Dump Submitted: The Matrix Movies and WALL - E 4K UHD
Cremsyn
#1 Post by Cremsyn » Tue Feb 03, 2026 1:39 am
Please see the TGZ files in the Google drive link below.
https://drive.google.com/drive/folders/ ... aiZC00zgIq
Below is my drive information:
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO8P55H1003
Highest AACS version: 72
Firmware version: 1.03
If someone could add these, it would be greatly appreciated! Let me know if anything else is needed.
MrPenguin
Re: Dump Submitted: The Matrix Movies and WALL - E 4K UHD
#2 Post by MrPenguin » Tue Feb 03, 2026 11:04 am
Cremsyn wrote: Tue Feb 03, 2026 1:39 am Please see the TGZ files in the Google drive link below.
Unfortunately, none of your TGZ dump files was created with LibreDrive enabled :(:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 2U{2<P"^ib0vfW}i5:213130306
DEBUG: Code 0 at ek0A`ekmmj7(oPSno;:121264395
DEBUG: Code 4 at ek0A`ekmmj7(oPSno;:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
This is almost certainly why MakeMKV cannot decrypt your disks. However, the latest KEYDB.cfg field does already contain entries for the following:
  • WALL-E
  • The Matrix
  • Matrix Revolutions
Try cold-booting your UHD drive, to see if MakeMKV can enable LibreDrive properly.
Can you also upload the full MKB_RO.inf file from your physical UHD "The Matrix Reloaded" disk into Google Drive please, because the copy of this file inside your TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. KEYDB would also need a replacement discatt.dat file for this disk in order to generate an entry for it.
Edit: Have you tried using SamuriHL's KEYDB Helper Utility?
Cremsyn
#3 Post by Cremsyn » Wed Feb 04, 2026 4:53 am
Thank you for your reply. I uploaded the extracted folders from the tgz files into the Google Drive folder so all the files are there. I tried cold booting my drive (turned off my pc, unplugged it, waited a minute or so, then turned it back on). However, when I go into the makemkv application and try to open the disc, I get errors like this in the log:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 2U{2<P"^ib0vfW}i5:213130766
DEBUG: Code 0 at ek0A`ekmmj7(oPSno;:213131709
I just don't understand why makemkv believes my drive is "LibreDrive enabled" but it says "LibreDrive compatible drive is required to open this disc - video can't be decrypted."
Google Drive folder: https://drive.google.com/drive/folders/ ... aiZC00zgIq
I'm not too familiar with SamuriHL's KEYDB Helper Utility. I downloaded the tool and extracted the disc info for The Matrix 4K UHD disc. Below is the info:
======================================================= DISC INFORMATION ======================================================= Validation Data : A926A1FD98F84CC736A29988ED255975 Media Key : 9BADF1ABD6D98B26798B51BE4597E6C4 VUK : CB6AE17AFB72D07D4C30476A5E5A7481 Unit Key 1 : 97FEB58D18105550716E73B307D99246 Unit Key validation failed with 3 aligned units ------------------------------------------------------- ------------------------------------------------------- --- Disc Information --- Disc ID : 0xF3083ADDA94CAD0B83CE6DCBEBFA8C271AFD9DB2 Volume : THE_MATRIX Title : The Matrix Date : 2018-03-22 Disc Type : UHD Blu-ray Encryption Keys: Media Key : 0x9BADF1ABD6D98B26798B51BE4597E6C4 VID : 0x1F60AFFDB3E9B107E3D39136A0142804 VUK : 0xCB6AE17AFB72D07D4C30476A5E5A7481 MKB Version : 61 Unit Keys (1): [1] 0x97FEB58D18105550716E73B307D99246 KeyDB Status: Database : (VALIDATED) Status : complete
I'm not sure if this is helpful. Let me know if I should try something else.
MrPenguin
#4 Post by MrPenguin » Wed Feb 04, 2026 2:51 pm
Cremsyn wrote: Wed Feb 04, 2026 4:53 am Thank you for your reply. I uploaded the extracted folders from the tgz files into the Google Drive folder so all the files are there.
