Public KeyDB Disc Submissions
cjw73
Fackham Hall
Disc type: UHD
Disc dump filename: MKB20_v82_Fackham_Hall_DD6A.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Disc dump link: https://drive.proton.me/urls/MCJ9WDD4YG#Gg46GqfP4u4F
thanks again
Disc type: UHD
thanks again
keydb_helper
Thanks for the new disc dump cjw73, your disc has been added to the public keydb.cjw73 wrote: Fri Mar 20, 2026 7:58 am Fackham Hall
Disc type: UHD
The 102A variant of Arco has also been added.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
kasko
keydb_helper
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Frankenhooker_UHD_553A
MKB20_v77_LEAGUE_OF_THEIR_OWN_A_6ACD
*MKB20_v82_A_Bridge_Too_Far_84F8
MKB20_v82_Dead_Kids_UHD_D757
*MKB20_v82_GILDA_UHD_5178
*MKB20_v82_Uncommon_Valor_5702
Thanks kasko, your disc has been added to the public keydb. Please follow the template in the future by including the full MKB_RO.inf file. You were lucky this time that your discs media key was already known to the keydb.
jtpowell
Disc type: UHD
Disc ID: 0x5eb8dca4cbe2f6ceaf1029bd54872fb1f7a231df
Disc dump filename: MKB20_v82_Marty_Supreme_2600
Drive: BDR-XD08U
Drive firmware: 1.04/ID05
MKB_RO.inf link: https://drive.google.com/file/d/17iKDyz ... share_link
Disc dump link: https://drive.google.com/file/d/132Shj_ ... share_link
Drive: BDR-XD08U
Grahamdoh
Two New Blu-Ray Releases from Eureka.
The Devils Hand
Cruel Tale of Bushido
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
The Devils Hand
Lyusya
Disc Dump: UPXX_1172 (AACS v82)
MKB_RO.inf is 1MB, extracted from BDMV/AACS folder.
MakeMKV reports "volume label unknown - cannot decrypt".
Download link: https://pan.baidu.com/s/1VJHwoYmUkYLwbRuAQ0ShRw 提取码: 69t3
rjrteb
Mimic - Theatrical Cut
Disc type: UHD
Disc ID: 0x72f3d51a6f8ee0ebc8584c29a05967d1aeef5347
Disc dump filename: MKB20_v82_Mimic_-_Theatrical_Cut_72BA
Drive: PIONEER BD-RW BDR S12U
Drive firmware: 1.03/ID43
MKB_RO.inf link: https://drive.google.com/file/d/1DWNDAE ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1tZk7x- ... sp=sharing
Disc type: UHD
MrPenguin
Thanks, but the KEYDB.cfg file seems to have already contained this disk for at least the past week.
userhou4
Hello, my UHD disc is currently undecryptable. Could you please help me with it? Thank you.
Disc type: UHD
Disc ID: 8605956F-25B2-4F62-93B4-EA8C1E3B2AB1
Disc dump filename: MKB20_v77_The_Sound_of_Music_BCE8
Drive: BU40N
Drive firmware:1.03MK
MKB_RO.inf link: https://drive.google.com/file/d/1o9qVLB ... drive_link
Disc dump link: https://drive.google.com/file/d/1V8vTQs ... drive_link
Disc type: UHD
Drive: BU40N
rjrteb
The Theatrical Cut disc is still showing as unknown for me, the Directors Cut disc is detected though.
edit: I just double checked again & it's definitely showing as "The volume key is unknown for this disc - video can't be decrypted. Failed to open disc".
unibart
Hello.
Disc-Typ: UHD
Disc-ID: 26BAF7E449078EE81AD7E751BA2CA39A6BEEDBEF
Dateiname des Disc-Dumps: MKB20_v77_NEVERMORE_0B2C.tgz
Antrieb: MT1959
Laufwerksfirmware: 1.04
LibreDrive-Status: Aktiviert
Haben Sie die öffentliche KeyDB innerhalb der letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, dass alle Einreichungslinks im Inkognito-/Privat-Browsing zugänglich sind? Ja
MKB_RO.inf-Link: [url]https://[/url]
Link zum Disc-Dump: [url]https://[/url]
Disc-Typ: UHD
Antrieb: MT1959
bdsucker
Disc type: UHD
Disc ID: 02B155AAEE0FC4DA23DECA603C45ECD8BD274C23
Disc dump filename: MKB20_v77_MACROSS_PLUS_THE_MOVIE_4K_UHD_A6DC
Drive: BW-16D1HT
Drive firmware: 3.00
Disc dump link: https://www.mediafire.com/file/a78fpzc6 ... C.tgz/file
Drive: BW-16D1HT
MrPenguin
This dump is actually MKB20_v68_BDROM_247D.tgz, not "The Sound of Music". Also, can you provide the MKB_RO.inf file from the actual UHD disk please? The one you have currently provided is only 56 bytes long, which means it must be the truncated one from inside the TGZ dump file itself. Not only is this one unusable, but we already have it anyway precisely because it's inside the TGZ dump file.userhou4 wrote: Tue Mar 24, 2026 1:33 am Hello, my UHD disc is currently undecryptable. Could you please help me with it? Thank you.
userhou4
Sorry, I probably made a mistake when filling it out. I'll try again tomorrow and send it to you.
