Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.04
Serial number: CGDL000966WL
Firmware date: 2024-10-09
Highest AACS version: 76
Drive platform: Pioneer RS9330
Firmware version: GENE
LibreDrive for Pioneer drives
Superunknown
I've was doing some tidying and discovered an BDR-XD08TB in a cupboard
Is it possible to enable LibreDrive for MakeMKV / UHD ripping on it, please?
The firmware is past 11/2022 and can't be flashed. Perhaps there's a solution in the future.
Superunknown
Ah, that’s a shame
We waited over 2 years for Mike to add LibreDrive support for firmware >= 2022-12. Don't give up on cross-flashing yet ...
InigoMontoya
Just wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
InigoMontoya wrote: ↑Mon Feb 16, 2026 10:32 pmJust wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
Email me your makemkv drive info section see below for email
InigoMontoya
Sorry. Should have been more specific. I don't have this drive. I was thinking about purchasing it. Just wanted to be sure it would work first. Maybe this isnt enough info though?Billycar11 wrote: ↑Tue Feb 17, 2026 12:19 amInigoMontoya wrote: ↑Mon Feb 16, 2026 10:32 pmJust wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
No one can be sure one way or another until we can see the MakeMKV drive info & libredrive info sections.InigoMontoya wrote: ↑Tue Feb 17, 2026 12:54 amSorry. Should have been more specific. I don't have this drive. I was thinking about purchasing it. Just wanted to be sure it would work first. Maybe this isnt enough info though?Billycar11 wrote: ↑Tue Feb 17, 2026 12:19 amInigoMontoya wrote: ↑Mon Feb 16, 2026 10:32 pmJust wondering if anyone knew if the Pioneer BDR-211XJB with firmware 1.51 (2018) would work for LibreDrive/UHD ripping? I assume it would be because of the firmware date, but I cant seem to find this drive listed on the compatible/incompatible list or the LibreDrive list.
InigoMontoya
Got it. Ill try to get more info. Thanks!MartyMcNuts wrote: ↑Tue Feb 17, 2026 1:17 amNo one can be sure one way or another until we can see the MakeMKV drive info & libredrive info sections.InigoMontoya wrote: ↑Tue Feb 17, 2026 12:54 amSorry. Should have been more specific. I don't have this drive. I was thinking about purchasing it. Just wanted to be sure it would work first. Maybe this isnt enough info though?Billycar11 wrote: ↑Tue Feb 17, 2026 12:19 am
"Hi, I'm new here and can't send PMs yet. I have a Pioneer BDR-UD03 (FW 1.14 / RS8511) and I'm looking for the MK-Firmware for LibreDrive support. Can someone help me out? Thanks from Germany!"
