f5816db500147c211f2a602e69fa17
Disc dump filename: MKB20_v82_The_Return_of_the_Pink_Panther_9CF8.tgz
Drive: BD-RE-BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/17QKrsz ... share_link
Disc dump link: https://drive.google.com/file/d/1lNW7mI ... share_link
Drive: BD-RE-BU40N
Dumps for
Starship troopers traitor of the mars
hard target
blazing saddles
https://uploadnow.io/f/ckSfMCz
hard target
blazing saddles
btrfs, no case folding.MrPenguin wrote: Thu Mar 26, 2026 10:53 pmWell, it apparently wasn't working, and there wasn't any other possibility... Which file-system are you using for your .MakeMVK folder? Are you using ext4 with "casefold" enabled?Toad King wrote: Thu Mar 26, 2026 10:41 pm That's not correct. I'm running Linux and it works fine even if I use "keydb.cfg" and not "KEYDB.cfg", at least when put in the MakeMKV folder.
hamsterdance
Disc type: UHD
Disc ID: 0xf4d69fb80370e3fc4cc4103f8c3a5ed366891294
Disc dump filename: MKB20_v82_Dogma_UHD_9393.tgz
Drive: LG BP50NB40
Drive firmware: 1.02 (2120-05-07 09:35)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://filebin.net/6ucjcvs3p8tvep31/MKB_RO.inf
Disc dump link: https://filebin.net/6ucjcvs3p8tvep31/MK ... D_9393.tgz
Drive: LG BP50NB40
