UHD Ballerina_F37F
Dartellum
UHD Ballerina_F37F
Post by Dartellum »
I emailed the tgz file generated for UHD Ballerina F37F. I searched the KEYDB.cfg file and only found one entry for Hellride with F37F.
MrPenguin
Re: UHD Ballerina_F37F
Post by MrPenguin »
Dartellum wrote: Thu Feb 12, 2026 1:47 am I emailed the tgz file generated for UHD Ballerina F37F. I searched the KEYDB.cfg file and only found one entry for Hellride with F37F.
Copy the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files), restart MakeMKV and then try ripping your disk again.
Dartellum
Post by Dartellum »
Thanks! Working now. :D
