Public KeyDB Disc Submissions
buffalobossie
Resurrection of Eve
Disc type: BD ROM
Disc ID: 1a2b909d28448d635023ae95e65c9252d8c266e9
Disc dump filename: MKB_v82_MBFG002_0358.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1rs9CES ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13TF1d3 ... sp=sharing
Maraschino Cherry
Disc type: BD ROM
Disc ID: 4a5a9107d54af80408a2eef342b3c05ac50a2667
Disc dump filename: MKB_v82_QX021_7372.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1hXY65Z ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1H14Gwp ... sp=sharing
Disc type: BD ROM
Maraschino Cherry
Disc type: BD ROM
Rabster
Thats weird as its showing as enabled before inserting the discMrPenguin wrote: Mon Jan 19, 2026 2:52 pmRabster wrote: Mon Jan 19, 2026 2:13 pm Drive: BD-RE BU40N
Drive firmware:1.03
LibreDrive status:EnabledYour drive has not enabled LibreDrive, which unfortunately means your dump is uselessCode: Select all
SDF v0a4: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO9P5OG1000 003007:0000 Using direct disc access mode 005085:0000 Loaded content hash table, will verify integrity of M2TS files. DEBUG: Code 2147483648 at 3}LEXDFfdV,&S#:f:121265499 DAFD=PAAAADAAAAEABDQgEFwECAQ== 002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' ... 003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive.
Try power-cycling your drive?
Rabster
Drive firmware:1.03
Restarted PC, removed drive from enclosure, plugged drive into a different USB port, had to use the same cables that I flashed the drive with, and now it appears to be working. Thanks for the help. I'll know in about an hour if it's done properly and if I've selected the right stream and will update then
MrPenguin
Sometimes LibreDrive just doesn't enable - I don't know why.Rabster wrote: Mon Jan 19, 2026 7:30 pm Restarted PC, removed drive from enclosure, plugged drive into a different USB port, had to use the same cables that I flashed the drive with, and now it appears to be working. Thanks for the help. I'll know in about an hour if it's done properly and if I've selected the right stream and will update then
Now that LD is working again, could you generate a new discatt.dat file for this disk and upload it please? (Use MakeMKV to start an encrypted disk backup-up into a temporary directory, copy the discatt.dat file to a safe place as soon as it appears - and it should be one of the very first files - and then abort the back-up.) This file should provide the missing pieces to allow people to add your disk to the public KEYDB.cfg file too.
buffalobossie
The Films of Hisayasu Sato - Volume 3 - Disc 1
Disc type: BD ROM
Disc ID: 7c07f0f927de510401be45d6524203f4c8ee2614
Disc dump filename: MKB_v82_PL003A_0712.tgz
MKB_RO.inf link: https://drive.google.com/file/d/13WoUqZ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kcxXgT ... sp=sharing
The Films of Hisayasu Sato - Volume 3 - Disc 2
Disc type: BD ROM
Disc ID: c30581b219f48e98083a33f4fc188d724d6c80a8
Disc dump filename: MKB_v82_PL003B_0BDA.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1WOd7KX ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1S99vyT ... sp=sharing
The Dead Thing
Disc type: BD ROM
Disc ID: 139a4a3569b6e0e45255ce6c312f4748991e4200
Disc dump filename: MKB_v82_The_Dead_Thing_407E.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1OoCfHR ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1HGIBx8 ... sp=sharing
Made in Hong Kong Volume 2 - Disc 1
Disc type: BD ROM
Disc ID: d6a64ca77adf45cefb4db04737b51389ea571322
Disc dump filename: MKB_v82_VS525A_5D72.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1Sk5g95 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/14gvvGw ... sp=sharing
Made in Hong Kong Volume 2 - Disc 2
Disc type: BD ROM
Disc ID: fe51a91fcf2c7cfda6b51363bff37aab66c92710
Disc dump filename: MKB_v82_VS525B_3094.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1raQwRW ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1uNV1Gr ... sp=sharing
Made in Hong Kong Volume 2 - Disc 3
Disc type: BD ROM
Disc ID: 1092048109f98326734d54eb9ea70ddb07fcd3b0
Disc dump filename: MKB_v82_VS525C_116A.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1uy8csf ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1lIfTGw ... sp=sharing
The Veil - Disc 1
Disc type: BD ROM
Disc ID: 0fe2d12b520d8e2afd266f20c5ea5e6e2e33b30e
Disc dump filename: MKB_v82_ICON002A_F9CA.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1RpMMCW ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1TwgsR9 ... sp=sharing
The Veil - Disc 2
Disc type: BD ROM
Disc ID: 06fbd87f8a5ad87844ec13aefbd22dea678ceda4
Disc dump filename: MKB_v82_ICON002B_65D6.tgz
MKB_RO.inf link: https://drive.google.com/file/d/1PfnxIP ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1m94PgL ... sp=sharing
The Veil - Disc 3
Disc type: BD ROM
Disc ID: a8a56c0103a69bfc0665feb8a695f8f7dc20cfa3
Disc dump filename: MKB_v82_ICON002C_19C8.tgz
MKB_RO.inf link: https://drive.google.com/file/d/14qOgj8 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/19veAGH ... sp=sharing
Disc type: BD ROM
Disc type: BD ROM
The Dead Thing
Disc type: BD ROM
Disc type: BD ROM
Disc type: BD ROM
Disc type: BD ROM
The Veil - Disc 1
Disc type: BD ROM
The Veil - Disc 2
Disc type: BD ROM
The Veil - Disc 3
Disc type: BD ROM
sandman_satx213
Apologies. New link below.MrPenguin wrote: Mon Jan 19, 2026 4:10 pmCan you upload the actual MKB_RO.inf file from your physical UHD disk please? The MKV_RO.inf file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable by anyone except MakeMKV itself. And besides, we already have the truncated file anyway because it's inside the TGZ file you have also provided...sandman_satx213 wrote: Mon Jan 19, 2026 3:40 pm Disc dump filename: MKB20_v77_AVATAR_THE_WAY_OF_WATER_A18D
Avatar The Way of The Water
Disc type: UHD
Disc ID: FDB33AF5C03AAA8F1A8B1CAA273E6B8CEF1F6BBD
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1NsfvGy ... drive_link
Disc dump link: https://drive.google.com/file/d/1Tb9gNz ... drive_link
keydb_helper
Thanks to everyone who posted new disc dump files. I believe all submissions have been added to the public keydb. The following UHD disc variants were new to the keydb:
@FootFungus07 - Please don't create a new thread for each disc. You can just post them here instead. Otherwise there is a very real chance your other threads could be overlooked as this thread is the priority.
