Public KeyDB Disc Submissions
Post by MartyMcNuts » Mon Mar 16, 2026 12:54 am
I have updated the KeyDB with a record for the Aussie 4k UHD of "The Running Man" (2025).
Dump file: MKB20_v82_THE_RUNNING_MAN_F24D
Disc ID: A16CB937802B5F88ED437498AF08B2332446B467
keydb_helper
Post by keydb_helper » Mon Mar 16, 2026 1:08 am
Bohuntin wrote: Mon Mar 16, 2026 12:06 am From the 6-movie Middle Earth box set, the 3 Hobbit disks are in the current keydb, but the LoTR ones are not.
Here are the details for the first disk (part 1 of fellowship, extended, UHD); will prep and upload the other 5 once I make sure this submission is correct.
Disc type: UHD
Disc ID: 0xCA34B47F1EB98119E5637B5C3A5F213648FBE0B7
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_EXT_PT_1_77C9.tgz
Hey Bohuntin, your submission is sufficient. Feel free to upload the remaining disc dumps when you get the chance and all six will be processed at once.
joh_0303 wrote: Sun Mar 15, 2026 7:38 pm Hello,
I don't directly have a dump file because makeMKV get's stuck at a specific point.
So i used xreveal to create a metadata .jar file. I hope this works as well.
Hey joh_0303, Xreveal JAR dump files are not usable at this point. You can try the 'manual' process of creating a disc dump by starting a protected (so Xreveal must be disabled) full-disc backup with MakeMKV and copying out the discatt.dat file as soon as it is created. Once you have the discatt.dat file, combine it with the discs 'AACS' directory and post of a link to the resulting archive file.
cuyler
Post by cuyler » Mon Mar 16, 2026 4:01 am
Disc type: UHD
Disc ID: 0x461A8AAE22C09D659778D59494B7DC3A607EC2C7
Disc dump filename: MKB20_v77_FRIENDS_S1_D1_F68B.tgz
Drive: HL-DT-ST BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1-xtOSY ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1-5LkG- ... sp=sharing
Lightyear
Post by Lightyear » Mon Mar 16, 2026 10:52 am
Disc type: UHD
Disc dump filename: MKB20_v82_A_Working_Man_E599
Drive: WH16NS60
Drive firmware: 1.02
Disc dump link: https://drive.google.com/file/d/16LDsyN ... drive_link
MrPenguin
Post by MrPenguin » Mon Mar 16, 2026 2:48 pm
cuyler wrote: Mon Mar 16, 2026 4:01 am Disc type: UHD
You presumably mean MKB20_v77_FRIENDS_S1_D2_7623.tgz here. However, your dump file isn't usable because LibreDrive failed to initialize for some unknown reason:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/DD7B409E'
DEBUG: Code 0 at y9yb`|da)(\XIm9jU:213130306
DEBUG: Code 0 at @}C}Kv6i=|1VVrx@<F:121264395
DEBUG: Code 4 at @}C}Kv6i=|1VVrx@<F:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Happily for you, the latest KEYDB.cfg file already contains a complete entry for this disk.
Bohuntin
Post by Bohuntin » Mon Mar 16, 2026 4:22 pm
From the 6-movie Middle Earth box set, the 3 Hobbit disks are in the current keydb, but the LoTR ones are not...
correction: The Return of the King extended part1 disk was already in keydb.