Thanks, but unfortunately that doesn't help because we already had all those files from the original TGZ dumps. What we actually need are the MKB_RO.inf files directly from the physical UHD disks, and for the precise reason that they contain information not in the TGZ dumps.
Cremsyn wrote: Wed Feb 04, 2026 4:53 am I'm not too familiar with SamuriHL's KEYDB Helper Utility. I downloaded the tool and extracted the disc info for The Matrix 4K UHD disc. Below is the info:
 DISC INFORMATION
  Volume : THE_MATRIX
  Title : The Matrix
  Date : 2018-03-22
  Disc Type : UHD
  MKB Version : 61
  Status : complete
That looks OK. Can you examine your "The Matrix Reloaded" disk using SamuriHL's utility please, and try uploading/validating it? (You'll need to get LibreDrive enabled properly first.)
Cremsyn
#5 Post by Cremsyn » Wed Feb 04, 2026 10:45 pm
I uploaded all the MKB_RO.inf files to my Google drive folder.
https://drive.google.com/drive/folders/ ... Lm5YO0E43k
I also validated the Matrix Reloaded UHD disc:
DISC VALIDATION
16:37:48 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
16:37:48 - MODE: ValidateDisc
16:37:48 - DriveLetter : D
16:37:48 - SettingsFile: >C:\Users\rkelt\OneDrive\Desktop\FindVUK\config\FindVUK.ini<
16:37:48 - Logfile >C:\Users\rkelt\OneDrive\Desktop\FindVUK\log\2026-02-04_FindVUK.txt< Default Loglevel >2<
16:37:48 - Update enabled - check for update
16:37:49 - No update required
16:37:49 - Open Main-KEYDB file: >C:\Users\rkelt\AppData\Roaming\aacs\KEYDB.cfg<
16:37:51 - Open Backup-KEYDB file: >C:\Users\rkelt\OneDrive\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
16:37:51 - Get basic AACS data
16:37:51 - AACS folder on disc is reachable - Validate is possible
16:38:01 - VolumeName >THE MATRIX RELOADED<
16:38:01 - DiscId >B2F122AFABE820364BEA114694C7A6B6CEB31469< (2018-08-17)
16:38:01 - DiscType >UHD<
16:38:01 - MKB Revision >65<
16:38:01 - Disc-BusEncEnabled >1<
16:38:01 - Drve-BusEncCapable >1<
16:38:01 - ==> Bus Encryption active!
16:38:01 - UnitKeyCount >1<
16:38:01 - >>> UnitKeyENC (1) >4CF84D27223325E634BEC50F6FE3A6B6<
16:38:01 - No entry for discid >B2F122AFABE820364BEA114694C7A6B6CEB31469< available in keydb >C:\Users\rkelt\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
16:38:01 - Eject the disc now from drive >D:\<
Please let me know if I need to provide anything else for these discs. Also, can you let me know how I can get my LibreDrive enabled properly? I just recently purchased my drive and I didn't even attempt to rip any discs until after I flashed the firmware. I even pulled the drive out of the enclosure it came in and attached it to my PC via sata because the enclosure was blocking the firmware flashing connection and SDF toolflasher wouldn't flash until I did this.
Again, my drive info is:
Revision: 1.03
MrPenguin
#6 Post by MrPenguin » Wed Feb 04, 2026 11:13 pm
Cremsyn wrote: Wed Feb 04, 2026 10:45 pm I uploaded all the MKB_RO.inf files to my Google drive folder.
Thanks for these :).
Cremsyn wrote: Wed Feb 04, 2026 10:45 pm I also validated the Matrix Reloaded UHD disc:
DISC VALIDATION
OK, so validation has failed because there wasn't already an entry in KEYDB to check against your disk :(. With any luck, this might change now that you've provided the disk's complete MKB_RO.inf file. However, you will also need to disable bus encryption in order to validate your disk, and that means getting your drive to enable LibreDrive.
I don't know why MakeMKV is saying that LD is enabled while clearly not enabling LD! A cold reboot normally fixes problems like this, but maybe there's a timing issue here too? Perhaps try waiting until your disk appears in Windows Explorer before launching MakeMKV?
