Trouble Opening Discs
Serpico23
#1 Post by Serpico23 » Sat Mar 07, 2026 7:33 pm
For some reason my drive and Makemkv won't open the following 4K discs.
Sleepaway camp 2 (shout)
Creepshow (shout)
Tenebrae (synapse)
The Fog (shout)
When I load the disc, VLC usually automatically opens up first, but with these titles nothing happens and my drive just keeps spinning. They play on my 4K player with no issue.
Any suggestions would be appreciated. Thanks in advance!
Re: Trouble Opening Discs
#2 Post by MartyMcNuts » Sat Mar 07, 2026 11:01 pm
Serpico23 wrote: Sat Mar 07, 2026 7:33 pm For some reason my drive and Makemkv won't open the following 4K discs.
Creepshow (shout)
Tenebrae (synapse)
The Fog (shout)
Paste the text from your MakeMKV drive info & libredrive info sections.
Serpico23
#3 Post by Serpico23 » Sun Mar 08, 2026 12:05 am
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOBN1UA1646
Highest AACS version: 82
Firmware version: 1.03
MrPenguin
#4 Post by MrPenguin » Sun Mar 08, 2026 12:15 am
Serpico23
#5 Post by Serpico23 » Sun Mar 08, 2026 3:25 pm
MrPenguin wrote: Sun Mar 08, 2026 12:15 am
I apologize for my ignorance, I'm not super tech savy. Are there instructions to try this?
The other odd thing is, I tried another copy of The Fog and that one worked without issue. Could be something with disc authoring?
MrPenguin
#6 Post by MrPenguin » Sun Mar 08, 2026 4:23 pm
Serpico23 wrote: Sun Mar 08, 2026 3:25 pm I apologize for my ignorance, I'm not super tech savy. Are there instructions to try this?
You mean this?
MrPenguin wrote: Sun Mar 08, 2026 12:15 am Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
The latest KEYDB.cfg file is inside the ZIP file that you get from that download link.
Serpico23
#7 Post by Serpico23 » Sun Mar 08, 2026 6:35 pm
MrPenguin wrote: Sun Mar 08, 2026 4:23 pm
You mean this?
Do I just copy and paste the file into the Makemkv folder through program files?
MrPenguin
#8 Post by MrPenguin » Sun Mar 08, 2026 6:47 pm
Serpico23 wrote: Sun Mar 08, 2026 6:35 pm Do I just copy and paste the file into the Makemkv folder through program files?
Probably more like "drag and drop" the KEYDB.cfg file into your MakeMKV folder.
If MakeMKV has created any TGZ files for any of these disks then maybe upload these files into (say) OneDrive or Google Drive, and then reply here with public download links?
Serpico23
#9 Post by Serpico23 » Sun Mar 08, 2026 10:51 pm
MrPenguin wrote: Sun Mar 08, 2026 6:47 pm
I'll give it a try. Thanks for your help.
