LibreDrive for Pioneer drives
Superunknown
#1876 Post by Superunknown » Sun Feb 15, 2026 9:57 am
I've was doing some tidying and discovered an BDR-XD08TB in a cupboard :D Is it possible to enable LibreDrive for MakeMKV / UHD ripping on it, please?
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.04
Serial number: CGDL000966WL
Firmware date: 2024-10-09
Highest AACS version: 76
Drive platform: Pioneer RS9330
Firmware version: GENE
zittrig
#1877 Post by zittrig » Sun Feb 15, 2026 10:21 am
The firmware is past 11/2022 and can't be flashed. Perhaps there's a solution in the future.
Superunknown
#1878 Post by Superunknown » Sun Feb 15, 2026 4:57 pm
Ah, that’s a shame :(
MrPenguin
#1879 Post by MrPenguin » Sun Feb 15, 2026 7:03 pm
Superunknown wrote: Sun Feb 15, 2026 4:57 pm Ah, that’s a shame :(
We waited over 2 years for Mike to add LibreDrive support for firmware >= 2022-12. Don't give up on cross-flashing yet ... ;).
InigoMontoya
#1880 Post by InigoMontoya » Mon Feb 16, 2026 10:32 pm
Just wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
#1881 Post by Billycar11 » Tue Feb 17, 2026 12:19 am
InigoMontoya wrote: Mon Feb 16, 2026 10:32 pm Just wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
Email me your makemkv drive info section see below for email
InigoMontoya
#1882 Post by InigoMontoya » Tue Feb 17, 2026 12:54 am
Billycar11 wrote: Tue Feb 17, 2026 12:19 am
Sorry. Should have been more specific. I don't have this drive. I was thinking about purchasing it. Just wanted to be sure it would work first. Maybe this isnt enough info though?
#1883 Post by MartyMcNuts » Tue Feb 17, 2026 1:17 am
InigoMontoya wrote: Tue Feb 17, 2026 12:54 am
No one can be sure one way or another until we can see the MakeMKV drive info & libredrive info sections.
InigoMontoya
#1884 Post by InigoMontoya » Tue Feb 17, 2026 2:13 am
MartyMcNuts wrote: Tue Feb 17, 2026 1:17 am
Got it. Ill try to get more info. Thanks!
Karl Napf
#1885 Post by Karl Napf » Tue Feb 17, 2026 10:11 pm
"Hi, I'm new here and can't send PMs yet. I have a Pioneer BDR-UD03 (FW 1.14 / RS8511) and I'm looking for the MK-Firmware for LibreDrive support. Can someone help me out? Thanks from Germany!"
#1886 Post by Coopervid » Wed Feb 18, 2026 10:14 am
Karl Napf wrote: Tue Feb 17, 2026 10:11 pm "Hi, I'm new here and can't send PMs yet. I have a Pioneer BDR-UD03 (FW 1.14 / RS8511) and I'm looking for the MK-Firmware for LibreDrive support. Can someone help me out? Thanks from Germany!"
PM sent.
tallnproud
#1887 Post by tallnproud » Sun Feb 22, 2026 4:18 pm
I seem to be in the unfortunate boat where I have a Pioneer drive (BDR-XD08) with 2022-12-17 firmware that can't be cross-flashed to enable UHD playback/ripping.
OS device name: E:
Revision: 1.02
Serial number: **************
Firmware date: 2022-12-27
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
I have seen on multiple posts that a future update of LibreDrive might make cross-flashing possible. Is there an estimated time-frame for when that would happen? And if it did, where would this kind of news be shared?
#1888 Post by Billycar11 » Sun Feb 22, 2026 4:24 pm
tallnproud wrote: Sun Feb 22, 2026 4:18 pm I seem to be in the unfortunate boat where I have a Pioneer drive (BDR-XD08) with 2022-12-17 firmware that can't be cross-flashed to enable UHD playback/ripping.
OS device name: E:
Revision: 1.02
Email me that drive info section
I and only I can flash that
911delorean
#1889 Post by 911delorean » Wed Feb 25, 2026 10:18 pm
RS8xxx and later, including RS9xxx RSAxxx and so on. Should be supported.
At the time of this writing none of the Pioneer drives require firmware update - they should just work.
If youre drive is listed above but is not supported, it means that it is not yet added to SDF.bin . Please post the drive model here.
Thought I would post that my drive appears to be missing from the list even though it is supported according to the first post.
BDR-207D FW v1.60, says its a RS8000 so it should be supported.
Anything I can do to help?
havokcloud
#1890 Post by havokcloud » Sat Feb 28, 2026 10:10 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: QDDL118815WL
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
Pulled out my old external drive and I was wondering if someone can help this poor old soul properly flash his firmware. Would be greatly appreciated!
