Submitted/emailed: MKB20_v76_Mad_Max_2-_The_Road_Warrior_E921.tgz
... as well as: MKB_RO.inf
since the file size for the .tgz was only 108 kb
Dump Submitted: Mad Max 2 - The Road Warrior 4K/UHD (E921 Variant)
datatracer
MrPenguin
Re: Dump Submitted: Mad Max 2 - The Road Warrior 4K/UHD (E921 Variant)
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?datatracer wrote: Fri Mar 20, 2026 10:31 pm Submitted/emailed: MKB20_v76_Mad_Max_2-_The_Road_Warrior_E921.tgz
If this doesn't work, could you upload both your TGZ dump file and its actual MKB_RO.inf file into (say) OneDrive of Google Drive please, and then reply here with public download links?
datatracer
I downloaded KEYDB.cfg yesterday and tried it before I submitted this post. Today's updated KEYDB.cfg also didn't work. Here's a link to the files: https://limewire.com/d/fZW38#Bq1m5Yt4O5MrPenguin wrote: Fri Mar 20, 2026 11:48 pm
MrPenguin
Thanks, and since you are using Windows, have you tried using SamuriHL's utility? This works as a useful front-end for managing your copy of KEYDB.datatracer wrote: Sat Mar 21, 2026 4:26 pm I downloaded KEYDB.cfg yesterday and tried it before I submitted this post. Today's updated KEYDB.cfg also didn't work.
datatracer
Thanks. I'll check it out!MrPenguin wrote: Sat Mar 21, 2026 4:38 pm Thanks, and since you are using Windows, have you tried using SamuriHL's utility? This works as a useful front-end for managing your copy of KEYDB.
Not sure if the updated KEYDB or makemkv's native key download was the method that worked, but it's working now!
