Hello,MrPenguin wrote: Fri Feb 06, 2026 3:58 pmThis disk has a fully validated entry in the public KEYDB file, so if it doesn't work for you then I suspect you haven't managed to disable bus encryption.theroninhunter wrote: Fri Feb 06, 2026 3:55 pm I can't post this in doom9 has only just registered but I get this error
DiscId >4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED< (2025-06-30)
15:44:25 - Drive is detected as 'REAL BLURAY' drive
15:44:25 - M2TS files found >72<
15:44:41 - Potentially invalid UnitKey >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - Unfortunately no candidate to get a correct unit key >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - There are still 72 files that cannot be decoded with the provided unit keys!
15:44:41 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
15:44:41 - Please report this in the Doom9 forum and attach the logfile!
The logging confirms bus encryption was disabled fine so it's not that.....
