Dump submitted - The Key (La Chiave) (Cult Epics)
ianfrancorchamps
MKB20_v82_THE_KEY_445D.tgz
Re: Dump submitted - The Key (La Chiave) (Cult Epics)
Can you also upload this TGZ dump flle into (say) OneDrive or Google Drive please, and then reply here with a public download link? (Along with the MKB_RO.inf file from the physical UHD disk, since the copy of this file inside the TGZ dump file has almost certainly been truncated to only 56 bytes, making it unusable.) This would allow people to try adding your disk to the public KEYDB.cfg file too.
ianfrancorchamps
Sure they're here: https://drive.google.com/file/d/14mzsYF ... sp=sharing, https://drive.google.com/file/d/1Eb52x2 ... sp=sharingMrPenguin wrote: Mon Mar 23, 2026 12:26 pmCan you also upload this TGZ dump flle into (say) OneDrive or Google Drive please, and then reply here with a public download link? (Along with the MKB_RO.inf file from the physical UHD disk, since the copy of this file inside the TGZ dump file has almost certainly been truncated to only 56 bytes, making it unusable.) This would allow people to try adding your disk to the public KEYDB.cfg file too.
