Public KeyDB Disc Submissions
BBonus
#1771 Post by BBonus » Wed Feb 11, 2026 7:46 pm
MrPenguin
#1772 Post by MrPenguin » Wed Feb 11, 2026 8:34 pm
BBonus wrote: Wed Feb 11, 2026 7:46 pm Hi - Excalibur 4K dump submitted:
The latest KEYDB.cfg file already has an entry for this disk.
BBonus
#1773 Post by BBonus » Wed Feb 11, 2026 10:33 pm
Hi - thanks I followed the KEYDB.cfg instructions - I have unzipped file keydb.cfg saved in:
C:\Users\[my user name]\.MakeMKV
However I still get this following error. Do I need to do something else?
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=E9BA8ECC61EF)
Saved AACS dump file as C:/Program Files (x86)/MakeMKV/MKB20_v82_EXCALIBUR_-_4K_UHD_0994.tgz
bfurner
#1774 Post by bfurner » Wed Feb 11, 2026 10:42 pm
Here is information for the Criterion 4k release of Playtime
Disc type: UHD
Disc ID: 4111BF3A9A7D08E8154F4952050C6E52C2644463
Disc dump filename: MKB20_v82_PLAYTIME_FE06
Drive: BD-RE WH16NS60
Drive firmware:
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1L9dSb9 ... drive_link
Disc dump link: https://drive.google.com/file/d/1trHqhA ... drive_link
#1775 Post by SamuriHL » Thu Feb 12, 2026 1:32 am
BBonus wrote: Wed Feb 11, 2026 10:33 pm Hi - thanks I followed the KEYDB.cfg instructions - I have unzipped file keydb.cfg saved in:
You put the keydb.cfg file in the wrong location. For whatever reason your data directory is set to C:/Program Files (x86)/MakeMKV/ and that's where it needs to go or change the data directory in your MakeMKV settings.
tterbg201
#1776 Post by tterbg201 » Thu Feb 12, 2026 2:07 am
I hope I do this correctly:
F1: The Movie
Disc type: UHD
Disc ID: 0x74D1A4FFE698D702ECBDF93BC389F2AF73D377C7
Disc dump filename: MKB20_v82_F1_FBFB.tgz
Drive: Pioneer BD-RW BDR-XD08U
Drive firmware: 1.04
MKB_RO.inf link: https://drive.proton.me/urls/ME344FSEEC#H5Clcb1qrP1L
Disc dump link: https://drive.proton.me/urls/P7YP1BQNF4#d9pm3z82QKn8
organicguy
#1777 Post by organicguy » Thu Feb 12, 2026 2:47 am
Hello, submitting a dump file for disc 1 of the Ben-Hur 4K release that just came out:
Disc type: UHD
Disc ID: 0x298A235FDD0FE0EA8E450918B576187677C941F2
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_132A.tgz
Drive: LG BE16NU50
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... c?e=VPdrOL
Disc dump link: https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... s?e=vhTAiA
Tihany
#1778 Post by Tihany » Thu Feb 12, 2026 10:16 am
Un drôle de flic - French UHD
Disc type: UHD
Disc ID: 0x1929d651350bdd951e4734d9db33bc334af9bec5
Disc dump filename: MKB20_v82_UnDroleDeFlic_393F.tgz
Drive firmware: 1.02
MKB_RO.inf link: https://limewire.com/d/RozaJ#2gjHNOqVv4
Disc dump link: https://limewire.com/d/XCTnJ#f0mTYODvKx
keydb_helper
#1779 Post by keydb_helper » Thu Feb 12, 2026 10:35 am
Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
The following discs corresponded to new media keys:
MKB20_v82_Fear_In_The_Night_40A6
MKB20_v82_Now_You_See_Me-_Now_You_Don't_9DF8
MKB20_v82_PREDATOR-_BADLANDS_990E
MKB20_v82_PREDATOR_BADLANDS_A230
DutchComputerKid
#1780 Post by DutchComputerKid » Thu Feb 12, 2026 11:44 am
Here the new Puss In Boots UHD release, haven't gotten The Last Wish in the mail yet but straight to getting the keys:
Disc type: UHD
Disc ID: c998c57b8fdb7bb4b2c29c8df1605c0c5a2759e0
Disc dump filename: MKB20_v77_Puss_in_Boots_7C67
Drive: BDR-UD04
Drive firmware:  Original (unpatched)
LibreDrive status: Enabled (2.1)
MKB_RO.inf & disc dump link: https://mega.nz/file/71pF3ACY#Nexlaf9g3 ... tDZ4kiK4wE
Both the tgz and the whole AACS folder just in case, also since the tgz has the smaller 56 byte file, not 5MiB.
organicguy
#1781 Post by organicguy » Thu Feb 12, 2026 2:26 pm
Thank you for the fast turnaround on Ben-Hur Disc 1.
I just found out this morning that the blu-ray (with the extras) isn't in the DB yet either. Here is that disc info:
Disc type: Blu-ray
Disc ID: 0xA1BAF3EFBE0217E39CEC9CD311841EC9B7C10F84
Disc dump filename: MKB_v82_Ben-Hur_(1959)_Bonus_Disc_6AA6.tgz
Drive: LG BE16NU50
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... g?e=VW9tmE
Disc dump link: https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... A?e=YazwDZ
Cineph
#1782 Post by Cineph » Thu Feb 12, 2026 4:19 pm
Bugonia (German UHD Disc)
Disc type: UHD
Disc ID: 0x3DBF7179CCB84AFAF2875D26A93039C0E4A0B375
Disc dump filename: MKB20_v82_Bugonia_9EBA.tgz
Drive: BD-RE ASUS BW 16D 1HT
Drive firmware: 3.10
MKB_RO.inf link: https://we.tl/t-ao21DAkkgs
Disc dump link: https://we.tl/t-rl7vlDPV4B
Brollan
#1783 Post by Brollan » Thu Feb 12, 2026 4:48 pm
keydb_helper wrote: Thu Feb 12, 2026 10:35 am Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
Perfect, works like a charm, thanks guys! :D
BBonus
#1784 Post by BBonus » Thu Feb 12, 2026 6:31 pm
SamuriHL wrote: Thu Feb 12, 2026 1:32 am
Hi thanks I didn't notice the different path - not sure why I had two paths, may have tried to do this before. I have changed my data directory in MakeMKV settings (to the normal default location) and put all files including keydb.cfg in the data directory, and all is now fine, I am ripping Excalibur 4K. Also, next time I will follow the correct process/submission format, apologies. Many thanks!
t1ll1van1ll1
#1785 Post by t1ll1van1ll1 » Thu Feb 12, 2026 8:32 pm
Disc type: UHD
Disc ID: 02C8D87FDCA831654EEE2E20C423C217BD560DBE
Disc dump filename: MKB20_v82_Wicked-_For_Good_6D8E
Drive firmware: Patched (microcode access re-enabled)
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1-PunwJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1wOJhcg ... sp=sharing
i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
