Public KeyDB Disc Submissions
marius_m24
Disc type: UHD
Disc ID: 0x3107C2E7A9E653308559C7ED8E261D9702F4C5F4
Disc dump filename: MKB20_v77_The_Sound_of_Music_BCE8
Drive: BW-16D1HT
Drive firmware: 3.10MK
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1zjeYIP ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1qqfEbK ... sp=sharing
Drive: BW-16D1HT
daofail
Disc type: UHD
Disc ID: 0x57E80E5F9439C00A50BCD8AFFB49AEF8AE22331B
Disc dump filename: MKB20_v61_MARVELS_THE_AVENGERS_6769.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02 / Patched
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/Qlrm6hgDxZrA
Disc dump link: https://transfer.it/t/Qlrm6hgDxZrA
Disc type: UHD
Disc ID: 0xAC045F539FC0858EE2536B4E1FC201F72DA23FC5
Disc dump filename: MKB20_v68_IRON_MAN_3_8DAF.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/edKLatglwRxY
Disc dump link: https://transfer.it/t/edKLatglwRxY
Disc type: UHD
Disc ID: 0xC229C4E3CD2B2638CA25AD1573140258C948B865
Disc dump filename: MKB20_v66_CAPTAIN_AMERICA_FIRST_AVENGER_EFFB.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/65Ju5E1j3LKQ
Disc dump link: https://transfer.it/t/65Ju5E1j3LKQ
Disc type: UHD
Disc ID: 0xEAE12FC6B88187C7B077F5E6B7C65907C0614ECA
Disc dump filename: MKB20_v68_THOR_9741.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/gqSc5c0RWDIB
Disc dump link: https://transfer.it/t/gqSc5c0RWDIB
Disc type: UHD
Disc ID: 0x1458AC358C7FB54CCAD1628A4F0CC62549C52628
Disc dump filename: MKB20_v68_IRON_MAN_BFA1.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/jQCX0N9HlDiZ
Disc dump link: https://transfer.it/t/jQCX0N9HlDiZ
Disc type: UHD
Disc ID: 0xB6BA52F682DCC776CD764F3CB46EABD8FE065D0A
Disc dump filename: MKB20_v61_THE_INCREDIBLE_HULK_4B1F.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/MCmjJJlDgZYI
Disc dump link: https://transfer.it/t/MCmjJJlDgZYI
Disc type: UHD
Disc type: UHD
Disc type: UHD
Disc type: UHD
Disc type: UHD
keydb_helper
Thanks for the submission ingallberry. Your disc has been added to the public keydb. Download or sync the latest keydb and you should be good to go.ingallberry wrote: Tue Jan 27, 2026 7:20 pm Disc dump filename: MKB20_v77_Titanic_9A19
First time - hope I've done it right!
Thanks for the submissions daofail. All six of your discs have been added to the public keydb.daofail wrote: Wed Jan 28, 2026 4:41 am Disc dump filename: MKB20_v61_MARVELS_THE_AVENGERS_6769.tgz
For the sake of clarity, there is no issue with AACS 2.1 disc dumps being submitted via this thread. But it is important that users understand:
1. MakeMKV will not utilise the public keydb for AACS 2.1 titles
2. The public keydb doesn't contain all of the required disc-specific keys for proper playback of AACS 2.1 titles
3. libaacs in its current public form doesn't support AACS 2.1 playback even if all of the keys were available in the keydb
Submitting AACS 2.1 disc dumps will not change the current playback/decryption situation but they may be utilised to facilitate support in the future.
nyva95
Disc type: Blu-ray
Disc ID: 0xD0C608DD78D94C46B080AEAD89A4170A0E594BC3
Disc dump filename: MKB_v82_Ryosuke_Yamada_Blue_Noise_8C9C.tgz
Drive: BD-RE WH14NS40
Drive firmware: 1.05
LibreDrive status: Possible (with patched firmware)
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1yorB4n ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1VdpTij ... drive_link
Disc type: Blu-ray
Disc ID: 0xAF353387B198F495A26F1E01A1E80771
Disc dump filename: MKB_v82_Ryosuke_Yamada_Blue_Noise_41DE.tgz
Disc dump link: https://drive.google.com/file/d/1nAesPK ... sp=sharing
Thank you!
Disc type: Blu-ray
Thank you!
MrPenguin
Hmm, your dump is actually MKB20_v77_The_Sound_of_Music_4E29.tgz. And there is no point also providing the MKB_RO.inf file from inside the TGZ dump file, because you've already provided that one by providing the TGZ dump file. Not only that, the only reason for asking for the MKB_RO.inf separately in the first place is because the one inside the TGZ dump has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV itself.
marius_m24
I didn't check it properly. Sorry.MrPenguin wrote: Wed Jan 28, 2026 11:35 amHmm, your dump is actually MKB20_v77_The_Sound_of_Music_4E29.tgz. And there is no point also providing the MKB_RO.inf file from inside the TGZ dump file, because you've already provided that one by providing the TGZ dump file. Not only that, the only reason for asking for the MKB_RO.inf separately in the first place is because the one inside the TGZ dump has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV itself.
I have attached the file again, please check it.
