That has nothing to do with it. But I'm telling you right now, "I placed the file in the correct directory and now and it is seeing it" <-- No. You wouldn't know if it's "seeing it" or not. The only way to know that is if it opens a disc that was previously giving you the key issue that then opens once the keydb.cfg is updated. So your premise is incorrect about MakeMKV "seeing it". It's not.
Public KeyDB Disc Submissions
New UK Eureka Blu-ray's
Jakob the Liar
Zen and Sword: The Miyamoto Mushashi Saga Discs 1-3
https://drive.google.com/drive/folders/ ... drive_link
Jakob the Liar
Ok so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.SamuriHL wrote: ↑Tue Feb 17, 2026 5:56 pmThat has nothing to do with it. But I'm telling you right now, "I placed the file in the correct directory and now and it is seeing it" <-- No. You wouldn't know if it's "seeing it" or not. The only way to know that is if it opens a disc that was previously giving you the key issue that then opens once the keydb.cfg is updated. So your premise is incorrect about MakeMKV "seeing it". It's not.
/tmp # ls -l /root/.config/aacs/KEYDB.cfg
-rwxr--r-- 1 root root 62330000 Feb 17 10:06
/tmp # /opt/makemkv/bin/makemkvcon -r info disc:0
MSG:1005,0,1,"MakeMKV v1.18.3 linux(x64-release) started","%1 started","MakeMKV v1.18.3 linux(x64-release)" DRV:0,2,999,12,"BD-RE ASUS BW-16D1HT 3.10 KLFN7EB0918","PEE WEES BIG ADVENTURE","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=0FA242DD4D0B)","%1","Using LibreDrive mode (v06.3 id=0FA242DD4D0B)" MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5050,0,2,"Evaluation version, 30 day(s) out of 30 remaining","Evaluation version, %1 day(s) out of %2 remaining","30","30"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3338,0,2,"Downloading latest HK to /root/.MakeMKV ...","Downloading latest %1 to %2 ...","HK","/root/.MakeMKV" MSG:3339,0,1,"Automatic HK downloading is disabled or failed.","Automatic %1 downloading is disabled or failed.","HK" MSG:3332,16908288,2,"Saved AACS dump file as file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz","Saved %1 dump file as %2","AACS","file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz" MSG:3303,16777216,0,"The volume key is unknown for this disc - video can't be decrypted","The volume key is unknown for this disc - video can't be decrypted"
MSG:5010,0,0,"Failed to open disc","Failed to open disc" TCOUNT:0
keydb_helper
The KEYDB.cfg file needs to go in the same directory as your generated disc dump files. In your case, this means you'll need to copy /root/.config/aacs/KEYDB.cfg to /root/.MakeMKV/KEYDB.cfgMikeismad wrote: ↑Tue Feb 17, 2026 8:49 pmCode: Select all
/tmp # ls -l /root/.config/aacs/KEYDB.cfg -rwxr--r-- 1 root root 62330000 Feb 17 10:06 /root/.config/aacs/KEYDB.cfg /tmp # /opt/makemkv/bin/makemkvcon -r info disc:0 MSG:1005,0,1,"MakeMKV v1.18.3 linux(x64-release) started","%1 started","MakeMKV v1.18.3 linux(x64-release)" MSG:3332,16908288,2,"Saved AACS dump file as file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz" ...
No worries! I'm glad to hear you are now able to process your disc and you have an additional option for future titles.bladerunner911 wrote: ↑Tue Feb 17, 2026 4:20 pmThanks keydb_helper for the note about SamuriHL's KeyDBTool, I did actually use this first, but didn't realise it could be used in the way you suggested - still pretty new at thissorry for wasting time and bandwidth!
My 'All The President's Men' UHD disk is now being read in makemkv correctly, so all good.
Thanks to everyone for making these tools and being so helpful!![]()
Hey AverageMean, unfortunately I don't think there is a native Mac option for FindVUK. I believe Linux users have been able to get it working to some extent via Wine, but I don't recall reading a similar report for macOS. Please feel free to continue posting disc dump files as often as you can.
keydb_helper wrote: ↑Tue Feb 17, 2026 9:18 pm
Thanks, I finally got it working!
