keydb_helper
Post
by keydb_helper » Thu Feb 05, 2026 5:53 am
Toad King wrote: Wed Feb 04, 2026 8:46 pm
Disc ID: 8A93CE7B7F396157ACB69A3A15EBCDAA6E5C1170
Disc dump filename: MKB20_v82_The_Big_Heat_4F0E
Hey Toad King, thanks for the new disc dump file. Your disc has been added to the public keydb along with these two discs:
MKB20_v77_Sisu-_Road_to_Revenge_5B7A
MKB20_v82_BananaJoe_DF34
Rico1977
Post
by Rico1977 » Thu Feb 05, 2026 2:31 pm
Hello.
I have a new one here.
Disc type: UHD
Disc ID: e9fc07db802fa451359d1921e73a8b0b107a510a
Disc dump filename: MKB20_v82_Nuremberg_UHD_5506
Drive: BW-16D1HT
Drive firmware: 3.10
LibreDrive status: Enable
MKB_RO.inf link:
https://drive.google.com/file/d/14A2fnR ... sp=sharing
Disc dump link:
https://drive.google.com/file/d/10sh00p ... sp=sharing
Thank you!!!
MrPenguin
Post
by MrPenguin » Thu Feb 05, 2026 2:35 pm
Rico1977 wrote: Thu Feb 05, 2026 2:31 pm
Can you adjust the "Share" option on those files please, so that people can access them? Specifically, the TGZ dump file.
Brentopc
Post
by Brentopc » Thu Feb 05, 2026 4:04 pm
Disc type: UHD Blu-ray
Disc ID: 0x936DF345E911AF23F0BEE5A369D0C5896D0BA63A
Disc dump filename: MKB20_v77_Five_Nights_at_Freddy's_246F
Drive: BD-RE BW-16D1HT
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
https://drive.google.com/file/d/1GFiBGH ... sp=sharing
Disc dump link:
https://drive.google.com/file/d/14j0xa4 ... sp=sharing
Rico1977
Post
by Rico1977 » Thu Feb 05, 2026 6:09 pm
MrPenguin wrote: Thu Feb 05, 2026 2:35 pm
I’ve fixed the link now. My mistake — I did it under a bit of stress.
Thank you
snowsneakers
Post
by snowsneakers » Thu Feb 05, 2026 6:54 pm
Disc type: UHD
Disc ID: 1f4c34303d8a1d82c10656247c9bc3ffd4689c74
Disc dump filename: MKB20_v68_Fifty_Shades_Freed_B4A6
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: n/a
Disc dump link:
https://drive.google.com/file/d/1GhGrHd ... sp=sharing
Let me know if I need to update anything. It's my first time posting. I appreciate it!
Zwiebelritter
Post
by Zwiebelritter » Thu Feb 05, 2026 9:08 pm
Hello, this ist my first post here. Here is the link for the dumb file (The Thicket - German Blu-ray Version):
https://app.filemail.com/d/tkjhdytbyrttlzg
I hope this is the correct procedure. Thanks.
theroninhunter
Post
by theroninhunter » Fri Feb 06, 2026 1:36 pm
Disc Type: UHD
Disc ID: 0x4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED
Dump name: MKB20_v82_The_Last_of_Us_Season_2_Disc_3_FCE5
Drive: BD-RW BDR-XS07U
Drive Revision: 1.02
Drive Firmware: 1.02/ID05
Disc Dump:
https://drive.proton.me/urls/KKR875SEJ0#2sVvdnv6ivXs
MKB:
https://drive.proton.me/urls/S2M7M8YXCR#9VWZ7gAoQnha
keydb_helper
Post
by keydb_helper » Fri Feb 06, 2026 2:26 pm
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v60_YOUR_NAME_3F1D
*MKB20_v68_Fifty_Shades_Freed_B4A6
*MKB20_v82_Eddington_9AF4
MKB20_v82_F1_B7A7
*MKB20_v82_Nuremberg_UHD_5506
*MKB20_v82_PROJECT_AKO_UHD
theroninhunter
Post
by theroninhunter » Fri Feb 06, 2026 3:55 pm
I can't post this in doom9 has only just registered but I get this error
DiscId >4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED< (2025-06-30)
15:44:25 - Drive is detected as 'REAL BLURAY' drive
15:44:25 - M2TS files found >72<
15:44:41 - Potentially invalid UnitKey >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - Unfortunately no candidate to get a correct unit key >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - There are still 72 files that cannot be decoded with the provided unit keys!
15:44:41 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
15:44:41 - Please report this in the Doom9 forum and attach the logfile!
MrPenguin
Post
by MrPenguin » Fri Feb 06, 2026 3:58 pm
theroninhunter wrote: Fri Feb 06, 2026 3:55 pm
This disk has a fully validated entry in the public KEYDB file, so if it doesn't work for you then I suspect you haven't managed to disable bus encryption.
lolipeid47
Post
by lolipeid47 » Fri Feb 06, 2026 5:24 pm
Disc ID: 0xCC5EB00AE98104A9DE879826DEB8D7CED4782DE5
Disc dump filename: MKB20_v82_THE_WAY_OF_THE_GUN_UHD_A12A.tgz
Drive: ASUS BW-16D1HT
LibreDrive status: Enabled + Patched (microcode access re-enabled)
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/VMRE1YzA#IdM1N66TK ... EZ2haz6Vm0
Disc dump link:
https://mega.nz/file/lBxTmKzR#uDNOV2XkO ... LLPWOUgu4M
theroninhunter
Post
by theroninhunter » Fri Feb 06, 2026 6:03 pm
MrPenguin wrote: Fri Feb 06, 2026 3:58 pm
The logging confirms bus encryption was disabled fine so it's not that.....
theroninhunter
Post
by theroninhunter » Fri Feb 06, 2026 6:27 pm
As if by magic it's worked after a reboot
rigormorti@aol.com
Post
by rigormorti@aol.com » Fri Feb 06, 2026 11:02 pm
Spawn Movie Directors Cut and Theatrical Cut
Directors Cut:
https://drive.google.com/file/d/1EA4Si1 ... sp=sharing
Theatrical Cut:
https://drive.google.com/file/d/1wbQkoi ... sp=sharing
I just downloaded the newest keydb.cfg file and tried with no luck. I figured it would have been added by now but guess not.
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: SPAWN BD
Timestamp: 2025-07-04 13:25:48
Protection: AACS v82
Data capacity: 45.60 Gb
Disc type: BD-ROM
Number of layers: 2
