Public KeyDB Disc Submissions
jenrashe
Van WILDERS (Bluray 4K)
Disc type: Bluray 4K
Disc dump filename:MKB20_v82_FACTORIS_1104_3701623403540_AMERICANPARTYVANWILDERRELATIONSPUBLIQUES_UHDCMF_BD66_C9F2
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1zXASO- ... sp=sharing
Disc dump link: https://drive.google.com/file/d/12pH3rB ... sp=sharing
Drive: LG BU40N
jenrashe
The Bodyguard From Beijing (Bluray 4K)
Disc dump filename: MKB20_v82_FACTORIS_1038_THEBODYGUARDFROMBEIJING_3F30
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1n-rdTA ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Lyxqa1 ... sp=sharing
Drive: LG BU40N
sackoffun
One Flew Over the Cuckoo's Nest
Disc type: BluRay 4K
Disc ID: b8acdb4721f6023dee3aea3eda9d0ba9
Disc dump filename: MKB20_v82_One_Flew_Over_the_Cuckoo's_Nest_47F8.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1rvwL23 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1XBZhra ... sp=sharing
MrPenguin
Doesn't the latest KEYDB.cfg file already contain this disk?sackoffun wrote: Thu Mar 12, 2026 10:11 pm One Flew Over the Cuckoo's Nest
jenrashe
Sisu : de l'or et du sang (Bluray 4K)
Disc dump filename: MKB20_v82_SISU_DE_L_OR_ET_DU_SANG_4D85
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1KLFOFn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1sh3kvi ... sp=sharing
Drive: LG BU40N
Zetph
Disc type: UHD
Disc ID: 0x3107C2E7A9E653308559C7ED8E261D9702F4C5F4
Disc dump filename: MKB20_v82_Wicked-_For_Good_18C4
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/drive/folders/ ... drive_link
Disc dump link: https://drive.google.com/drive/folders/ ... drive_link (in the same drive folder)
Drive: BW-16D1HT
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
I believe all other valid submissions have been processed and added to the public keydb.
*MKB20_v77_BDROM (悪魔のいけにえ 4Kデジタルリマスター 公開50周年記念版 -4K Ultra HD Blu-ray-)
*MKB20_v82_Brotherbood_of_Justice_BF0C
*MKB20_v82_Bulk_UHD
MKB20_v82_Crying_Freeman_5B3F
*MKB20_v82_DOA-UNCUT-OpenMatte-UHD_EB6E
*MKB20_v82_FACTORIS_1038_THEBODYGUARDFROMBEIJING_3F30
*MKB20_v82_FACTORIS_1082_YOURENEXT_66_256A
*MKB20_v82_FACTORIS_1104_3701623403540_AMERICANPARTYVANWILDERRELATIONSPUBLIQUES_UHDCMF_BD66_C9F2
*MKB20_v82_ShelbyOaks_C028
*MKB20_v82_THE_BREAKFAST_CLUB_3EF6
*mkb20_v82_thegreatalligator_2824
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
sammyd1108
I have the latest downloaded and it’s still saying unknown volume key and it looks like someone else is also having the same issue.MrPenguin wrote: Fri Mar 13, 2026 11:13 amDoesn't the latest KEYDB.cfg file already contain this disk?sackoffun wrote: Thu Mar 12, 2026 10:11 pm One Flew Over the Cuckoo's Nest
keydb_helper
The 47F8 variant of One Flew Over the Cuckoo's Nest was added to the public keydb over 24 hours ago. Both your submission and the submission by sackoffun have the disc ID 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992 and this is indeed present in the keydb.sammyd1108 wrote: Fri Mar 13, 2026 2:39 pm I have the latest downloaded and it’s still saying unknown volume key and it looks like someone else is also having the same issue.
Open up your keydb.cfg file and search for 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992. You should see a line like this:
0xA5B59F43F15C6DA231BAF0D83190EBC291B55992 = One Flew Over the Cuckoo's Nest | D | 0000-00-00 | M | 0x59<Redacted> | I | 0xB8<Redacted> | V | 0x9E<Redacted> | U | 1-0xE1<Redacted> ; MKBv82/BEE (UHD)
In case you've changed the MakeMKV data directory from the default, just remember that your extracted keydb.cfg file needs to be placed in the same folder where MakeMKV created your MKB20_v82_One_Flew_Over_the_Cuckoo's_Nest_47F8.tgz dump file.
