Public KeyDB Disc Submissions
lolipeid47
Disc type: UHD Blu-ray
Disc ID: 0xCC5EB00AE98104A9DE879826DEB8D7CED4782DE5
Disc dump filename: MKB20_v82_THE_WAY_OF_THE_GUN_UHD_A12A.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled + Patched (microcode access re-enabled)
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/VMRE1YzA#IdM1N66TK ... EZ2haz6Vm0
Disc dump link:
https://mega.nz/file/lBxTmKzR#uDNOV2XkO ... LLPWOUgu4M
Disc dump link:
theroninhunter
Hello,MrPenguin wrote: ↑Fri Feb 06, 2026 3:58 pmThis disk has a fully validated entry in the public KEYDB file, so if it doesn't work for you then I suspect you haven't managed to disable bus encryption.theroninhunter wrote: ↑Fri Feb 06, 2026 3:55 pmI can't post this in doom9 has only just registered but I get this error
DiscId >4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED< (2025-06-30)
15:44:25 - Drive is detected as 'REAL BLURAY' drive
15:44:25 - M2TS files found >72<
15:44:41 - Potentially invalid UnitKey >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - Unfortunately no candidate to get a correct unit key >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - There are still 72 files that cannot be decoded with the provided unit keys!
15:44:41 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
15:44:41 - Please report this in the Doom9 forum and attach the logfile!
The logging confirms bus encryption was disabled fine so it's not that.....
theroninhunter
As if by magic it's worked after a reboot
rigormorti@aol.com
Spawn Movie Directors Cut and Theatrical Cut
Directors Cut:
https://drive.google.com/file/d/1EA4Si1 ... sp=sharing
Theatrical Cut:
https://drive.google.com/file/d/1wbQkoi ... sp=sharing
I just downloaded the newest keydb.cfg file and tried with no luck. I figured it would have been added by now but guess not.
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: SPAWN BD
Timestamp: 2025-07-04 13:25:48
Protection: AACS v82
Data capacity: 45.60 Gb
Disc type: BD-ROM
Number of layers: 2
Directors Cut:
Theatrical Cut:
OS device name: E:
Revision: 1.03
Disc Information
Label: SPAWN BD
Disc type: BD-ROM
Number of layers: 2
Disc type: UHD
Disc ID: 6c448d61e1abc102969d0f0d52e3cb5a18ee9cb5
Disc dump filename: MKB20_v77_TOPAZ_609F.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/mcb2tkn0 ... F.tgz/file
Thank you!
Thank you!
Disc type: UHD
Disc ID: bdd928f5d3d84a9902ca80c55587723ca959f67c
Disc dump filename: MKB20_v77_TORN_CURTAIN_D55B.tgz
Disc dump link: https://www.mediafire.com/file/adqedyr9 ... B.tgz/file
Thank you!
Thank you!
keydb_helper
Hey user76419, thanks for taking the time to add the full MKB_RO.inf file from each disc into your originally partial disc dump files. I was going to ask users to do that in the opening post of this thread but I never got around to it.
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_PREDATOR_BADLANDS_AC7E
*MKB20_v82_ALL_THE_PRESIDENTS_MEN_066A
*MKB20_v82_BeautifulMind_UPK75_B4C0
*MKB20_v82_BEN_HUR_1959_PART_1_C2F6
*MKB20_v82_BEN_HUR_1959_PART_2_6290
*MKB20_v82_JackieBrown_D038
*MKB20_v82_Nightcrawler_UHD_3426
*MKB20_v82_THE_WAY_OF_THE_GUN_UHD_A12A
FROM KeyDB Helper:
Disc ID : 0x051345FA08AAA49137B2C748035102B3B2EE5C73
Volume : NUREMBERG
Date : 2025-12-08
Disc Type : Blu-ray
Encryption Keys:
Media Key : 0xC854694C0BA7ED29F7C82497FF76D303
VID : 0xFDB142A9644F8ECD99F1BD86BDA779E0
VUK : 0xAED0472E40BBD6F2694182C8FB8A5DBF
MKB Version : 82
Unit Keys (1):
[1] 0xC5A17047218FBADF201725243A8D68FC
KeyDB Status:
Status : not found
Disc dump filename: MKB_v82_NUREMBERG_F6B2.tgz
LibreDrive status: Active
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/open?id=1CqKfK ... p=drive_fs (tested)
Disc dump filename: https://drive.google.com/open?id=1nognw ... p=drive_fs (tested)
Volume : NUREMBERG
Date : 2025-12-08
Disc Type : Blu-ray
Encryption Keys:
MKB Version : 82
Unit Keys (1):
KeyDB Status:
Status : not found
Can you adjust the "Share" option on that file please, so that people can download it?
wanderingeye01
Another copy of the Dirty Work Vinegar Syndrome 4K. The one in the KeyDB is dated "2025-04-18" where as this one is dated "2025-04-17."
https://drive.google.com/file/d/1enltc_ ... sp=sharing
Carnal Knowledge 4k (Criterion, 2nd printing to fix error):
https://drive.google.com/file/d/1LIiPJk ... sp=sharing
mrrelational
Disc type: BD_ROM
Disc ID: 0x4179A1A0B08EE97BC6AB1927B7F349983413B063
Disc dump filename: MKB_v82_Jurassic_World_Rebirth_7962
Drive: BP50NB40
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? No
MKB_RO.inf link: https://drive.google.com/file/d/1wwui7k ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1qcRNn7 ... sp=sharing
Finally got KEYDB_Helper working and between this post and now, a Synchronize updated the key, so I am now able to rip. I apologize if I inconvenienced anyone. This is my first time.
Drive: BP50NB40
jonaspoehler
Disc type: UHD
Disc ID: 0x5234c2d73f7769133c6eb54495d8253bae7b955e
Disc dump filename: MKB20_v76_THE_GODFATHER,_PART_II_9041
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1iSpJcn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1zFge2u ... sp=sharing
Thank you!
Drive: BD-RE BU40N
Thank you!
Unfortunately your UHD drive has failed to enable LibreDrive, which makes your TGZ dump file unusablejonaspoehler wrote: ↑Mon Feb 09, 2026 9:51 pmDisc type: UHD
Drive: BD-RE BU40N
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
DEBUG: Code 0 at ?>@=1r\!W?_}[zdZ6:213130306
DEBUG: Code 0 at oH+-D*FQAz1#bPXt1=:121264395
DEBUG: Code 4 at oH+-D*FQAz1#bPXt1=:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