Fellowship extended 4K part 2:
Disc type: UHD
Disc ID: 0x1FAF685161B8D4F610A7383118430F3878B2C699
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_EXT_PT_2_D5C1 .tgz
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1zNtbM8QI4Bwk8knSrSgGal-ON47J4I9q/view?usp=sharing
Disc dump link: https://drive.google.com/file/d/1sIGV1SNZQaBGHr-v5Gd7ZVPUCTB5WqLn/view?usp=sharing
Two Towers extended 4K part 1:
Disc type: UHD
Disc ID: 0x290972736F6D6634C339309A4D8B4A8F2B24DAA8
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_EXT_PT_1_159D.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1DF8q7Ro-YBfWCdmh6A4zbrh3fBCom4mD/view?usp=sharing
Disc dump link: https://drive.google.com/file/d/19_y2B_stA-hLIRKPkkGzQHBw3kJEpm2z/view?usp=sharing
Two Towers extended 4k part 2:
Disc type: UHD
Disc ID: 0x8571906C7D2E8402AB0A815C874CF5BDE25CB471
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_EXT_PT_2_98CB.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1UlHMmP3RajftcuCUAa3dcO3aPswYPj7C/view?usp=sharing
Disc dump link: https://drive.google.com/file/d/1vvtQ3fYFlV6dlAoaOcAALM3Js6ZYjhE8/view?usp=sharing
chucky527c
Post by chucky527c » Mon Mar 16, 2026 4:43 pm
The Substitute 4K UHD (Lionsgate Limited) (US)
Disc type: UHD
Disc ID: FE3D5E006147D76BD22255E53533C1ABFD52CEA2
Disc dump filename: MKB20_v82_The_Substitute_3A06.tgz
Drive: LG WH16NS60
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1_Jyyc7 ... sp=sharing
chucky527c
Post by chucky527c » Mon Mar 16, 2026 5:13 pm
Leprechaun 4K UHD (Lionsgate Limited) (US)
Disc type: UHD
Disc ID: 121C29EE17FAA0B123AB8A118B38A86B6FD42926
Disc dump filename: MKB20_v82_Leprechaun_4634.tgz
Drive: LG WH16NS60
Disc dump link: https://drive.google.com/file/d/13i8B5S ... sp=sharing
joh_0303
Post by joh_0303 » Mon Mar 16, 2026 8:11 pm
keydb_helper wrote: Mon Mar 16, 2026 1:08 am
Disc type: UHD
Hello again,
here is the new link: https://drive.google.com/drive/folders/ ... sp=sharing
I hope i did everything correctly.
If not please let me know. :)
Toby82
Post by Toby82 » Mon Mar 16, 2026 9:59 pm
Disc type: UHD
Label: AQUAMAN_AND_THE_LOST_KINGDOM
Disc dump filename: MKB20_v77_Aquaman_and_the_Lost_Kingdom_EBCB
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link: https://drive.google.com/file/d/1GauGNj ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1zjzESs ... sp=sharing
keydb_helper
Post by keydb_helper » Tue Mar 17, 2026 2:24 am
joh_0303 wrote: Mon Mar 16, 2026 8:11 pm Hello again,
here is the new link: ...
Hey joh_0303, thanks for following my instructions. Your manually created disc dump was sufficient and your disc has been added to the public keydb.
Lightyear wrote: Mon Mar 16, 2026 10:52 am Disc type: UHD
Thanks for the submission Lightyear. Your disc has also been added but please remember to include the full MKB_RO.inf file from your disc next time. You were lucky that the media key of your disc was already known to the keydb.
Thanks to everyone else who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v76_AVATAR_A41C
*MKB20_v77_ALL_QUIET_ON_THE_WESTERN_FRONT
MKB20_v77_American_Graffiti_671D
*MKB20_v77_Aquaman_and_the_Lost_Kingdom_EBCB
MKB20_v77_M3GAN
MKB20_v82_Groove_B7BF
*MKB20_v82_Leprechaun_4634
*MKB20_v82_MARTY_SUPREME_6E5C
*MKB20_v82_Outbrteak_UHD_F28E
*MKB20_v82_RED_SONJA
*MKB20_v82_Spellbinder_UHD
*MKB20_v82_The_Substitute_3A06
I believe all other valid submissions have been processed and added to the public keydb.
