Dump submitted for 3:10 to Yuma
niteflyr
Post by niteflyr » Fri Feb 06, 2026 8:22 pm
MKB20_v82_310_TO_YUMA_9F3C.tgz
keyed.cfg works for this title
tbrady3742@aol.com
Re: Dump submitted for 3:10 to Yuma
Post by tbrady3742@aol.com » Sat Feb 14, 2026 7:09 pm
Did you get 4K of 3:10 to Yuma to copy? Mine keeos saying failed to open.
andypinkc
Post by andypinkc » Sun Feb 15, 2026 12:52 pm
I'm also getting failed to open
MrPenguin
Post by MrPenguin » Sun Feb 15, 2026 11:04 pm
tbrady3742@aol.com wrote: Sat Feb 14, 2026 7:09 pm Did you get 4K of 3:10 to Yuma to copy? Mine keeos saying failed to open.
If this doesn't work, you'll need to email those TGZ dump files to svq@makemkv.com, and maybe also upload them into (say) OneDrive or Google Drive, and then reply here with public download links.
tbrady3742@aol.com
Post by tbrady3742@aol.com » Mon Feb 16, 2026 9:19 pm
Thanks, I just sent to one drive and emailed them.
MrPenguin wrote: Sun Feb 15, 2026 11:04 pm
MrPenguin
Post by MrPenguin » Mon Feb 16, 2026 9:22 pm
tbrady3742@aol.com wrote: Mon Feb 16, 2026 9:19 pm Thanks, I just sent to one drive and emailed them.
Emailing it to svq@makemkv.com will allow MakeMKV to add your disk to its private "hashed keys" database at some (unknowable) point in the future. However, if you can also provide a public link to download this file from OneDrive then we could try adding your disk to KEYDB too.