TheOfficialRD3
Disc type: BD-ROM UHD
Disc ID: DD9192FC7E37C069DDBCB5BE3AF6CE5465A2CACC
Disc dump filename: MKB20_v61_Hook_37ED
Drive: RS9201
Drive firmware: 1.03/ID72
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): DONE
Disc dump link: https://drive.google.com/drive/folders/ ... sp=sharing
Thank you so much guys!!!
Drive: RS9201
rockerest
Re: Public KeyDB Disc Submissions -- Minority Report 4K
Disc type...................BD-ROM UHD
Disc ID.......................f7a38d631e86a4e7a83e7f463fe1cd16c99866f3
Disc dump filename MKB20_v82_MINORITY_REPORT_56ED
Drive..........................Pioneer BD-RW BDR-S13U (RS9201)
Drive firmware..........PIONEER BDR-213T (1.03/ID43)
LibreDrive status......Enabled
15min keydb sync?..Yes
Public links?.............Yes
MKB_RO.inf link.......https://drive.google.com/file/d/1MwRNFS ... sp=sharing
Disc dump link..........https://drive.google.com/file/d/1YYYoTO ... sp=sharing
Scavenger
Disc type: UHD
Disc ID: E2174B2E0A01D25577646FE751804E67AD223FBB
Disc dump filename: MKB20_v82_Infernal_Affairs_UHD_407C
Disc dump link: https://mega.nz/file/Gg81gb5b#AuJKGlF7T ... MinDWIPOpw
Disc type: UHD
Disc ID: 4F1CA105DA7946258EC100137F7BEBFAD1371D51
Disc dump filename: MKB20_v82_Infernal_Affairs_2_UHD_241C
Disc dump link: https://mega.nz/file/39VFhK7L#aXgqnGumX ... LVZrol0CIk
Disc type: UHD
Disc ID: 8B94AD4D2652F8916E83FE532F7C0BE97DD8E1D6
Disc dump filename: MKB20_v82_Infernal_Affairs_3_UHD_EB92
Disc dump link: https://mega.nz/file/uxVESRaD#2Zu2iidvQ ... AKSVmfLMNQ
Disc type: UHD
Disc type: UHD
Jade.
Here's my dump file, hope you can help decrypt.
Thank you.
Thank you.
FrankGrimes2769
Constantine (2005)
Disc type: UHD
Disc ID: 7ef2612818c84407b1db6677fae06723b1b1360f
Disc dump filename: MKB20_v77_Constantine_F2E9
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/15Ypb0h ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1bT6-Gj ... sp=sharing
Thanks in advance for helping out!
I updated keydb.cfg and everything is now working. Thanks for the assist. Awesome Stuff!
Disc type: UHD
Drive: BD-RE BU40N
user76419
Disc type: UHD
Disc ID: 3dbd1c99146a8dff24bcb55cf0fcfa79925e3598
Disc dump filename: MKB20_v61_Arrival_2001.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/ij9n8tr6 ... 1.tgz/file
Thank you!
Thank you!
Scavenger
Bumping this one, because everything posted after this has already been processed. MKB_RO.inf is by the way not included in separate links because dumps are ~3.3MB.
Scavenger wrote: Fri Jan 30, 2026 10:44 am Disc type: UHD
Disc type: UHD
Disc type: UHD
keydb_helper
The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v68_WEATHERING_WITH_YOU_B05F
*MKB20_v82_BLUE_VELVET
mkb20_v82_ice_road_vengeance_e6e7
*MKB20_v82_Infernal_Affairs_2_UHD_241C
*MKB20_v82_Infernal_Affairs_3_UHD_EB92
*MKB20_v82_Infernal_Affairs_UHD_407C
*MKB20_v82_KILL_BILL_1_FB28
*MKB20_v82_KILL_BILL_2_3D82
*MKB20_v82_One_Battle_After_Another_07F0
Hey Scavenger, please don't bump submissions within 24 hours of your original post. The disc dumps which were posted after and supported before yours shared media keys with existing entries in the public keydb. These titles will generally be added to the public keydb more promptly compared to titles which require new media keys.Scavenger wrote: Sat Jan 31, 2026 8:54 am Bumping this one, because everything posted after this has already been processed. MKB_RO.inf is by the way not included in separate links because dumps are ~3.3MB.
ergassia
Hi, dumps UHD 4K Italian version of KILL BILL (1-2)
The dumps are in the same file zip.
Disc type: UHD
Disc ID: 0xB8065E64FACB07F8EFD7629F3B27BAA085A0E42E
Disc dump filename: MKB20_v82_KILL_BILL_1_FB28.tgz
Drive: BD-RE BU40N
MKB_RO.inf link:
https://www.mediafire.com/file/zhzx75re ... s.zip/file
Disc type: UHD
Disc ID: 0x226CE4DFD3C53CCE851D0552862F56499726A816
Disc dump filename: MKB20_v82_KILL_BILL_2_3D82.tgz
Drive: BD-RE BU40N
MKB_RO.inf link:
Thanks in advance.
Disc type: UHD
Drive: BD-RE BU40N
MKB_RO.inf link:
Disc type: UHD
Drive: BD-RE BU40N
MKB_RO.inf link:
Thanks in advance.
