Dump submitted for Wicked: For Good
jrocca8
#1 Post by jrocca8 » Wed Jan 21, 2026 9:15 pm
Sent file MKB_v82_Wicked-_For_Good_1FE0.tgz
mcmehrtens
Re: Dump submitted for Wicked: For Good
#2 Post by mcmehrtens » Thu Jan 22, 2026 1:24 am
Bit of a silly question, but I just tried to rip The Wicked: For Good Blu-ray (American, Universal Pictures release) and the dump file that got created was MKB_v82_Wicked-_For_Good_8426.tgz. Note the difference in the last four characters.
Does this mean I have a different version that needs to be submitted as well or are the last four characters an unrelated identifier?
#3 Post by dcoke22 » Thu Jan 22, 2026 4:59 am
If the last four characters are different then your disc needs a different key. You should email your dump to svq@makemkv.com.
You could also try an alternative source of keys for MakeMKV, the public keyDB. It might contain the key your disc needs. If not, you can submit the dump to them as well.
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=38293
Michl1a
#4 Post by Michl1a » Fri Feb 20, 2026 3:13 pm
Greetings
here is another version of the dumpfile from "Wicked: Teil 2"
MKB20_v82_Wicked-_For_Good_6D8E
Michl1a
#5 Post by Michl1a » Sun Feb 22, 2026 9:01 am
MKB20_v82_Wicked-_For_Good_6D8E.tgz
Babyhunts
#6 Post by Babyhunts » Mon Feb 23, 2026 10:23 pm
Another one submitted.
mvcoder
#7 Post by mvcoder » Tue Feb 24, 2026 11:02 pm
I've just tried to open Wicked: For Good and it fails with this dump file.
MKB20_v82_Wicked-_For_Good_67FE.tgz
(3.41 MiB) Downloaded 111 times
Do I need to do anything with this file to get a solution? I'm new to UHD ripping.
MrPenguin
#8 Post by MrPenguin » Tue Feb 24, 2026 11:34 pm
Someone has already attached a file with that same name here, so you definitely don't need to attach yours here as well. All you really need do is email it to svq@makemkv.com, although if you would also like your disk added to the public KEYDB.cfg file as well then you can upload your TGZ file into (say) OneDrive or Google Drive and then post a public download link here.
BTW this is the BD sub-forum. There is a separate sub-forum for UHD disks like yours.
