Public KeyDB Disc Submissions
Disc type: UHD
Disc ID: 5440D9CCE73669A738BE3EFEEDF71B6DF0069D64
Disc dump filename: MKB20_v82_Swordsman_2FF6
Drive: BDR-S13JX
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/file/d/1klqcRK ... jyNz4/view
Drive: BDR-S13JX
Disc Type: UHD
Disc ID:
Disc Dump Filename: MKB20_v82_UHD_Shell_C1A7
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://1drv.ms/f/c/29aa5f2d1ffacbe9/Ig ... g?e=Wa8QAZ
Disc ID:
Drive: BW-1601HT
Thanks for the TGZ dump file, but can you also provide a download link for the actual MKB_RO.inf file from the physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV itself.
My latest unsupported UHD disc:
Disc Type: UHD
Disc dump filename: MKB20_v82_KAAMELOTT_2_partie_1_062B.tgz
Drive: ASUS BW-16D1HT
Firmware version: 3.10
Disc dump link: https://limewire.com/d/cjH1H#mSNqnOFDSY
MKB_RO.inf link: https://limewire.com/d/XxoUy#5LNFuOi2Xj
Disc Type: UHD
jackycyk0924
Here is the disc information (3 recently released blu-ray discs) and thanks for your help:
Disc type: UHD
Disc dump filename: MKB_v82_THE_TOUR_OF_MISIA_2025_8986 & MKB_v82_BD_ROM_17E4 & MKB_v82_BD_ROM_1956
Drive: BDR-S13JX
Disc dump link:
Disc no.1: https://drive.google.com/file/d/14Z4uKU ... drive_link
Disc no.2: https://drive.google.com/file/d/1SIwOC2 ... drive_link
Disc no.3: https://drive.google.com/file/d/1Ovi2XU ... drive_link
Disc type: UHD
Drive: BDR-S13JX
Disc dump link:
FrankGrimes2769
The Death of Superman (2018)
The_Death_of_Superman_27D9
Disc type: UHD
Disc ID: d6e18e589acd873308c22078e1e3859700f12c4b
Disc dump filename: MKB20_v61_The_Death_of_Superman_27D9.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/12cXVEI ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1h6B6cD ... sp=sharing
Unit_Key_RO.inf link: https://drive.google.com/file/d/1gJDVMF ... sp=sharing
Thank you! I appreciate the support!
It works now. Thank you for the assist!
Disc type: UHD
Drive: BD-RE BU40N
Last edited by FrankGrimes2769 on Sun Mar 01, 2026 1:36 am, edited 1 time in total.
Now inf file uploaded to the same folder, see link. Thank You.MrPenguin wrote: Fri Feb 27, 2026 2:55 pmThanks for the TGZ dump file, but can you also provide a download link for the actual MKB_RO.inf file from the physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV itself.
Thanks, and can you also adjust the permissions on this file please, so that people can download it?Chisum04 wrote: Fri Feb 27, 2026 7:05 pm Now inf file uploaded to the same folder, see link. Thank You.
Pink Floyd - Live at Pompeii UHD
Disc type: BD-ROM UHD
Disc ID: UHD_PNKF
Disc dump filename: MKB20_v82_Pink_Floyd_at_Pompeii_CB0F.zip
Drive: BD-RE WH16NS60 1.02
Drive firmware: 2118-10-29 19:36
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://ufile.io/hvtf4q1s
Disc dump link: https://ufile.io/hvtf4q1s (AACS/MKB_RO.inf was replaced with a version copied directly from the disc)
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: ...
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: UHD_PNKF
Timestamp: 2025-07-19 18:19:56
Protection: AACS2.0/C v82
Data capacity: 92.82 Gb
Number of layers: 3
Bus encryption flags: 80
Disc ID: UHD_PNKF
Revision: 1.02
Serial number: ...
Disc Information
Label: UHD_PNKF
Number of layers: 3
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_RED_13F0
*MKB20_v61_The_Death_of_Superman_27D9
*MKB20_v82_Ahora_me_ves_3_5932
*MKB20_v82_CLASSE_TOUS_RISQUES_5C8E
*MKB20_v82_DOGTOOTH_AE9A
*MKB20_v82_DRAGON_LORD_3C5C
*MKB20_v82_DRAGON_LORD_ACE2
*MKB20_v82_LA_TARENTULE_AU_VENTRE_NOIR_-_4K_UHD_3356
*MKB20_v82_L_EMMERDEUR_EB92
*MKB20_v82_LiberiArmatiPericolosi_77BC
*MKB20_v82_SegniParticolariBellissimo_A866
*MKB20_v82_Swordsman_2FF6
*MKB20_v82_TheDevilsAdvocate_UHD_D8A0
*MKB20_v82_TheSmashingMachine_D540
mkb20_v82_uhd_unfs_f3f5
*MKB20_v82_WICKED_FOR_GOOD_DE78
Another 4 please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_SOLDIER_38C0.tgz
MKB20_v82_THE_KILLER_-_UHD_4CE2.tgz
MKB_v82_THE_KILLER_-_DISC_2_132E.tgz
MKB_v82_THE_KILLER_EXTENDED_CUT_89F4.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-LTvmxvhjEA
Many thanks!
Disc type: UHD
Drive: BD-RE BU40N
Many thanks!
The Man Who Wasn't There UHD - Criterion UK
Disc type: UHD
Disc ID: 8d96839b57890a8b58367337364474a8cf78b35b
Disc dump filename: MKB20_v82_THE_MAN_WHO_WASN'T_THERE_B54D.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/16pzBf4 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1EBdylf ... sp=sharing
Disc type: UHD
Drive: BW-16D1HT
benutzer13
The Running Man (2025) UHD - ger, rental
Disc type: UHD
Disc ID: f9015e9e775dda031940530bbb7b68597d9bb51a
Disc dump filename: MKB20_v82_THE_RUNNING_MAN_5D0F.tgz
Drive: BW-16D1HT
Drive firmware: 3.10MK
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1vJouyL ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1OZgbtq ... sp=sharing
Disc type: UHD
Drive: BW-16D1HT
Submission for Pink Floyd at Pompeii 4K
Disc type: UHD
Disc ID: 6CBCD6EFA0EBF8D276CE25CCCCFCED6AD8BA0C6E
Disc dump filename: MKB20_v82_UHD_PNKF_CB0F.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1vahOJR ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Y9kBau ... sp=sharing
Disc type: UHD
Disc type: UHD
Disc ID: ebf734575c01aa5ee53c5e4a31651ad083357429
Disc dump filename: MKB20_v72_JOKER_FBFD.tgz
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/5aq30rix ... D.tgz/file
Thank you!
Thank you!
