Public KeyDB Disc Submissions
mhalter81
Post by mhalter81 » Sun Jan 25, 2026 3:35 pm
MrPenguin wrote: Sun Jan 25, 2026 3:32 pm
mhalter81 wrote: Sun Jan 25, 2026 3:14 pm Disc dump filename: MKB21_v70_Zombieland_CC8B
I think you're out of luck with this one :(
Oh no, did I do something wrong?
Never mind, I see.
user76419
Post by user76419 » Sun Jan 25, 2026 4:50 pm
Disc type: UHD
Disc ID: e78c74bef72fe136433a6ef5317349e67f1569df
Disc dump filename: MKB20_v61_HOWTHEGRINCHUHD_UPK1_0C91.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/wozl96y8 ... 1.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 4:53 pm
Disc type: UHD
Disc ID: d72fff6d449c8dffa9f717273e305f03fedcfe1d
Disc dump filename: MKB20_v61_JURASSICPARK_UHD_UPK1_78E7.tgz
Disc dump link: https://www.mediafire.com/file/zg33yn1i ... 7.tgz/file
Thank you!
user76419
Disc type: UHD
Disc ID: eeb7b17fdad45f9992896fd7da36294661137d37
Disc dump filename: MKB20_v61_JURASSICPARK2UHD_UPK1_7BA1.tgz
Disc dump link: https://www.mediafire.com/file/jw1k6nch ... 1.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 4:54 pm
Disc type: UHD
Disc ID: 383b8f25ec303e2841962371df66653b0d92498b
Disc dump filename: MKB20_v61_JURASSICPARK3UHD_UPK1_B807.tgz
Disc dump link: https://www.mediafire.com/file/p0mvfw7c ... 7.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 4:56 pm
Disc type: UHD
Disc ID: 15eb8ad7b97087558363787c2339b95b0426381e
Disc dump filename: MKB20_v61_JURASSIC_WORLD_A8C7.tgz
Disc dump link: https://www.mediafire.com/file/yxap165k ... 7.tgz/file
Thank you!
MrPenguin
Post by MrPenguin » Sun Jan 25, 2026 4:56 pm
dannyb496 wrote: Sun Jan 25, 2026 12:53 pm LibreDrive status: Enabled
Unfortunately, it doesn't look like LibreDrive was enabled when creating this dump:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130306
DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:121264395
DEBUG: Code 4 at JP0V,W`B0e43*0h<e5:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Can you try power-cycling your drive and trying again please?
user76419
Post by user76419 » Sun Jan 25, 2026 4:57 pm
Disc type: UHD
Disc ID: 143f4cb5fd9ec1154b2e142212c3e1fc58133b00
Disc dump filename: MKB20_v61_MUMMY3UHD_NA_2265.tgz
Disc dump link: https://www.mediafire.com/file/fxctitt7 ... 5.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 4:58 pm
Disc type: UHD
Disc ID: 48eda910a9386ad559c13bb7c34f55abb4a7b008
Disc dump filename: MKB20_v61_The_Mummy_Returns_F557.tgz
Disc dump link: https://www.mediafire.com/file/xafhd83t ... 7.tgz/file
Thank you!
daofail
Post by daofail » Sun Jan 25, 2026 5:32 pm
Disc type: UHD
Disc ID: 0xC74F0C0CFCA2D0C94FF8D09036E6878ECE160669
Disc dump filename: MKB20_v68_GUARDIANS_OF_THE_GALAXY_1_8BC3.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02 / Patched
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/fwPb69pjzDxL
Disc dump link: https://transfer.it/t/fwPb69pjzDxL
Thank you!
MrPenguin
Post by MrPenguin » Sun Jan 25, 2026 5:40 pm
daofail wrote: Sun Jan 25, 2026 5:32 pm Disc dump filename: MKB20_v68_GUARDIANS_OF_THE_GALAXY_1_8BC3.tgz
That link is for "Avengers: Age of Ultron".
user76419
Post by user76419 » Sun Jan 25, 2026 9:47 pm
Disc type: UHD
Disc ID: 71160117f7cdad0aca9b49ea5e886a923ac97c54
Disc dump filename: MKB20_v76_THE_HOBBIT_BOTFA_EXT_2C57.tgz
Disc dump link: https://www.mediafire.com/file/bkltvhz6 ... 7.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:48 pm
Disc type: UHD
Disc ID: d87d7bdafc5b77c07ed3a1a33a0eca6bb3977f38
Disc dump filename: MKB20_v76_LOTR_FELLOWSHIP_OF_THE_RING_P2_DC9B.tgz
Disc dump link: https://www.mediafire.com/file/05iwdkzw ... B.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:49 pm
Disc type: UHD
Disc ID: bc80f51d36dc6f0e51960de822a3b3037cb5e34f
Disc dump filename: MKB20_v76_LOTR_FELLOWSHIP_OF_THE_RING_7D99.tgz
Disc dump link: https://www.mediafire.com/file/yh606o2g ... 9.tgz/file
Thank you!
user76419
Post by user76419 » Sun Jan 25, 2026 9:50 pm
Disc type: UHD
Disc ID: 52fe1283e5134b44ac23cf3e1986573776c6c114
Disc dump filename: MKB20_v76_LOTR_THE_TWO_TOWERS_PT1_174B.tgz
Disc dump link: https://www.mediafire.com/file/4un7yna4 ... B.tgz/file
Thank you!
