Public KeyDB Disc Submissions
Mikeismad
#1786 Post by Mikeismad » Thu Feb 12, 2026 9:00 pm
Pee-Wees Big Adventure Criterion 4k
Disc type: UHD
Disc ID: dee8ba763134399d2326ad111c9d3b33ae625db8
Disc dump filename: MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301
Drive: ASUS_BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link:
Disc dump link:
#1787 Post by SamuriHL » Thu Feb 12, 2026 10:03 pm
BBonus wrote: Thu Feb 12, 2026 6:31 pm Hi thanks I didn't notice the different path - not sure why I had two paths, may have tried to do this before. I have changed my data directory in MakeMKV settings (to the normal default location) and put all files including keydb.cfg in the data directory, and all is now fine, I am ripping Excalibur 4K. Also, next time I will follow the correct process/submission format, apologies. Many thanks!
Glad that worked for you. Enjoy!
keydb_helper
#1788 Post by keydb_helper » Fri Feb 13, 2026 1:13 am
t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
Hey t1ll1van1ll1, the long number is the SHA-1 hash of the Unit_Key_RO.inf file. You'll find this file inside the AACS directory on your disc. You can calculate this hash value with tools such as 7-zip on Windows or the shasum/sha1sum command-line utility on Linux/macOS.
Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
The following discs corresponded to new media keys:
MKB20_v77_Frontier_Crucible_1018
MKB20_v82_LE_ONDE_DEL_DESTINO_7CF0
MKB20_v82_SEAL_8724
MKB20_v82_The_Straight_Story_UHD
organicguy
#1789 Post by organicguy » Fri Feb 13, 2026 3:04 am
If you're on Windows (which has PowerShell installed by default), you can open PowerShell and run this command (this assumes D is the letter associated with your UHD/blu-ray disc drive -- you'll need to change that if it's different on your computer):
Get-FileHash "D:\AACS\Unit_Key_RO.inf" -Algorithm SHA1 | Select-Object -ExpandProperty Hash
This should work on macOS or Linux as well if you have PowerShell installed.
Thanks again keydb_helper for the fast turnaround.
t1ll1van1ll1
#1790 Post by t1ll1van1ll1 » Fri Feb 13, 2026 7:02 am
t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm Disc type: UHD
Disc ID: 02C8D87FDCA831654EEE2E20C423C217BD560DBE
Disc dump filename: MKB20_v82_Wicked-_For_Good_6D8E
Drive: BD-RE WH16NS60
Drive firmware: Patched (microcode access re-enabled)
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1-PunwJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1wOJhcg ... sp=sharing
thank you for your kind and explanatory reply. you seem to be nice people. i have added the Disc ID.
Cineph
#1791 Post by Cineph » Fri Feb 13, 2026 4:32 pm
Thank You:
Aktion Mutante (German UHD Disc)
Disc type: UHD
Disc ID: 0x414CCAA9DFF3A729292BCABA5F8BC158CF11F65C
Disc dump filename: MKB20_v82_AKTION_MUTANTE_0E4F.tgz
Drive: BD-RE ASUS BW 16D 1HT
MKB_RO.inf link: https://we.tl/t-krBaJijmOC
Disc dump link: https://we.tl/t-dtHLjw9puH
FootFungus07
#1792 Post by FootFungus07 » Fri Feb 13, 2026 8:01 pm
Predator Badlands - 4K UHD TGZ Key File
Disc type: UHD
Disc dump filename: MKB20_v77_PREDATOR-_BADLANDS_5B48.tgz
Drive: BD-RE BP60NB10
Drive firmware: Enabled 2120-05-07 09:35
Predator Badlands - 4K UHD TGZ Key File Link:
https://drive.google.com/file/d/1FyG-QZ ... drive_link
MrPenguin
#1793 Post by MrPenguin » Sat Feb 14, 2026 12:21 am
Cineph wrote: Fri Feb 13, 2026 4:32 pm Aktion Mutante (German UHD Disc)
MKB_RO.inf link: ...
Can you also provide the MKB_RO.inf file from your physical UHD disk please? The copy of MKB_RO.inf file inside the TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. Similarly, there is no point uploading the truncated 56 byte MKB_RO.inf file again because we already have that (useless) version from your TGZ dump file.
Cineph
#1794 Post by Cineph » Sat Feb 14, 2026 1:05 pm
Cineph wrote: Fri Feb 13, 2026 4:32 pm Thank You:
Disc type: UHD
NEW MKB_RO.inf link : https://we.tl/t-vAK4Eqmd1l
Cineph
#1795 Post by Cineph » Sat Feb 14, 2026 1:07 pm
Cineph wrote: Thu Feb 12, 2026 4:19 pm I hope I do this correctly:
Bugonia (German UHD Disc)
Disc type: UHD
Disc ID: 0x3DBF7179CCB84AFAF2875D26A93039C0E4A0B375
Disc dump filename: MKB20_v82_Bugonia_9EBA.tgz
MKB_RO.inf link: https://we.tl/t-ao21DAkkgs
Disc dump link: https://we.tl/t-rl7vlDPV4B
NEW MKB_RO.inf link : https://we.tl/t-plWZDSACQI
Cineph
#1796 Post by Cineph » Sat Feb 14, 2026 1:08 pm
MrPenguin wrote: Sat Feb 14, 2026 12:21 am
Thanks for the correction. I uploaded the MKB from the disc again from both files. Thank you very much.
tylwyth
Save The Green Planet UHD - Arrow
#1797 Post by tylwyth » Sat Feb 14, 2026 3:29 pm
Disc type: UHD
Disc ID: 2A5F643F650D91DF08403AD4112B6D87B1F83F70
Disc dump filename: MKB20_v82_SAVE_THE_GREEN_PLANET_-_UHD_E33E.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1G-sodB ... sp=sharing
Disc dump link: https://drive.google.com/file/d/16js7aZ ... sp=sharing
katja2500
#1798 Post by katja2500 » Sat Feb 14, 2026 3:40 pm
hammr25
#1799 Post by hammr25 » Sat Feb 14, 2026 11:55 pm
Ben Hur 4k
Disc type:: UHD
Disc ID: 32D6762CAC4718765246BE6319D23832361FB333
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_C2F6.tgz
Drive: LG WH16NS60
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1dzFWxb ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1BQOf5N ... sp=sharing
MrPenguin
#1800 Post by MrPenguin » Sun Feb 15, 2026 12:03 am
hammr25 wrote: Sat Feb 14, 2026 11:55 pm Ben Hur 4k
Disc type:: UHD
The latest KEYDB.cfg file already contains this disk.
