All Pioneer drives will be LibreDrive supported
kikkoman
Re: All Pioneer drives will be LibreDrive supported
Post by kikkoman » Thu Jan 01, 2026 8:29 pm
Hi ya'll.
So I'm new to this, just bought Pioneer BDR-XD08B with drive details below.
If it says LibreDrive enabled, does this mean I can start ripping 4K UHD discs? Or do I still need a separate firmware for my drive to do so.
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Firmware date: 2022-12-27
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
Post by MartyMcNuts » Thu Jan 01, 2026 9:38 pm
kikkoman wrote: Thu Jan 01, 2026 8:29 pm Hi ya'll.
Revision: 1.02
This drive can't read 4K UHD discs as it is not a UHD model. It can't currently be cross-flashed with the available tools as the firmware is post 11/2022. Having libredrive enabled for standard blu-ray is the best this drive can get for now.
It may be possible in the future to cross-flash so check the forum every now and then for updates.
MrPenguin
Post by MrPenguin » Thu Jan 01, 2026 10:21 pm
MartyMcNuts wrote: Thu Jan 01, 2026 9:38 pm This drive can't read 4K UHD discs as it is not a UHD model. It can't currently be cross-flashed with the available tools as the firmware is post 11/2022. Having libredrive enabled for standard blu-ray is the best this drive can get for now.
Definitely still hang on to it though, because it's still a good drive. And I'm sure Mike is working on the problem too.
kikkoman
Post by kikkoman » Fri Jan 02, 2026 12:25 am
MrPenguin wrote: Thu Jan 01, 2026 10:21 pm
crap...that's what I get for buying without checking forums first. bought back during Black Friday but was still expensive.
good to know though thanks.
lomatrasu
Post by lomatrasu » Thu Jan 22, 2026 6:12 pm
Hi All,
this is my current drive info
OS device name: /dev/rdisk4
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 26
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID43
what are my best options?
can I do 4K UHD by downgrading firmware or is LibreDrive with Standard 4K my best case scenario?
Post by MartyMcNuts » Thu Jan 22, 2026 10:03 pm
lomatrasu wrote: Thu Jan 22, 2026 6:12 pm Hi All,
Revision: 1.05
Serial number:
Nothing needs to be done. It is already ready to go. Just insert a UHD disc and rip it.
Szary Kot
Post by Szary Kot » Sun Feb 01, 2026 9:32 pm
Will there be a chance in the near future to unlock BDXL drives, e.g. Pioneer BDR X13JBK, to read UHD formats? Is there anything more known yet?
Licensed User MakeMKV
Post by Coopervid » Sun Feb 01, 2026 9:55 pm
Szary Kot wrote: Sun Feb 01, 2026 9:32 pm Will there be a chance in the near future to unlock BDXL drives, e.g. Pioneer BDR X13JBK, to read UHD formats? Is there anything more known yet?
Post your Makemkv info. If pre Dec. 2022 there is a chance.
Szary Kot
Post by Szary Kot » Sun Feb 01, 2026 10:21 pm
I have the opportunity to purchase it. The firmware is 100% newer than 12-2022. I don't know what to do, hence my question.
Post by MartyMcNuts » Sun Feb 01, 2026 10:31 pm
Szary Kot wrote: Sun Feb 01, 2026 10:21 pm I have the opportunity to purchase it. The firmware is 100% newer than 12-2022. I don't know what to do, hence my question.
Depending on the price, is probably worth the risk anyway, even if it can never be made to read UHD as it'd be a good blu-ray ripper regardless and near impossible to find.
