Public KeyDB Disc Submissions
tarzxf
Post by tarzxf »
And it helps if the data directory is NOT set to the output path; my mistake.
Does explain why the .tgz file was appearing there and not the in Library path on the Mac as expected.
Thank you for the continued work and effort!
tarzxf wrote: Sun Feb 22, 2026 5:09 am Howard the Duck 4K
Disc ID: 43973f77769ffac653465f3ad50752d036469c68
Disc dump filename: MKB20_v76_Howard_the_Duck_0D43.tgz
Hey tarzxf, thanks for the submission but your particular disc variant was added to the public keydb on February 3. Please check the latest keydb before posting to this thread.
CrashOveride
Post by CrashOveride »
Disc type: UHD
Disc ID: 06f86853e4d11caab38417abaefd3a63af7e5305
Disc dump filename: MKB20_v82_Galaxy_Express_999_636B
Drive: BW-16D1X-U (Flashed with WH16NS60 firmware)
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? (Yes)
Have you verified that all submission links are accessible in incognito/private browsing? (Yes)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/GCgHyLrQ#Wcd2srw9F ... gK2rEiz0OQ
Disc dump link: https://mega.nz/file/iSQm0KoI#DP6rtmkn1 ... rPAMMLSwUA
Thank you for your effort in maintaining the DB!
Franchiver
Post by Franchiver »
keydb_helper wrote: Sun Feb 22, 2026 11:41 am Thanks to everyone who followed the submission template and provided new disc dump files. The following discs have been added to the public keydb (new media keys indicated with an asterisk):
*MKB20_v82_Halloween_4022
*MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2
*MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94
*MKB20_v82_SPACEBALLS_-_UHD_16F0
*MKB20_v82_THE_BIRTHDAY_-_UHD_52E8
*MKB20_v82_THE_DEAD_315E
Thank you for the addition.
99gagamel
Post by 99gagamel »
Disc Type: UHD
Disc ID: 0xC58CC1300B14294185F507D340DE278EE1BE59A8
Disc Dump Filename: MKB20_v61_RED_13F0,tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1OdhUB0 ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1tBw5_S ... sp=sharing
Getting disc info...
Validation Data: 6625E2B719EDE68D675FC6FACEEA795B [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0xC58CC1300B14294185F507D340DE278EE1BE59A8
[Volume]: RED
[Date]: 2018-04-16
[VID]: 0x6007F1252C537644B4C590C1B387E1CD
[MKB]: 61
[EncKey]: 1-0xB07F3E332852BE91494ABD5FF1BA11DD
[KEYDB_STATUS]: (NOTVALIDATED)
[STATUS]: incomplete
[DiscType]: UHD
HomerJay
Post by HomerJay »
Disc type: UHD Blu-ray
Disc ID: 0xFE47498B9FB93BCF9DA5AA5FFA3B5CCEF7AF4A05
Disc dump filename: MKB_RO.inf
Drive : BH16NS55
LibreDrive status: OK
Did you sync the public keydb within the last 15 minutes? Yes]
MKB_RO.inf link: https://reva.blob.core.windows.net/post ... MKB_RO.inf
Disc dump link: https://reva.blob.core.windows.net/post ... 2_save.tgz
MakeMKV really struggled with this one. It never stopped reading the disc.
KEY DB HELPER:
Disc ID : 0xFE47498B9FB93BCF9DA5AA5FFA3B5CCEF7AF4A05
Volume : Battle of Britain UHD
Title : Battle of Britain - 4K UHD
Disc Type : UHD Blu-ray
Encryption Keys:
VID : 0xCD5D4C22DC89463C65A6854CB468162F
MKB Version : 82
Encrypted Keys (1):
[1] 0xEC4B7899D8424168A77552904C5DCFF7
MrPenguin
Post by MrPenguin »
HomerJay wrote: Sun Feb 22, 2026 6:55 pm Disc dump link: MKB20_v82_save.tgz
Unfortunately, that's not the correct TGZ dump file for this disk :(. We would need one called something like:
  • MKB20_v82_Battle_of_Britain_-_4K_UHD_????.tgz
And it looks like MakeMKV hasn't managed to generate it yet.
Grahamdoh
Post by Grahamdoh »
lukeyrada
Post by lukeyrada »
Makemkv is not able to rip/copy House Party 4K (Criterion). It isn't recognising the Disc properly when it is reading the data to be ripped. There is no such problem with Minority Report 4K. That read and ripped with zero issues. Both are newly released in the UK where I live. I am using a 2021 Macbook Pro (M1) WITH the latest version of Makemkv & MacOS with a Pioneer Drive for the discs.
Any tips or suggestions for a fix would be welcome.
MrPenguin
Post by MrPenguin »
lukeyrada wrote: Sun Feb 22, 2026 11:56 pm Any tips or suggestions for a fix would be welcome.
Have you considered reading the first post in this thread?
HomerJay
Post by HomerJay »
MrPenguin wrote: Sun Feb 22, 2026 10:15 pm Unfortunately, that's not the correct TGZ dump file for this disk :(. We would need one called something like:
I just loaded the disc again after seeing your reply and it’s now recognised by MakeMKV and ripping.
MrPenguin
Post by MrPenguin »
HomerJay wrote: Mon Feb 23, 2026 2:39 am I just loaded the disc again after seeing your reply and it’s now recognised by MakeMKV and ripping.
Could you use SamuriHL's utility to validate your disk please? I think the latest KEYDB.cfg file already has a basic entry for it, but it would be good to be sure. And could you also provide a discatt.dat file? MakeMKV creates one of these files whenever you create an encrypted disk back-up, so you'd only need to start a back-up into a temporary directory, grab the discatt.dat file as soon as it appears (and it should be one of the very first files), and then abort the back-up.
99gagamel
Post by 99gagamel »
xokia
Post by xokia »
Se7en movie fails to extract
It seems the rules have changed since last time I uploaded a file. Keydb.cfg doesnt seem accessible for me dont know about others but I can't download the latest file.
http://fvonline-db.bplaced.net/ -> seems dead
link to dumped file
https://limewire.com/d/GRGgP#HRf1ruYgQ1
*edit*
Used the tool and that was able to update the keydb and now extracts
OleBluEyes
Post by OleBluEyes »
Hi!
The Black Belly of the Tarantula FR 4K
Disc type: UHD
Disc ID: 718422ACAB7C5B7B4A7F2F6DDE77AABC0A8A1354
Disc dump filename: MKB20_v82_LA_TARENTULE_AU_VENTRE_NOIR_-_4K_UHD_3356.tgz
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link: Copied MKB_RO.inf from disc into disk dump
Disc dump link: https://drive.google.com/file/d/1cHkR5z ... kDxCGPhGgU
Thank you!
Rushton
Post by Rushton »
Disc type: UHD
Disc ID: 0C1396FBBCE26A8D74D30A366C263905F943FA0C
Disc dump filename: MKB20_v82_Wicked-_For_Good_67FE.tgz
Drive: BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1ZWNPtg ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1q55J33 ... sp=sharing