Additionally to what you were told above which is absolutely correct, the automatic download is for the MakeMKV hashed keys which is how MakeMKV acquires its own keys. The KeyDB is a completely separate entity that has nothing to do with the automated HK downloads. Meaning, even if the HK downloads were successful, if the key is not known to MakeMKV yet, the KeyDB would still be used. And finally, I would fix the automatic download issue. It's likely DNS related or it's turned off in your MakeMKV settings. That way you can source keys from both MakeMKV HK and the KeyDB at the same time, giving you the best chance to decrypt all your titles going forward.Mikeismad wrote: ↑Tue Feb 17, 2026 8:49 pmOk so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.
Thanks, I appreciate the explanation. I'm going to look into the automatic download issue now.SamuriHL wrote: ↑Tue Feb 17, 2026 9:38 pmAdditionally to what you were told above which is absolutely correct, the automatic download is for the MakeMKV hashed keys which is how MakeMKV acquires its own keys. The KeyDB is a completely separate entity that has nothing to do with the automated HK downloads. Meaning, even if the HK downloads were successful, if the key is not known to MakeMKV yet, the KeyDB would still be used. And finally, I would fix the automatic download issue. It's likely DNS related or it's turned off in your MakeMKV settings. That way you can source keys from both MakeMKV HK and the KeyDB at the same time, giving you the best chance to decrypt all your titles going forward.Mikeismad wrote: ↑Tue Feb 17, 2026 8:49 pmOk so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.
AverageMean
Disc type: UHD
Disc ID: 20d90f77f0145920018058a71aa682acca80b9c9
Disc dump filename: MKB20_v77_STAR_TREK_V-_THE_FINAL_FRONTIER_EF79
Drive: BD-RE HL-DT-ST BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/r4xzzvgz ... x45a4&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/3se19aa7 ... xvm9v&dl=0
Submitted dump files for
Ben Hur 4k Disc 1 and 2. (It's 4K, but still split over 2 discs!)
UhhNewUser
OBI_WAN_KENOBI_COMPLETE_DISC_2
Disc type: BD-ROM UHD
Disc ID: b39a0c5822c15f42b8312a41a36cd5631bb588e9
Disc dump filename: MKB20_v77_Obi-Wan_Kenobi-_The_Complete_Series_Disc_2_B307.tgz
Drive: BD-RE WH16NS40
Drive firmware: 2115-12-11 14:59
MKB_RO.inf link: https://www.dropbox.com/scl/fi/a1hfysop ... bpvpw&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/kws7iq50 ... 4mg18&dl=0
MSCloude115
Here's the dump for Five Nights at Freddy's 2 UHD.
MKB20_v82_Five_Nights_at_Freddy's_2_262C.tgz
https://drive.google.com/file/d/1i7NsUe ... share_link
keydb_helper
Thanks MSCloude115, but your link is not publicly accessible so it cannot be downloaded or processed. Please generate a new link when you get a chance and verify that it is accessible in private browsing/incognito mode before posting it here.MSCloude115 wrote: ↑Wed Feb 18, 2026 3:09 amHere's the dump for Five Nights at Freddy's 2 UHD.
MSCloude115
Sorry about that, I went into Google Drive and changed the access settings to public so you should be good now!keydb_helper wrote: ↑Wed Feb 18, 2026 3:42 amThanks MSCloude115, but your link is not publicly accessible so it cannot be downloaded or processed. Please generate a new link when you get a chance and verify that it is accessible in private browsing/incognito mode before posting it here.MSCloude115 wrote: ↑Wed Feb 18, 2026 3:09 amHere's the dump for Five Nights at Freddy's 2 UHD.
https://drive.google.com/file/d/1i7NsUe ... sp=sharing
Disc type: UHD
Disc ID: 06318e09a2aaeb7973a5bd86c15ccb97c7d18e18
Disc dump filename: MKB20_v76_SCREAM_454D.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/niwgcyyj ... D.tgz/file
Thank you!
Thank you!
Disc type: UHD
Disc ID: 56c5270271312360330a5f4e29109921c91b76c8
Disc dump filename: MKB20_v77_SCREAM_3_8451.tgz
Disc dump link: https://www.mediafire.com/file/9240kt5l ... 1.tgz/file
Thank you!
Thank you!
