Blu-Ray Drive Stuck On Loading Disk
pilot kaboom
Post by pilot kaboom »
Hello forum,
I have recently obtained an older Pioneer Blue-ray reader. Whenever I have tried to load a disk, it gets stuck at perpetually 'Disk is being loaded...'. I have tried just waiting literal hours, it is connected to known good SATA, and I have had this install of MakeMKV read and rip DVDs fine from another drive I have installed. I have tried loading many both BRs and DVDs in the new drive and it never gets past loading. I am aware that this drive is not capable of UHD disks and I have not been trying to read them. Here is the data from the MKV screen, but I can pull the drive out and get that more specific drive information if needed.
The other quirk of my setup is that it is running on TrueNAS Scale. Again, I have had this working for another drive and it seems to be perfectly capable for many other users, it is just this new drive that is giving me problems. I will also admit that I have not ensured the mechanical function of the drive with something like VCL as the drive is installed in my server and none of my other computers have a quick and easy way to troubleshoot a 5.25 inch drive. I will wrench on it if there is not something obvious I have fouled with the software. Thank you.
Re: Blu-Ray Drive Stuck On Loading Disk
pilot kaboom wrote: Sun Mar 15, 2026 4:36 am Hello forum,
Let the OS see and initialise the disc before opening the MakeMKV application and see if that helps.
You might have to connect the drive directly to a PC for further testing,
pilot kaboom
Update: The drive works fine and MakeMKV is able to recognize and read my disks fine from Windows (In the exact same computer), but I am running a truenas app for my actual implementation and that is causing it to fail in this manner. Maybe I need a different forum for that.
16442496
Post by 16442496 »
MakeMKV above v1.17.7 still broken on Linux
viewtopic.php?f=3&t=37670
MakeMKV just won't work.
viewtopic.php?f=3&t=36408
and many more. ;)
Debian
MakeMKV 1.17.6 (Registered)
MrPenguin
Post by MrPenguin »
16442496 wrote: Mon Mar 23, 2026 6:41 am MakeMKV above v1.17.7 still broken on Linux
I cannot explain what you're seeing, because I am running MakeMKV 1.18.3 on Fedora Linux without issue.
16442496
Post by 16442496 »
I run MakeMKV 1.18.3 on Debian 13, but first i need download Firmware dump with 1.17.7. Without that firmware it is "Endless spin" with both my non-libre Pioneer BD-ROM drives. BD's & DVD's.
Debian
