Disc type: UHD Blu-ray
Disc ID: 0xFE47498B9FB93BCF9DA5AA5FFA3B5CCEF7AF4A05
Disc dump filename: MKB_RO.inf
Drive : BH16NS55
Drive firmware: 1.02
LibreDrive status: OK
Did you sync the public keydb within the last 15 minutes? Yes]
MKB_RO.inf link: https://reva.blob.core.windows.net/post ... MKB_RO.inf
Disc dump link: https://reva.blob.core.windows.net/post ... 2_save.tgz
MakeMKV really struggled with this one. It never stopped reading the disc.
KEY DB HELPER:
Disc ID : 0xFE47498B9FB93BCF9DA5AA5FFA3B5CCEF7AF4A05
Volume : Battle of Britain UHD
Title : Battle of Britain - 4K UHD
Disc Type : UHD Blu-ray
Encryption Keys:
VID : 0xCD5D4C22DC89463C65A6854CB468162F
MKB Version : 82
Encrypted Keys (1):
[1] 0xEC4B7899D8424168A77552904C5DCFF7
Public KeyDB Disc Submissions
MrPenguin
Unfortunately, that's not the correct TGZ dump file for this diskHomerJay wrote: Sun Feb 22, 2026 6:55 pm Disc dump link: MKB20_v82_save.tgz
- MKB20_v82_Battle_of_Britain_-_4K_UHD_????.tgz
Grahamdoh
lukeyrada
Makemkv is not able to rip/copy House Party 4K (Criterion). It isn't recognising the Disc properly when it is reading the data to be ripped. There is no such problem with Minority Report 4K. That read and ripped with zero issues. Both are newly released in the UK where I live. I am using a 2021 Macbook Pro (M1) WITH the latest version of Makemkv & MacOS with a Pioneer Drive for the discs.
Any tips or suggestions for a fix would be welcome.
MrPenguin
Have you considered reading the first post in this thread?
HomerJay
I just loaded the disc again after seeing your reply and it’s now recognised by MakeMKV and ripping.MrPenguin wrote: Sun Feb 22, 2026 10:15 pm Unfortunately, that's not the correct TGZ dump file for this disk. We would need one called something like:
And it looks like MakeMKV hasn't managed to generate it yet.
MrPenguin
Could you use SamuriHL's utility to validate your disk please? I think the latest KEYDB.cfg file already has a basic entry for it, but it would be good to be sure. And could you also provide a discatt.dat file? MakeMKV creates one of these files whenever you create an encrypted disk back-up, so you'd only need to start a back-up into a temporary directory, grab the discatt.dat file as soon as it appears (and it should be one of the very first files), and then abort the back-up.HomerJay wrote: Mon Feb 23, 2026 2:39 am I just loaded the disc again after seeing your reply and it’s now recognised by MakeMKV and ripping.
xokia
Se7en movie fails to extract
It seems the rules have changed since last time I uploaded a file. Keydb.cfg doesnt seem accessible for me dont know about others but I can't download the latest file.
http://fvonline-db.bplaced.net/ -> seems dead
link to dumped file
https://limewire.com/d/GRGgP#HRf1ruYgQ1
*edit*
Used the tool and that was able to update the keydb and now extracts
link to dumped file
*edit*
OleBluEyes
Hi!
The Black Belly of the Tarantula FR 4K
Disc type: UHD
Disc ID: 718422ACAB7C5B7B4A7F2F6DDE77AABC0A8A1354
Disc dump filename: MKB20_v82_LA_TARENTULE_AU_VENTRE_NOIR_-_4K_UHD_3356.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
LibreDrive status: Enabled
MKB_RO.inf link: Copied MKB_RO.inf from disc into disk dump
Disc dump link: https://drive.google.com/file/d/1cHkR5z ... kDxCGPhGgU
Thank you!
Disc type: UHD
Thank you!
Rushton
Disc type: UHD
Disc ID: 0C1396FBBCE26A8D74D30A366C263905F943FA0C
Disc dump filename: MKB20_v82_Wicked-_For_Good_67FE.tgz
Drive: BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1ZWNPtg ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1q55J33 ... sp=sharing
Drive: BU40N
99gagamel
Disc Type: UHD
Disc ID: 0xC58CC1300B14294185F507D340DE278EE1BE59A8
Disc Dump Filename: MKB20_v61_RED_13F0,tgz
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/17FBeAJ ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1tBw5_S ... sp=sharing
Drive: BW-1601HT
Toad King
Disc type: UHD
Disc ID: 5440D9CCE73669A738BE3EFEEDF71B6DF0069D64
Disc dump filename: MKB20_v82_Swordsman_2FF6
Drive: BDR-S13JX
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/file/d/1klqcRK ... jyNz4/view
Drive: BDR-S13JX
Chisum04
Disc Type: UHD
Disc ID:
Disc Dump Filename: MKB20_v82_UHD_Shell_C1A7
Drive: BW-1601HT
Link to the file MKB_RO.inf: https://1drv.ms/f/c/29aa5f2d1ffacbe9/Ig ... g?e=Wa8QAZ
Disc ID:
Drive: BW-1601HT
MrPenguin
Thanks for the TGZ dump file, but can you also provide a download link for the actual MKB_RO.inf file from the physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV itself.