(I'm not sure why the disc ID provided by sackoffun is incorrect for his disc dump file)
sammyd1108
I’ll try it again when I get home I guess. I know I tried it right before posting my data dump and it still wasn’t opening.keydb_helper wrote: Fri Mar 13, 2026 3:18 pmThe 47F8 variant of One Flew Over the Cuckoo's Nest was added to the public keydb over 24 hours ago. Both your submission and the submission by sackoffun have the disc ID 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992 and this is indeed present in the keydb.sammyd1108 wrote: Fri Mar 13, 2026 2:39 pm I have the latest downloaded and it’s still saying unknown volume key and it looks like someone else is also having the same issue.
Open up your keydb.cfg file and search for 0xA5B59F43F15C6DA231BAF0D83190EBC291B55992. You should see a line like this:If you can't find it, you'll need to carefully follow my instructions hereCode: Select all
JackBurton
The Narrow Margin
Disc type: Blu-ray
Disc dump filename: MKB_v82_THE_NARROW_MARGIN_8516.tgz
Drive: BW-16D1HT
Drive firmware: 3.10MK
MKB_RO.inf link: https://drive.google.com/file/d/10p2Znk ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1HmypxN ... sp=sharing
Stranger on the Third Floor
Disc type: Blu-ray
Disc dump filename: MKB_v82_STRANGER_ON_THE_THIRD_FLOOR_D84C.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1jfW5lV ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1dRhk8W ... sp=sharing
Disc type: Blu-ray
Drive: BW-16D1HT
Disc type: Blu-ray
Drive: BW-16D1HT
keydb_helper
I don’t want to sound rude but it wasn’t working for you earlier because you hadn’t followed the steps required to use the latest public keydb. Your disc has been in the keydb for almost 36 hours and the keydb entry is unambiguously correct.sammyd1108 wrote: Fri Mar 13, 2026 4:09 pm I’ll try it again when I get home I guess. I know I tried it right before posting my data dump and it still wasn’t opening.
Your issue will be at least one of:
1. You downloaded an ancient copy of the keydb from the wrong site instead of the one I linked in my instructions
2. You didn’t extract the keydb.cfg file from the downloaded zip file
3. You put the extracted keydb.cfg file in the wrong folder
4. (Linux/macOS only) You didn’t rename the keydb.cfg file to the case-sensitive KEYDB.cfg file required by certain filesystem configurations
There aren’t too many other ways to fuck up downloading, extracting and copying a file.
freshspaghettios
Disc type: UHD
Disc ID: 5187044E8B57FBAA1CB86BA66AD8E6E3A81D9470
Disc dump filename: MKB20_v82_We're_All_Gonna_Die_7B43
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1ZQdAGP ... drive_link
Disc dump link: https://drive.google.com/file/d/1EE573A ... drive_link
I sent the dump to svq@makemkv.com as well. Let me know if I'm missing anything, hopefully the hash is right.
keydb_helper
Thanks Jack, both of your discs have been added to the public keydb.JackBurton wrote: Fri Mar 13, 2026 4:20 pm The Narrow Margin
Disc type: Blu-ray
Disc type: Blu-ray
These two UHD discs were also just added:
MKB20_v82_Anaconda_(2025)_E6F4
MKB20_v82_K2_20A0
InstExtension
Heavy Metal 4k UHD
Disc type: UHD
Disc ID: 6a6db3629a38e2ae3cb8de52e0805353f2220771
Disc dump filename: MKB20_v76_Heavy_Metal_2989
MKB_RO.inf link: https://1drv.ms/u/c/850c3a15b7956143/IQ ... 8?e=DWgRdO
Disc dump link: https://1drv.ms/u/c/850c3a15b7956143/IQ ... g?e=AFPmd2
Yes, this Disc ID already exists in the current KeyDB, but it is not working for some reason. I tried with with two different UHD drives:
PIONEER BDR-S13JX
LG WH16NS60
The current KeyDB did work for some other titles I had problems with so I know its installed and working correctly.
Disc type: UHD
PIONEER BDR-S13JX
LG WH16NS60
