Dump submitted for Wicked: For Good
jrocca8
Post by jrocca8 »
Sent file MKB_v82_Wicked-_For_Good_1FE0.tgz
mcmehrtens
Re: Dump submitted for Wicked: For Good
Post by mcmehrtens »
Bit of a silly question, but I just tried to rip The Wicked: For Good Blu-ray (American, Universal Pictures release) and the dump file that got created was MKB_v82_Wicked-_For_Good_8426.tgz. Note the difference in the last four characters.
Does this mean I have a different version that needs to be submitted as well or are the last four characters an unrelated identifier?
mcmehrtens wrote:
Thu Jan 22, 2026 1:24 am
If the last four characters are different then your disc needs a different key. You should email your dump to svq@makemkv.com.
You could also try an alternative source of keys for MakeMKV, the public keyDB. It might contain the key your disc needs. If not, you can submit the dump to them as well.
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=38293
Michl1a
Post by Michl1a »
Greetings
here is another version of the dumpfile from "Wicked: Teil 2"
MKB20_v82_Wicked-_For_Good_6D8E
Michl1a
Post by Michl1a »
MKB20_v82_Wicked-_For_Good_6D8E.tgz
Babyhunts
Post by Babyhunts »
Another one submitted.
mvcoder
Post by mvcoder »
I've just tried to open Wicked: For Good and it fails with this dump file.
MKB20_v82_Wicked-_For_Good_67FE.tgz
(3.41 MiB) Downloaded 338 times
Do I need to do anything with this file to get a solution? I'm new to UHD ripping.
MrPenguin
Post by MrPenguin »
mvcoder wrote:
Tue Feb 24, 2026 11:02 pm
Someone has already attached a file with that same name here, so you definitely don't need to attach yours here as well. All you really need do is email it to svq@makemkv.com, although if you would also like your disk added to the public KEYDB.cfg file as well then you can upload your TGZ file into (say) OneDrive or Google Drive and then post a public download link here.
BTW this is the BD sub-forum. There is a separate sub-forum for UHD disks like yours.
