Greenland 2: Migration dump submitted
powrhaus
Just got the 4k disc today and it fails to open. Attached is the dump file.
- MKB20_v82_Greenland_2-_Migration_1BBA.tgz
- (3.26 MiB) Downloaded 805 times
Re: Greenland 2: Migration dump submitted
Did you also email the dump to svq@makemkv.com so a hashed key can be made for it?
powrhaus
I didn't know that was part of the process. I'll do that now.
noworries1968
Anyone gotten this disk to open???
MrPenguin
noworries1968
Thanks, I will give it a try.
But isn't it supposed to download updates like this automatically?
I've bene using for years and it usually just downloads some file on the Mac named "_private", or some approximation thereof.
MrPenguin
There are two key databases, and the "hashed keys" inside _private_data.tar are indeed managed automatically. However, KEYDB.cfg is an alternative key database that MakeMKV can use, should the file be available in MakeMKV's data directory. The KEYDB.cfg file can often be updated more rapidly that the "hashed keys", and so it's worth having both databases available.noworries1968 wrote: Fri Mar 27, 2026 4:53 pm But isn't it supposed to download updates like this automatically?
powrhaus
I tried to rip the disc again yesterday and it worked great. I noticed during the loading process it downloaded a new database and that one had the key. If you haven't tried in a couple of days, try again and it should work. If it still doesn't, your disc may be different and you'll need to provide a dump file for it.
