Public KeyDB Disc Submissions
Mikeismad
Post by Mikeismad »
keydb_helper wrote:Thanks to everyone who followed the template and provided new disc dump files.
The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Sisu-_Road_to_Revenge_0790
*mkb20_v82_bdrom_3f0a
mkb20_v82_elvira_-_herrscherin_der_dunkelheit_c9e1
*mkb20_v82_factoris_1113_influencers_91c0
*MKB20_v82_SAVE_THE_GREEN_PLANET_-_UHD_E33E
*MKB20_v82_STOLEN_FACE
*MKB20_v82_THE_SHADOWS_EDGE
I believe all other submissions have also been processed.
Hi - I believe I followed the template correctly in post #1786 for Pee Wee 4k criterion. Are you able to review that one?
mikewin
Post by mikewin »
SE7EN
Disc type: UHD
Disc ID: 0xDD92107AF91D7FE6921CDBA37D765FAA09CD3DFA
Disc dump filename: MKB20_v77_Se7en_8EE7.tgz
Drive: BU10
Drive firmware: 0.BU10O
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1i_Vv3j ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1YqIPzz ... sp=sharing
MKVDUDE
Post by MKVDUDE »
Disc type: UHD
Disc dump filename: MKB20_v82_Double_Impact_F1E0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dump link: https://we.tl/t-8FAO9LX8i5
Many thanks!
MrPenguin
Post by MrPenguin »
Mikeismad wrote: Tue Feb 17, 2026 1:45 am Hi - I believe I followed the template correctly in post #1786 for Pee Wee 4k criterion. Are you able to review that one?
keydb_helper wrote:I believe all other submissions have also been processed.
Have you tried downloading the latest KDYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
99gagamel
Post by 99gagamel »
Disc Type: UHD
Disc ID:v06.3 id=EC0D0F39EDA7
Disc Dump Filename: MKB20_v77_Halloween_3_9639,tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1q37mAJ ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1c4xnAl ... sp=sharing
______________________________________________________________________________________________________________________
Disc Type: UHD
Disc ID:v06.3 id=E064BA3E3F81
Disc Dump Filename: MKB20_v77_Halloween_2_2605,tgz
Drive: BW-1601HT
Drive Firmware: 3.01
Link to the file MKB_RO.inf: https://drive.google.com/file/d/183oWxJ ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1bSVTm5 ... sp=sharing
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v60_GODS_OF_EGYPT_9D8A
*MKB20_v77_Halloween_2_2605
*MKB20_v77_Halloween_3_9639
*MKB20_v77_Se7en_8EE7
*MKB20_v77_The_Rocky_Horror_Picture_Show_6ACC
*MKB20_v82_Double_Impact_F1E0
*MKB20_v82_Nobody_2_ABD2
As the public keydb continues to grow, there are an increasing number of UHD media keys which can be used to derive complete keydb records for similar disc variants. I strongly recommend Windows users take the time to try SamuriHL's KeyDBTool as it would've derived & submitted the variant-specific keys and avoided the need to post the following titles:
AverageMean wrote: Mon Feb 16, 2026 5:29 pm Disc dump filename: MKB20_v77_STAR_TREK-_THE_MOTION_PICTURE_-_DIRECTOR'S_EDITION_57D7
PConnors wrote: Mon Feb 16, 2026 2:08 pm Disc dump filename: MKB20_v77_The_Dead_Zone_6C69.tgz
liels wrote: Tue Feb 17, 2026 12:04 am Disc dump filename: MKB20_v77_TRON-_ARES_8CF9.tgz
bladerunner911 wrote: Mon Feb 16, 2026 2:06 pm Disc dump filename: MKB20_v82_All_the_President's_Men_77E8
polygonbronson wrote: Tue Feb 17, 2026 2:23 am MKB20_v82_F1_FBFB.tgz
FootFungus07 wrote: Mon Feb 16, 2026 11:58 pm Disc dump filename: MKB20_v82_Richard_Pryor_Here_and_Now_F9ED.tgz
Public KeyDB Disc Submissions KeyDB Download
Mikeismad
Post by Mikeismad »
MrPenguin wrote: Tue Feb 17, 2026 11:34 am
I have and just tried it again. However, I did open the KEYDB file and confirmed that my disc ID is present, but I keep getting this error: "The volume key is unknown for this disc - video can't be decrypted. Failed to open disc."
I'm using the MakeMKV docker on an Unraid server. I just deleted my KEYDB.cfg file from appdata/MakeMKV and then download and copied over a new one. I also completely shut down the server and retried again.
Post by SamuriHL »
MakeMKV isn't finding your keydb.cfg file. You need to know what the data directory is defined as and put the keydb.cfg in that directory. Sometimes it needs to be named KEYDB.cfg as on Linux case is not optional.
bladerunner911
Post by bladerunner911 »
Thanks keydb_helper for the note about SamuriHL's KeyDBTool, I did actually use this first, but didn't realise it could be used in the way you suggested - still pretty new at this ;-) sorry for wasting time and bandwidth!
My 'All The President's Men' UHD disk is now being read in makemkv correctly, so all good.
