Public KeyDB Disc Submissions
FrankGrimes2769
Post by FrankGrimes2769 » Wed Feb 04, 2026 12:29 am
Wonder Woman (2017)
Disc type: UHD
Disc ID: 45eaf5100bea5b4c1afda14d4e061e38e4480bcb
Disc dump filename: MKB20_v61_Wonder_Woman_DC39.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1QKVWsU ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kc79ij ... sp=sharing
Thank you! I appreciate the support!
Simply Wow! Thanks for the real quick support. All is good now.
keydb_helper
Post by keydb_helper » Wed Feb 04, 2026 1:49 am
FrankGrimes2769 wrote:
Sun Feb 01, 2026 1:58 pm
Disc ID: 1cd2c6a6cc2384b045070c86062e1372bce14c8c
Disc dump filename: MKB20_v76_Spider-Man-_No_Way_Home_43C5
Sun Feb 01, 2026 11:22 pm
Disc ID: ce08ba5c6731a4d4da6697ad7d20b3f429aa3bb7
Disc dump filename: MKB20_v76_Thor-_Love_and_Thunder_9407.tgz
Hey Grimey, great to hear that you've been able to backup your discs.
As a Windows user, you also have the option of using SamuriHL's KeyDB Helper tool (Link). For all three of your most recent submissions the KeyDB Helper tool would've generated and submitted the complete keydb entry as the disc media keys were already known to the keydb. This means you wouldn't have needed to post to this thread or wait for the submissions to be processed.
Newer discs will generally require posting to this thread but I do recommend running SamuriHL's KeyDB Helper tool beforehand just in case.
FrankGrimes2769
Post by FrankGrimes2769 » Wed Feb 04, 2026 2:56 am
Holy Moly you learn something new every day. I will always do this first going forward for absolute sure. I always appreciate things that make life simpler. Thanks!!!
Toad King
Post by Toad King » Wed Feb 04, 2026 8:46 pm
Disc type: UHD
Disc ID: 8A93CE7B7F396157ACB69A3A15EBCDAA6E5C1170
Disc dump filename: MKB20_v82_The_Big_Heat_4F0E
Drive: BD-RW BDR-S13JX
Drive firmware: 1.03/ID72
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/file/d/1yWlFZY ... 70goI/view
keydb_helper
Post by keydb_helper » Thu Feb 05, 2026 5:53 am
Hey Toad King, thanks for the new disc dump file. Your disc has been added to the public keydb along with these two discs:
MKB20_v77_Sisu-_Road_to_Revenge_5B7A
MKB20_v82_BananaJoe_DF34
Rico1977
Post by Rico1977 » Thu Feb 05, 2026 2:31 pm
Hello.
I have a new one here.
Disc type: UHD
Disc ID: e9fc07db802fa451359d1921e73a8b0b107a510a
Disc dump filename: MKB20_v82_Nuremberg_UHD_5506
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/14A2fnR ... sp=sharing
Disc dump link: https://drive.google.com/file/d/10sh00p ... sp=sharing
Thank you!!!
MrPenguin
Post by MrPenguin » Thu Feb 05, 2026 2:35 pm
Can you adjust the "Share" option on those files please, so that people can access them? Specifically, the TGZ dump file.
Brentopc
Post by Brentopc » Thu Feb 05, 2026 4:04 pm
Disc type: UHD Blu-ray
Disc ID: 0x936DF345E911AF23F0BEE5A369D0C5896D0BA63A
Disc dump filename: MKB20_v77_Five_Nights_at_Freddy's_246F
Drive: BD-RE BW-16D1HT
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1GFiBGH ... sp=sharing
Disc dump link: https://drive.google.com/file/d/14j0xa4 ... sp=sharing
Rico1977
Post by Rico1977 » Thu Feb 05, 2026 6:09 pm
I’ve fixed the link now. My mistake — I did it under a bit of stress.
Thank you :)
snowsneakers
Post by snowsneakers » Thu Feb 05, 2026 6:54 pm
Disc type: UHD
Disc ID: 1f4c34303d8a1d82c10656247c9bc3ffd4689c74
Disc dump filename: MKB20_v68_Fifty_Shades_Freed_B4A6
Drive: BD-RE BU40N
MKB_RO.inf link: n/a
Disc dump link: https://drive.google.com/file/d/1GhGrHd ... sp=sharing
Let me know if I need to update anything. It's my first time posting. I appreciate it!
Zwiebelritter
Post by Zwiebelritter » Thu Feb 05, 2026 9:08 pm
Hello, this ist my first post here. Here is the link for the dumb file (The Thicket - German Blu-ray Version):
https://app.filemail.com/d/tkjhdytbyrttlzg
I hope this is the correct procedure. Thanks.
theroninhunter
Post by theroninhunter » Fri Feb 06, 2026 1:36 pm
Disc Type: UHD
Disc ID: 0x4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED
Dump name: MKB20_v82_The_Last_of_Us_Season_2_Disc_3_FCE5
Drive: BD-RW BDR-XS07U
Drive Revision: 1.02
Drive Firmware: 1.02/ID05
Disc Dump: https://drive.proton.me/urls/KKR875SEJ0#2sVvdnv6ivXs
MKB: https://drive.proton.me/urls/S2M7M8YXCR#9VWZ7gAoQnha
keydb_helper
Post by keydb_helper » Fri Feb 06, 2026 2:26 pm
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v60_YOUR_NAME_3F1D
*MKB20_v68_Fifty_Shades_Freed_B4A6
*MKB20_v82_Eddington_9AF4
MKB20_v82_F1_B7A7
*MKB20_v82_Nuremberg_UHD_5506
*MKB20_v82_PROJECT_AKO_UHD
theroninhunter
Post by theroninhunter » Fri Feb 06, 2026 3:55 pm
I can't post this in doom9 has only just registered but I get this error
DiscId >4E29A1C0E15B56D83EE0AA91FFD0AB34404D76ED< (2025-06-30)
15:44:25 - Drive is detected as 'REAL BLURAY' drive
15:44:25 - M2TS files found >72<
15:44:41 - Potentially invalid UnitKey >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - Unfortunately no candidate to get a correct unit key >FADF95BCCC211969D338ECCAE5CD7D8E<
15:44:41 - There are still 72 files that cannot be decoded with the provided unit keys!
15:44:41 - Validation failed - VUK/UnitKeys are INVALID!!!!!!!
15:44:41 - Please report this in the Doom9 forum and attach the logfile!
MrPenguin
Post by MrPenguin » Fri Feb 06, 2026 3:58 pm
This disk has a fully validated entry in the public KEYDB file, so if it doesn't work for you then I suspect you haven't managed to disable bus encryption.
