Glad that worked for you. Enjoy!BBonus wrote: Thu Feb 12, 2026 6:31 pm Hi thanks I didn't notice the different path - not sure why I had two paths, may have tried to do this before. I have changed my data directory in MakeMKV settings (to the normal default location) and put all files including keydb.cfg in the data directory, and all is now fine, I am ripping Excalibur 4K. Also, next time I will follow the correct process/submission format, apologies. Many thanks!
Public KeyDB Disc Submissions
keydb_helper
Hey t1ll1van1ll1, the long number is the SHA-1 hash of the Unit_Key_RO.inf file. You'll find this file inside the AACS directory on your disc. You can calculate this hash value with tools such as 7-zip on Windows or the shasum/sha1sum command-line utility on Linux/macOS.t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
The following discs corresponded to new media keys:
MKB20_v77_Frontier_Crucible_1018
MKB20_v82_LE_ONDE_DEL_DESTINO_7CF0
MKB20_v82_SEAL_8724
MKB20_v82_The_Straight_Story_UHD
organicguy
If you're on Windows (which has PowerShell installed by default), you can open PowerShell and run this command (this assumes D is the letter associated with your UHD/blu-ray disc drive -- you'll need to change that if it's different on your computer):t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
Get-FileHash "D:\AACS\Unit_Key_RO.inf" -Algorithm SHA1 | Select-Object -ExpandProperty HashThanks again keydb_helper for the fast turnaround.
t1ll1van1ll1
t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm Disc type: UHD
Disc ID: 02C8D87FDCA831654EEE2E20C423C217BD560DBE
Disc dump filename: MKB20_v82_Wicked-_For_Good_6D8E
Drive: BD-RE WH16NS60
Drive firmware: Patched (microcode access re-enabled)
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1-PunwJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1wOJhcg ... sp=sharing
thank you for your kind and explanatory reply. you seem to be nice people. i have added the Disc ID.
Thank You:
Aktion Mutante (German UHD Disc)
Disc type: UHD
Disc ID: 0x414CCAA9DFF3A729292BCABA5F8BC158CF11F65C
Disc dump filename: MKB20_v82_AKTION_MUTANTE_0E4F.tgz
Drive: BD-RE ASUS BW 16D 1HT
Drive firmware: 3.10
MKB_RO.inf link: https://we.tl/t-krBaJijmOC
Disc dump link: https://we.tl/t-dtHLjw9puH
Disc type: UHD
FootFungus07
Predator Badlands - 4K UHD TGZ Key File
Disc type: UHD
Disc dump filename: MKB20_v77_PREDATOR-_BADLANDS_5B48.tgz
Drive: BD-RE BP60NB10
Drive firmware: Enabled 2120-05-07 09:35
Predator Badlands - 4K UHD TGZ Key File Link:
https://drive.google.com/file/d/1FyG-QZ ... drive_link
Disc type: UHD
Can you also provide the MKB_RO.inf file from your physical UHD disk please? The copy of MKB_RO.inf file inside the TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. Similarly, there is no point uploading the truncated 56 byte MKB_RO.inf file again because we already have that (useless) version from your TGZ dump file.Cineph wrote: Fri Feb 13, 2026 4:32 pm Aktion Mutante (German UHD Disc)
MKB_RO.inf link: ...
NEW MKB_RO.inf link : https://we.tl/t-vAK4Eqmd1lCineph wrote: Fri Feb 13, 2026 4:32 pm Thank You:
Disc type: UHD
NEW MKB_RO.inf link : https://we.tl/t-plWZDSACQICineph wrote: Thu Feb 12, 2026 4:19 pm I hope I do this correctly:
Bugonia (German UHD Disc)
Disc type: UHD
Disc ID: 0x3DBF7179CCB84AFAF2875D26A93039C0E4A0B375
Disc dump filename: MKB20_v82_Bugonia_9EBA.tgz
MKB_RO.inf link: https://we.tl/t-ao21DAkkgs
Disc dump link: https://we.tl/t-rl7vlDPV4B
Thanks for the correction. I uploaded the MKB from the disc again from both files. Thank you very much.MrPenguin wrote: Sat Feb 14, 2026 12:21 amCan you also provide the MKB_RO.inf file from your physical UHD disk please? The copy of MKB_RO.inf file inside the TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. Similarly, there is no point uploading the truncated 56 byte MKB_RO.inf file again because we already have that (useless) version from your TGZ dump file.Cineph wrote: Fri Feb 13, 2026 4:32 pm Aktion Mutante (German UHD Disc)
Save The Green Planet UHD - Arrow
Disc type: UHD
Disc ID: 2A5F643F650D91DF08403AD4112B6D87B1F83F70
Disc dump filename: MKB20_v82_SAVE_THE_GREEN_PLANET_-_UHD_E33E.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1G-sodB ... sp=sharing
Disc dump link: https://drive.google.com/file/d/16js7aZ ... sp=sharing
Drive: BW-16D1HT
Dump file sent: Sisu - Road to Revenge 4K(German Disc):
https://drive.google.com/open?id=1h61BA ... p=drive_fs
https://drive.google.com/open?id=1knJtb ... p=drive_fs
Ben Hur 4k
Disc type:: UHD
Disc ID: 32D6762CAC4718765246BE6319D23832361FB333
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_C2F6.tgz
Drive: LG WH16NS60
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1dzFWxb ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BQOf5N ... sp=sharing
Disc type:: UHD
Drive: LG WH16NS60
Preadtor Badlands 4k
Disc type:: UHD
Disc ID:
Disc dump filename: MKB20_v77_PREDATOR-_BADLANDS_B42A.tgz
Drive: BD-RE BU40N
Disc dump link:
Edit: links removed, updated Keydb again and ripping. Not sure if any changes were made, but appreciate it and all the work that goes into these efforts!
Disc type:: UHD
Disc ID:
Drive: BD-RE BU40N
Disc dump link:
