Public KeyDB Disc Submissions
lolipeid47
#1741 Post by lolipeid47 » Fri Feb 06, 2026 5:24 pm
Disc type: UHD Blu-ray
Disc ID: 0xCC5EB00AE98104A9DE879826DEB8D7CED4782DE5
Disc dump filename: MKB20_v82_THE_WAY_OF_THE_GUN_UHD_A12A.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enabled + Patched (microcode access re-enabled)
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/VMRE1YzA#IdM1N66TK ... EZ2haz6Vm0
Disc dump link:
https://mega.nz/file/lBxTmKzR#uDNOV2XkO ... LLPWOUgu4M
theroninhunter
#1742 Post by theroninhunter » Fri Feb 06, 2026 6:03 pm
MrPenguin wrote: Fri Feb 06, 2026 3:58 pm
theroninhunter wrote: Fri Feb 06, 2026 3:55 pm I can't post this in doom9 has only just registered but I get this error
DiscId >4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED< (2025-06-30)
15:44:25 - Drive is detected as 'REAL BLURAY' drive
15:44:25 - M2TS files found >72<
15:44:41 - Potentially invalid UnitKey >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - Unfortunately no candidate to get a correct unit key >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - There are still 72 files that cannot be decoded with the provided unit keys!
15:44:41 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
15:44:41 - Please report this in the Doom9 forum and attach the logfile!
This disk has a fully validated entry in the public KEYDB file, so if it doesn't work for you then I suspect you haven't managed to disable bus encryption.
The logging confirms bus encryption was disabled fine so it's not that.....
theroninhunter
#1743 Post by theroninhunter » Fri Feb 06, 2026 6:27 pm
As if by magic it's worked after a reboot
rigormorti@aol.com
#1744 Post by rigormorti@aol.com » Fri Feb 06, 2026 11:02 pm
Spawn Movie Directors Cut and Theatrical Cut
Directors Cut:
https://drive.google.com/file/d/1EA4Si1 ... sp=sharing
Theatrical Cut:
https://drive.google.com/file/d/1wbQkoi ... sp=sharing
I just downloaded the newest keydb.cfg file and tried with no luck. I figured it would have been added by now but guess not.
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: SPAWN BD
Timestamp: 2025-07-04 13:25:48
Protection: AACS v82
Data capacity: 45.60 Gb
Disc type: BD-ROM
Number of layers: 2
user76419
#1745 Post by user76419 » Sat Feb 07, 2026 2:27 am
Disc type: UHD
Disc ID: 6c448d61e1abc102969d0f0d52e3cb5a18ee9cb5
Disc dump filename: MKB20_v77_TOPAZ_609F.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/mcb2tkn0 ... F.tgz/file
Thank you!
user76419
#1746 Post by user76419 » Sat Feb 07, 2026 2:28 am
Disc type: UHD
Disc ID: bdd928f5d3d84a9902ca80c55587723ca959f67c
Disc dump filename: MKB20_v77_TORN_CURTAIN_D55B.tgz
Disc dump link: https://www.mediafire.com/file/adqedyr9 ... B.tgz/file
Thank you!
keydb_helper
#1747 Post by keydb_helper » Sat Feb 07, 2026 5:39 am
user76419 wrote: Sat Feb 07, 2026 2:27 am MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
user76419 wrote: Sat Feb 07, 2026 2:28 am MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Hey user76419, thanks for taking the time to add the full MKB_RO.inf file from each disc into your originally partial disc dump files. I was going to ask users to do that in the opening post of this thread but I never got around to it.
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_PREDATOR_BADLANDS_AC7E
*MKB20_v82_ALL_THE_PRESIDENTS_MEN_066A
*MKB20_v82_BeautifulMind_UPK75_B4C0
*MKB20_v82_BEN_HUR_1959_PART_1_C2F6
*MKB20_v82_BEN_HUR_1959_PART_2_6290
*MKB20_v82_JackieBrown_D038
*MKB20_v82_Nightcrawler_UHD_3426
*MKB20_v82_THE_WAY_OF_THE_GUN_UHD_A12A
vonMalm
#1748 Post by vonMalm » Sat Feb 07, 2026 5:39 pm
FROM KeyDB Helper:
Disc ID : 0x051345FA08AAA49137B2C748035102B3B2EE5C73
Volume : NUREMBERG
Date : 2025-12-08
Disc Type : Blu-ray
Encryption Keys:
Media Key : 0xC854694C0BA7ED29F7C82497FF76D303
VID : 0xFDB142A9644F8ECD99F1BD86BDA779E0
VUK : 0xAED0472E40BBD6F2694182C8FB8A5DBF
MKB Version : 82
Unit Keys (1):
[1] 0xC5A17047218FBADF201725243A8D68FC
KeyDB Status:
Status : not found
Disc dump filename: MKB_v82_NUREMBERG_F6B2.tgz
LibreDrive status: Active
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/open?id=1CqKfK ... p=drive_fs (tested)
Disc dump filename: https://drive.google.com/open?id=1nognw ... p=drive_fs (tested)
MrPenguin
#1749 Post by MrPenguin » Sat Feb 07, 2026 6:08 pm
vonMalm wrote: Sat Feb 07, 2026 5:39 pm Disc dump filename: MKB_v82_NUREMBERG_F6B2.tgz
Can you adjust the "Share" option on that file please, so that people can download it?
wanderingeye01
#1750 Post by wanderingeye01 » Sun Feb 08, 2026 2:02 am
Another copy of the Dirty Work Vinegar Syndrome 4K. The one in the KeyDB is dated "2025-04-18" where as this one is dated "2025-04-17."
https://drive.google.com/file/d/1enltc_ ... sp=sharing
vonMalm
#1751 Post by vonMalm » Sun Feb 08, 2026 10:06 am
MrPenguin wrote: Sat Feb 07, 2026 6:08 pm
I'm sorry... I guess I forgot to set it to "everyone". Can you try again now?
kbwyrick
#1752 Post by kbwyrick » Mon Feb 09, 2026 8:59 pm
Carnal Knowledge 4k (Criterion, 2nd printing to fix error):
https://drive.google.com/file/d/1LIiPJk ... sp=sharing
mrrelational
#1753 Post by mrrelational » Mon Feb 09, 2026 9:10 pm
Disc type: BD_ROM
Disc ID: 0x4179A1A0B08EE97BC6AB1927B7F349983413B063
Disc dump filename: MKB_v82_Jurassic_World_Rebirth_7962
Drive: BP50NB40
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes? No
MKB_RO.inf link: https://drive.google.com/file/d/1wwui7k ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1qcRNn7 ... sp=sharing
Finally got KEYDB_Helper working and between this post and now, a Synchronize updated the key, so I am now able to rip. I apologize if I inconvenienced anyone. This is my first time.
jonaspoehler
#1754 Post by jonaspoehler » Mon Feb 09, 2026 9:51 pm
Disc type: UHD
Disc ID: 0x5234c2d73f7769133c6eb54495d8253bae7b955e
Disc dump filename: MKB20_v76_THE_GODFATHER,_PART_II_9041
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1iSpJcn ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1zFge2u ... sp=sharing
Thank you!
MrPenguin
#1755 Post by MrPenguin » Tue Feb 10, 2026 12:50 am
jonaspoehler wrote: Mon Feb 09, 2026 9:51 pm Disc type: UHD
Drive: BD-RE BU40N
Unfortunately your UHD drive has failed to enable LibreDrive, which makes your TGZ dump file unusable :(:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
DEBUG: Code 0 at ?>@=1r\!W?_}[zdZ6:213130306
DEBUG: Code 0 at oH+-D*FQAz1#bPXt1=:121264395
DEBUG: Code 4 at oH+-D*FQAz1#bPXt1=:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Try re-plugging your USB drive or cold-booting your PC, and then trying to rip your disk again.