Thanks to everyone for making these tools and being so helpful! 8)
Mikeismad
Post by Mikeismad »
SamuriHL wrote: Tue Feb 17, 2026 3:47 pm MakeMKV isn't finding your keydb.cfg file. You need to know what the data directory is defined as and put the keydb.cfg in that directory. Sometimes it needs to be named KEYDB.cfg as on Linux case is not optional.
Ok thanks for the feedback. I placed the file in the correct directory and now and it is seeing it, but I'm still getting the same error. Then when I reviewed the Disc ID entry it says "NOTVALIDATED". Could this be the issue?
root@Blue:~# grep -i dee8ba763134399d2326ad111c9d3b33ae625db8 /mnt/user/appdata/MakeMKV/.config/aacs/KEYDB.cfg
0xDEE8BA763134399D2326AD111C9D3B33AE625DB8 = PEE WEES BIG ADVENTURE (PEE-WEE’S BIG ADVENTURE) | D | 2025-10-14 | M | 0x8DD4ED6B29C174E64D3397AF2A3EA7E4 | I | 0x5EB485287AA4C28F449C0F15BE37EC7F | V | 0x37C9658DCD195D86341795BB93631A0B | U | 1-0x07C4D7438ACD4D3189E3B00C60720A98 ; MKBv82/BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
AverageMean
Post by AverageMean »
Is there a Mac friendly version of this tool?
keydb_helper wrote: Tue Feb 17, 2026 2:52 pm As the public keydb continues to grow, there are an increasing number of UHD media keys which can be used to derive complete keydb records for similar disc variants. I strongly recommend Windows users take the time to try SamuriHL's KeyDBTool as it would've derived & submitted the variant-specific keys and avoided the need to post the following titles:
Post by SamuriHL »
Mikeismad wrote: Tue Feb 17, 2026 4:26 pm Ok thanks for the feedback. I placed the file in the correct directory and now and it is seeing it, but I'm still getting the same error. Then when I reviewed the Disc ID entry it says "NOTVALIDATED". Could this be the issue?
That has nothing to do with it. But I'm telling you right now, "I placed the file in the correct directory and now and it is seeing it" <-- No. You wouldn't know if it's "seeing it" or not. The only way to know that is if it opens a disc that was previously giving you the key issue that then opens once the keydb.cfg is updated. So your premise is incorrect about MakeMKV "seeing it". It's not.
Grahamdoh
Post by Grahamdoh »
New UK Eureka Blu-ray's
Jakob the Liar
Zen and Sword: The Miyamoto Mushashi Saga Discs 1-3
https://drive.google.com/drive/folders/ ... drive_link
Mikeismad
Post by Mikeismad »
SamuriHL wrote: Tue Feb 17, 2026 5:56 pm
Ok so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.
/tmp # ls -l /root/.config/aacs/KEYDB.cfg
-rwxr--r-- 1 root root 62330000 Feb 17 10:06
/tmp # /opt/makemkv/bin/makemkvcon -r info disc:0
MSG:1005,0,1,"MakeMKV v1.18.3 linux(x64-release) started","%1 started","MakeMKV v1.18.3 linux(x64-release)" DRV:0,2,999,12,"BD-RE ASUS BW-16D1HT 3.10 KLFN7EB0918","PEE WEES BIG ADVENTURE","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=0FA242DD4D0B)","%1","Using LibreDrive mode (v06.3 id=0FA242DD4D0B)" MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5050,0,2,"Evaluation version, 30 day(s) out of 30 remaining","Evaluation version, %1 day(s) out of %2 remaining","30","30"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3338,0,2,"Downloading latest HK to /root/.MakeMKV ...","Downloading latest %1 to %2 ...","HK","/root/.MakeMKV" MSG:3339,0,1,"Automatic HK downloading is disabled or failed.","Automatic %1 downloading is disabled or failed.","HK" MSG:3332,16908288,2,"Saved AACS dump file as file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz","Saved %1 dump file as %2","AACS","file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz" MSG:3303,16777216,0,"The volume key is unknown for this disc - video can't be decrypted","The volume key is unknown for this disc - video can't be decrypted"
MSG:5010,0,0,"Failed to open disc","Failed to open disc" TCOUNT:0
keydb_helper
Mikeismad wrote: Tue Feb 17, 2026 8:49 pm
The KEYDB.cfg file needs to go in the same directory as your generated disc dump files. In your case, this means you'll need to copy /root/.config/aacs/KEYDB.cfg to /root/.MakeMKV/KEYDB.cfg
bladerunner911 wrote: Tue Feb 17, 2026 4:20 pm Thanks keydb_helper for the note about SamuriHL's KeyDBTool, I did actually use this first, but didn't realise it could be used in the way you suggested - still pretty new at this ;-) sorry for wasting time and bandwidth!
No worries! I'm glad to hear you are now able to process your disc and you have an additional option for future titles.
AverageMean wrote: Tue Feb 17, 2026 5:45 pm Is there a Mac friendly version of this tool?
Hey AverageMean, unfortunately I don't think there is a native Mac option for FindVUK. I believe Linux users have been able to get it working to some extent via Wine, but I don't recall reading a similar report for macOS. Please feel free to continue posting disc dump files as often as you can.
