DOGMA 4k
brown1480
DOGMA 4k
Post by brown1480 »
received a cannot open disc dump
Debug log started at Wed Feb 04 03:46:20 2026 , written by MakeMKV v1.18.3 win(x64-release)
001005:0000 MakeMKV v1.18.3 win(x64-release) started
No SDF v0a5: HL-DT-ST_DVD+-RW_GU90N_A1C3_20191125161200_M1MK1UF5827
DEBUG: Code 3 at tNjYHe^Zv]scO1k:ka77Z}$W:29395310
SDF id v0a5: HL-DT-ST_DVD+-RW_GU90N_A1C3_20191125161200_M1MK1UF5827
SDF v0a5: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLAP2AB5550
001011:0000 Using LibreDrive mode (v06.3 id=7FA2657C7667)
DEBUG: Code 2147483648 at 3FirBS;l\AtCiaA}:121265499
003332:0000 Saved AACS dump file as file://C:\Users\jrbpi/.MakeMKV/MKB20_v82_Dogma_41F1.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
DEBUG: Code 0 at [~^tn^s^5yv"y#^.:213132721
DEBUG: Code 0 at [~^tn^s^5yv"y#^.:213131341
MrPenguin
Re: DOGMA 4k
Post by MrPenguin »
brown1480 wrote: Wed Feb 04, 2026 3:49 am 003332:0000 Saved AACS dump file as file://C:\Users\jrbpi/.MakeMKV/MKB20_v82_Dogma_41F1.tgz
You need to email this TGZ dump file to svq@makemkv.com. And could you also upload it into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
Have you also tried using SamuriHL's KEYDB Helper Utility?
