Odd, I cannot find this disk in KEYDB.cfg, nor any download link for its MKB20_v82_PREDATOR_BADLANDS_A230.tgz file. Can you make this TGZ file available please?Brollan wrote: Wed Feb 11, 2026 10:10 am First post in here about on keydb.
Previous post I missed adding MKB_RO.inf file from disc link...
Disc ID: AB750907B15828027D0D77129071DA6FFD646D91 Disc dump filename: MKB20_v82_PREDATOR_BADLANDS_A230
Public KeyDB Disc Submissions
Thanks for reply, appreciated!
Here is a new link:
edit: link gone
Here is a new link:
edit: link gone
Can you adjust the settings on that file to allow anonymous download please?
Sorry, don't know what you mean? Please advise.
You need to adjust the link settings so everbody is allowed to download.
Maybe free dropbox won't work?
edit:
Disc type: UHD
Disc dump filename: MKB20_v82_Fear_In_The_Night_40A6.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: N/A
Disc dump link: https://we.tl/t-eFLwnPJk3H
Many thanks!
Drive: BD-RE BU40N
Many thanks!
Your MKB_RO.inf file downloaded fine. It'll be a Dropbox setting so that people can download the file without needing to login to Dropbox first.Brollan wrote: Wed Feb 11, 2026 1:43 pmWhere...? In here or at dropbox?
These links seems to work?
MKB-RO
https://www.dropbox.com/scl/fi/ysnqtmc1 ... 7cpci&dl=0
https://www.dropbox.com/scl/fi/p0c6pyrb ... a8il2&dl=0
Thanks, these work fine
Greetings my Predator Badlands key is here.
MKB20_v82_PREDATOR-_BADLANDS_990E.tgz
https://drive.google.com/file/d/1o06xAJ ... sp=sharing
The latest KEYDB.cfg file already has an entry for this disk.
Hi - thanks I followed the KEYDB.cfg instructions - I have unzipped file keydb.cfg saved in:
C:\Users\[my user name]\.MakeMKV
However I still get this following error. Do I need to do something else?
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=E9BA8ECC61EF)
Saved AACS dump file as C:/Program Files (x86)/MakeMKV/MKB20_v82_EXCALIBUR_-_4K_UHD_0994.tgz
