Public KeyDB Disc Submissions
Disc type: BD
Disc ID: 53A0F6E99B3AC69E69ADAFEFD9C6074397AB4C5D
Disc dump filename: MKB_v82_「Fate_stay_night」20周年記念コンサート_Finale_03A4
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://transfer.it/t/IC09H9ghUJRA
Disc dump link: https://transfer.it/t/6MbXq4oH2ZQD
Drive: BD-RE BU40N
Unfortunately the third part isn't working, could someone please check it again?
MKB20_v82_MeisterAllerKlassen3_UHD_42DE
I think the KEYDB entry for this disk is correct.kasko wrote: Thu Jan 22, 2026 10:49 am Unfortunately the third part isn't working, could someone please check it again?
Hi!
First time submission, so let me know, if I made something wrong.
Disc dump "MKB_v82_ONE_BATTLE_AFTER_ANOTHER_E390"
https://magentacloud.de/s/MxzWBxoq9M9mSqX
Cheers,
Zap
Cheers,
Zap
Disc type: UHD
Disc ID: 863AA9F0B6356D4F4BEEF09901CC606CB49DA26D
Disc dump filename: MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_DD6C
Drive: ASUS_BW-16D1HT_3.10
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/0rdsCU8VgBKY
Disc dump link: https://transfer.it/t/N7oreF1B3ZYR
I restarted it now and it's working, I have no idea why it didn't work this morning.
Thank you
I did run the disc through the hash check and it verified 100%. So I don't think it is a dirty disc problem. Arrow UK's discs are usually perfect, but I will try it. Thank you.Coopervid wrote: Thu Jan 22, 2026 10:32 amWash the disc wit liquid soap and warm water. Dry witha microfiber cloth. If you get still an error post it here .SMD88 wrote: Thu Jan 22, 2026 10:29 amVery true, I am sorry about that! I am not home at the moment but I will add the information when I can.keydb_helper wrote: Thu Jan 22, 2026 9:43 am
It is hard to speculate on what might be the issue without any information about the error message or error code. Are you receiving a decryption error? Or is it a read error? If it is a read error, I can't suggest anything other than cleaning the disc and trying a different disc drive.
When I open the disc, it takes a good few minutes to go through the "dycrypting" stage, and then fails. It gives two debug codes and says the disc cannot be decrypted. Much like posts I have seen where the keydb file was not being read by Makemkv.
frameloose
According to this thread, the UHD is not encrypted.SMD88 wrote: Thu Jan 22, 2026 9:15 am I have been trying in vein to rip Arrow's City On Fire. Has anyone managed to rip it?
I have used Keydb Helper to get the keys, but it still refuses to work. I used the programme previously to rip Little Darlings and it was quick and easy. This damned Arrow disc refuses to work for me. Very frustrating. I am not sure what I am doing wrong.
viewtopic.php?f=12&t=40089
keydb_helper
knolle123 wrote: Thu Jan 22, 2026 4:08 pm Disc dump filename: MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_DD6C
Thanks for the new disc submissions. One variant after another has been added to the public keydb.
Thanks for the reminder SamSpeexy. I forgot that City on Fire had previously been discussed within this thread: Link.SamSpeexy wrote: Thu Jan 22, 2026 9:10 pm According to this thread, the UHD is not encrypted.
KeyDB Helper should have caught that and displayed a message about it. Granted, it's an experimental feature I added but in theory it should have been able to check.
Great! It works... Thanks a lotkeydb_helper wrote: Fri Jan 23, 2026 3:18 amknolle123 wrote: Thu Jan 22, 2026 4:08 pm Disc dump filename: MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_DD6CThanks for the new disc submissions. One variant after another has been added to the public keydb.
Disc type: UHD
Disc ID: 3b246daf52261b5e2d15616661fb48e369cd89e4
Disc dump filename: MKB20_v82_BEASTMASTER_6B50
Drive: WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://transfer.it/t/h9Tvb04BBT7J
Disc dump link: https://transfer.it/t/IMaQK9pF1TpR
Thank you!
Drive: WH16NS60
Thank you!
Disc type: UHD
Disc ID: 0xAB9BDC07D7FEC17BA080D25C8AC3E210466474E2
Disc dump filename: MKB20_v61_MARVEL'S_GUARDIANS_OF_THE_GALAXY_VOL_2_320D.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02 / Patched
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/JPTEy5pFyR6K
Disc dump link: https://transfer.it/t/JPTEy5pFyR6K
Disc type: UHD
Disc ID: 0xCE0E92490D1BEC137677525BB9F52BBD334E8CF5
Disc dump filename: MKB20_v65_MARVEL'S_ANT-MAN_AND_THE_WASP_-_ULTRA_HD_6B37.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/4IL7WwxVELxb
Disc dump link: https://transfer.it/t/4IL7WwxVELxb