Ammonia9663
Post by Ammonia9663 » Tue Mar 17, 2026 3:00 am
Disc type: UHD
Disc ID: 324ace09b08d2b54345e5d47b8c3cce855a76eaa
Disc dump filename: MKB20_v82_Dogma_41F1
Drive: BH16NS40
MKB_RO.inf link: https://drive.google.com/file/d/1Es96s_ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KVg6mr ... sp=sharing
cuyler
Post by cuyler » Tue Mar 17, 2026 5:03 am
MrPenguin wrote: Mon Mar 16, 2026 2:48 pm
Wonderful, thank you! I wonder why LibreDrive failed to initialize. I will download the latest keydb.cfg and try again.
andymar5280
Post by andymar5280 » Tue Mar 17, 2026 2:17 pm
Here is a submission for SALEM'S LOT 4K UHD by Arrow Video
https://drive.google.com/drive/folders/ ... share_link
libreuser123456
Post by libreuser123456 » Tue Mar 17, 2026 7:21 pm
I hope you are all well :)
Disc type: UHD
Disc ID: 47f11ece4e974a6cad54c99770941cc6c634babd
Disc dump filename: MKB20_v61_Harry_Potter_Order_of_Phoenix_690F
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1eXTHIw ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1PvR5jY ... sp=sharing
Disc type: UHD
Disc ID: 17cb62e83c1e13b4a653a2ae332d9c520ab862e0
Disc dump filename: MKB20_v70_LÉON_D14D
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1_9Rs50 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1TclWDB ... sp=sharing
Disc type: UHD
Disc ID: 8c136962f20cdf58ef626c71ebf4884c1dd070cf
Disc dump filename: MKB20_v61_BLADE_RUNNER_THE_FINAL_CUT_FDB5
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1i6WUxn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/11k54Ha ... sp=sharing
Disc type: UHD
Disc ID: 075dc4d6f3c10947c923316ad14e13d10234f748
Disc dump filename: MKB20_v61_READY_PLAYER_ONE_4C0F
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1oXB6lD ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1INNvfD ... sp=sharing
Disc type: UHD
Disc ID: d3e3a3758759816ebee81a65985d21768f2fb0f9
Disc dump filename: MKB20_v76_Die_unendliche_Geschichte_UHD_14A5
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1OG2EBr ... sp=sharing
Disc dump link: https://drive.google.com/file/d/11PPaQY ... sp=sharing
Disc type: UHD
Disc dump filename: MKB20_v61_Harry_Potter_DeathlyHallowsP1_C11D
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1kLxzq2 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1bxRnqA ... sp=sharing
Disc type: UHD
Disc ID: 937291869ed38ba0d53434d4a94fe24b6ced6afa
Disc dump filename: MKB20_v61_FANTASTIC_BEASTS_ABDB
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1GSHFYq ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1dTSJfl ... sp=sharing
Disc type: UHD
Disc ID: eb866ec30ee0dcb1323dfa2b19d4d8b2e00c6c61
Disc dump filename: MKB20_v61_HARRY_POTTER_CHAMBER_SECRETS_56BD
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1dTXIYV ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1sJ5mbW ... sp=sharing
Disc type: UHD
Disc ID: ba069b9fadb02dd5e83419f459f27718ccb93c55
Disc dump filename: MKB20_v61_UHD_MOCKINGJAY_2_5B99
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/17YiYUr ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1KzFsH9 ... sp=sharing
Disc type: UHD
Disc dump filename: MKB20_v76_Indiana_Jones_and_the_Temple_of_Doom_0AC1
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1GGNzJy ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kl0aY_ ... sp=sharing
Disc type: UHD
Disc ID: 08c333fc7487775938bab1a046c3634fcac25d77
Disc dump filename: MKB20_v61_UHD_MOCKINGJAY_1_F4DF
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1qHehrh ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1jct7kQ ... sp=sharing
Disc type: UHD
Disc ID: 2e198e7eb5d793da324449ef7068f5dd4b13cd1e
Disc dump filename: MKB20_v61_UHD_CATCHING_FIRE_C1CB
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/12pgrlq ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1vUZczr ... sp=sharing
Disc type: UHD
Disc ID: 9bae479db47b00fea30d1a3c200b23cc4d5f7d02
Disc dump filename: MKB20_v61_UHD_HUNGER_GAMES_89CF
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1t3LCeV ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1y_h9k3 ... sp=sharing
Thank you!
