Public KeyDB Disc Submissions
user76419
Post by user76419 » Sun Jan 25, 2026 9:47 pm
Disc type: UHD
Disc ID: 71160117f7cdad0aca9b49ea5e886a923ac97c54
Disc dump filename: MKB20_v76_THE_HOBBIT_BOTFA_EXT_2C57.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/bkltvhz6 ... 7.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:48 pm
Disc type: UHD
Disc ID: d87d7bdafc5b77c07ed3a1a33a0eca6bb3977f38
Disc dump filename: MKB20_v76_LOTR_FELLOWSHIP_OF_THE_RING_P2_DC9B.tgz
Disc dump link: https://www.mediafire.com/file/05iwdkzw ... B.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:49 pm
Disc type: UHD
Disc ID: bc80f51d36dc6f0e51960de822a3b3037cb5e34f
Disc dump filename: MKB20_v76_LOTR_FELLOWSHIP_OF_THE_RING_7D99.tgz
Disc dump link: https://www.mediafire.com/file/yh606o2g ... 9.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:50 pm
Disc type: UHD
Disc ID: 52fe1283e5134b44ac23cf3e1986573776c6c114
Disc dump filename: MKB20_v76_LOTR_THE_TWO_TOWERS_PT1_174B.tgz
Disc dump link: https://www.mediafire.com/file/4un7yna4 ... B.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:51 pm
Disc type: UHD
Disc ID: 62a5f597abe77f30d23ee634646e8827f7c8fe2d
Disc dump filename: MKB20_v76_LOTR_THE_TWO_TOWERS_55E3.tgz
Disc dump link: https://www.mediafire.com/file/jgut0qxr ... 3.tgz/file
Thank you!
daofail
Post by daofail » Sun Jan 25, 2026 9:53 pm
Disc type: UHD
Disc ID: 0xC91340CB7D3DF40D1E6916C81B8F4C427A8AD97C
Disc dump filename: MKB20_v68_THOR_THE_DARK_WORLD_6151.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02 / Patched
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/FwbpP4gz2TBL
Disc dump link: https://transfer.it/t/FwbpP4gz2TBL
thx!
daofail
Post by daofail » Sun Jan 25, 2026 9:54 pm
MrPenguin wrote: Sun Jan 25, 2026 5:40 pm
daofail wrote: Sun Jan 25, 2026 5:32 pm Disc dump filename: MKB20_v68_GUARDIANS_OF_THE_GALAXY_1_8BC3.tgz
That link is for "Avengers: Age of Ultron".
whoops. resent
Disc type: UHD
Disc ID: 0xC74F0C0CFCA2D0C94FF8D09036E6878ECE160669
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/L6kj78hHVJaD
Disc dump link: https://transfer.it/t/L6kj78hHVJaD
daofail
Post by daofail » Mon Jan 26, 2026 1:47 am
Disc type: UHD
Disc ID: 0x172AA8B31E23C2D21BAE36D68A7ADF6C836D0816
Disc dump filename: MKB20_v61_MARVEL'S_AVENGERS-_AGE_OF_ULTRON_997D.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/CFDrmxpDRJKZ
Disc dump link: https://transfer.it/t/CFDrmxpDRJKZ
This is the Age of Ultron.
Playboy84
Post by Playboy84 » Mon Jan 26, 2026 5:54 am
Disc type:UHD
Disc ID:0x601AF1435A3816B62DA936CA2D3775627C5ECF22
Disc dump filename:MKB20_v77_The_Fugitive_9E91.tgz
Drive:BD-RE BP60NB10
Drive firmware:1.02
Disc dump link: https://transfer.it/t/vF9PVrxlHRTJ
dannyb496
Post by dannyb496 » Mon Jan 26, 2026 9:31 am
MrPenguin wrote: Sun Jan 25, 2026 4:56 pm
dannyb496 wrote: Sun Jan 25, 2026 12:53 pm LibreDrive status: Enabled
Unfortunately, it doesn't look like LibreDrive was enabled when creating this dump:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130306
DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:121264395
DEBUG: Code 4 at JP0V,W`B0e43*0h<e5:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Can you try power-cycling your drive and trying again please?
Sorry, my MakeMKV told me it was enabled, not sure what was going on. I tried again today on a whim and it was able to open the disc, but then failed to save the files. Then I remembered reading somewhere that 4K disc reading/ripping can require alot of power that USB drives can struggle with (my drive is USB), so I plugged it in to the back of my PC instead of the front panel and it successfully saved the files. So glad because the disc had given me no end of trouble, I was cycling through different BU40N
firmwares in the hopes to get it to work, I guess restarting the PC and using the back panel made it work. Sorry for taking up your time. I'm using a Verbatim utra slim 4K 43888 if thats useful. Thanks again
keydb_helper
Post by keydb_helper » Mon Jan 26, 2026 9:53 am
Thanks to everyone who sent in new disc dump files. Aside from the incomplete Tangled disc dump, I believe all submissions have been added to the public keydb. These two UHD variants corresponded to new media keys:
MKB20_v82_TheToxicAvenger_634A
MrMegadeth99
Post by MrMegadeth99 » Mon Jan 26, 2026 4:46 pm
Hello, where can I get download the latest keydb.cfg file? I was getting it from FindVUK but that site seems to be down.
MrPenguin
Post by MrPenguin » Mon Jan 26, 2026 5:22 pm
MrMegadeth99 wrote: Mon Jan 26, 2026 4:46 pm Hello, where can I get download the latest keydb.cfg file? I was getting it from FindVUK but that site seems to be down.
It's not down. More likely, your browser is trying to use HTTPS, whereas the site only supports HTTP.
joealden
Post by joealden » Mon Jan 26, 2026 8:33 pm
Disc type: UHD
Disc ID: Ox1E7BA23516FDC12E70B568143B98BA71657BBA18
Disc dump filename: MKB20_v82_South_Park-_Bigger,_Longer,_&_Uncut_3683.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/p3hDaxg3FDxA
Disc dump link: https://transfer.it/t/dJe5ax5hFZJQ
keydb_helper
Post by keydb_helper » Mon Jan 26, 2026 9:13 pm
Playboy84 wrote: Mon Jan 26, 2026 5:54 am Disc ID:0x601AF1435A3816B62DA936CA2D3775627C5ECF22
Your disc was added to the public keydb on June 12 last year. If you opened up any keydb.cfg from the past six months in a text editor you could've searched for and found your disc ID.
Playboy84 wrote: Mon Jan 26, 2026 5:54 am MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
I was really fucking clear in the opening post about the requirement for including the full MKB_RO.inf file. If your disc wasn't already supported by the public keydb, the 56 byte stub in your disc dump file would've been useless compared to the actual file on your disc:
keydb_helper wrote: Thu Jun 26, 2025 1:40 am Partial disc dumps
UHD disc dump files are generally 3-8MB. If your disc dump is less than 1MB, you will need to manually include the MKB_RO.inf file when uploading your disc dump file. You can find this file within the AACS folder on your disc. The MKB_RO.inf file may be ~128MB so feel free to zip it before uploading it.
Do not just extract the ~56 byte MKB_RO.inf file from a partial disc dump file and upload it separately. This is not helpful. Instead, copy the MKB_RO.inf file from the AACS folder on your disc and upload it separately. If your MKB_RO.inf file is not several megabytes in size, it is probably not useful for UHD discs.
