Hello.
I'm using Linux Mint 22.1, have an external 4K Blu-ray UltraHD payer by LG.
I'm trying to Rip MCU's "Hawkeye" season 1.
I'm getting error messages. Specifically....
and (multiple of these illegal request lines."
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:2'
The last 4k disc i tried went off w/o a hitch.
Is there anything I can do, or should I just break down and buy the DVD version too, if it can be found.
Unable to Rip 4K Blu-ray
MrPenguin
Re: Unable to Rip 4K Blu-ray
You need to flash the drive's firmware to make it LibreDrive-compatible. MakeMKV's "Info" window probably says that LibreDrive is currenly disabled.Riker7323 wrote: Wed Feb 11, 2026 3:11 pm LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Can you post the contents of MakeMKV's "Info" window please? You should probably redact your drive's serial number though.
The alternative to using LibreDrive would be to obtain a valid AACSv2 host certificate from AACS-LA. I don't know what you would need to do to achieve this, but I suspect it would include sacrificing your first-born at some point...
science-nerd
What's your makemkv drive info? Don't forget to redact / delete the serial number before posting
Riker7323
OS device name: /dev/sr1
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: xxxxxxxxxxxxxxxxxx
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Revision: 1.02
science-nerd
Seems like you need to flash MK firmware for your drive to unlock 4k UHD rips.
You will need BP60NB10-1.02-MK, in a single flash step, it is encrypted so don't forget the enc flag.
You can follow my guide here to get makemkv v1.17.7 running without touching your original install viewtopic.php?f=3&t=40977
