Dump Submitted: Mad Max 2 - The Road Warrior 4K/UHD (E921 Variant)
datatracer
Post by datatracer » Fri Mar 20, 2026 10:31 pm
Submitted/emailed: MKB20_v76_Mad_Max_2-_The_Road_Warrior_E921.tgz
... as well as: MKB_RO.inf
since the file size for the .tgz was only 108 kb
MrPenguin
Re: Dump Submitted: Mad Max 2 - The Road Warrior 4K/UHD (E921 Variant)
Post by MrPenguin » Fri Mar 20, 2026 11:48 pm
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?
If this doesn't work, could you upload both your TGZ dump file and its actual MKB_RO.inf file into (say) OneDrive of Google Drive please, and then reply here with public download links?
datatracer
Post by datatracer » Sat Mar 21, 2026 4:26 pm
I downloaded KEYDB.cfg yesterday and tried it before I submitted this post. Today's updated KEYDB.cfg also didn't work. Here's a link to the files: https://limewire.com/d/fZW38#Bq1m5Yt4O5
MrPenguin
Post by MrPenguin » Sat Mar 21, 2026 4:38 pm
Thanks, and since you are using Windows, have you tried using SamuriHL's utility? This works as a useful front-end for managing your copy of KEYDB.
datatracer
Post by datatracer » Sun Mar 22, 2026 6:56 pm
Thanks. I'll check it out!
Not sure if the updated KEYDB or makemkv's native key download was the method that worked, but it's working now! :D
