Trouble Opening Discs
Serpico23
For some reason my drive and Makemkv won't open the following 4K discs.
Sleepaway camp 2 (shout)
Creepshow (shout)
Tenebrae (synapse)
The Fog (shout)
When I load the disc, VLC usually automatically opens up first, but with these titles nothing happens and my drive just keeps spinning. They play on my 4K player with no issue.
Any suggestions would be appreciated. Thanks in advance!
Creepshow (shout)
Tenebrae (synapse)
The Fog (shout)
Re: Trouble Opening Discs
Paste the text from your MakeMKV drive info & libredrive info sections.Serpico23 wrote: Sat Mar 07, 2026 7:33 pm For some reason my drive and Makemkv won't open the following 4K discs.
Creepshow (shout)
Tenebrae (synapse)
The Fog (shout)
Serpico23
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOBN1UA1646
Highest AACS version: 82
Firmware version: 1.03
Revision: 1.03
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Serpico23 wrote: Sat Mar 07, 2026 7:33 pm For some reason my drive and Makemkv won't open the following 4K discs.
Serpico23
I apologize for my ignorance, I'm not super tech savy. Are there instructions to try this?MrPenguin wrote: Sun Mar 08, 2026 12:15 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Serpico23 wrote: Sat Mar 07, 2026 7:33 pm For some reason my drive and Makemkv won't open the following 4K discs.
The other odd thing is, I tried another copy of The Fog and that one worked without issue. Could be something with disc authoring?
MrPenguin
You mean this?Serpico23 wrote: Sun Mar 08, 2026 3:25 pm I apologize for my ignorance, I'm not super tech savy. Are there instructions to try this?
The latest KEYDB.cfg file is inside the ZIP file that you get from that download link.
Serpico23
Do I just copy and paste the file into the Makemkv folder through program files?
MrPenguin
Probably more like "drag and drop" the KEYDB.cfg file into your MakeMKV folder.Serpico23 wrote: Sun Mar 08, 2026 6:35 pm Do I just copy and paste the file into the Makemkv folder through program files?
If MakeMKV has created any TGZ files for any of these disks then maybe upload these files into (say) OneDrive or Google Drive, and then reply here with public download links?
Serpico23
I'll give it a try. Thanks for your help.MrPenguin wrote: Sun Mar 08, 2026 6:47 pmProbably more like "drag and drop" the KEYDB.cfg file into your MakeMKV folder.Serpico23 wrote: Sun Mar 08, 2026 6:35 pm Do I just copy and paste the file into the Makemkv folder through program files?