MKB20_v77_Death_on_the_Nile_C1E4
MKB20_v77_Evil_Under_the_Sun_45DE
MKB20_v77_The_Mirror_Crack'd_8670
MKB20_v82_Carrie_UHD_1112
- Do not submit Stranger Things S2D2, S4D3, or S5D2
qqac8
I posted this before, but I had to repost it because the link was incorrect.
viewtopic.php?p=193478#p193478
Disc type:BD
Disc dump filename:MKB_v82_サイレント・ウィッチ_沈黙の魔女の隠しごと_4_FD0E.tgz
Drive: BD-RE BH16NS58
Drive firmware: 1.01
LibreDrive status: True
Did you sync the public keydb within the last 15 minutes?: Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/UX7jsU8l2ZQS (Copied from disk)
Disc dump link: https://transfer.it/t/157Jpdk3UTgA
Disc type:BD
a01ik3d4_1018
Here I'm posting a shared link to the dump file for the Blu-ray disc I want Keydb to support. It's probably something no one has shared yet. Also, could someone please tell me how to check if my disc's ID is already entered in Keydb, and where disc IDs are added in the first place—is it the public key database?
This is the link to share the Blu-ray disc dump file.
https://drive.google.com/file/d/1mCFcIG ... sp=sharing
Bomb_Dance
Disc type: BD
Disc dump filename: MKB_v82_BD_VIDEO_279E
Drive: CH12NS40
MKB_RO.inf link: https://www.dropbox.com/scl/fi/nzh0ohfk ... 86uys&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/mypktkfj ... i3m96&dl=0
Disc type: BD
Disc dump filename: MKB_v82_BD_VIDEO_2096
Drive: CH12NS40
MKB_RO.inf link: https://www.dropbox.com/scl/fi/19r9ir37 ... 7xept&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/zfbf0gng ... pylw6&dl=0
Disc type: BD
Disc dump filename: MKB_v82_BD_VIDEO_24EC
Drive: CH12NS40
MKB_RO.inf link: https://www.dropbox.com/scl/fi/ol2bkfmq ... u0j4t&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/t92md20u ... 7fkw6&dl=0
Disc type: BD
Disc dump filename: MKB_v82_BD_VIDEO_AAB4
Drive: CH12NS40
MKB_RO.inf link: https://www.dropbox.com/scl/fi/rbcly7di ... t3x36&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/rrm0n33y ... gorn1&dl=0
Drive: CH12NS40
Disc type: BD
Drive: CH12NS40
Disc type: BD
Drive: CH12NS40
Disc type: BD
Drive: CH12NS40
reverandbob
Suspect
Disc type: Blu-ray (AACS 1.0)
Disc dump filename: MKB_v82_BDROM_ACD4.tgz
Drive: BD-RE WP50NB40
Drive firmware: 1.03
LibreDrive status: N/A
Disc dump link: https://drive.google.com/file/d/1zzUfC0 ... drive_link
reverandbob
It looks like your disc ID is in the latest keyDB file, you'll need to pull down an updated keydb.cfg file from the online database. http://fvonline-db.bplaced.net/a01ik3d4_1018 wrote: Tue Jan 20, 2026 5:36 am Here I'm posting a shared link to the dump file for the Blu-ray disc I want Keydb to support. It's probably something no one has shared yet. Also, could someone please tell me how to check if my disc's ID is already entered in Keydb, and where disc IDs are added in the first place—is it the public key database?
in the future, you'll want to do that BEFORE posting to this forum... it'll save you some time.
sunday
Disc type: Blu-ray
Disc ID: 0x5D909E2A0A95324688A37A5FB30A4ED5D2F2C66F
Disc dump filename: MKB_v82_BD_ROM_D1AC.tgz
Drive: BRXL
Drive firmware: 1.00
MKB_RO.inf link: https://transfer.it/t/HrPOwYkF2ZqY
Disc dump link: https://transfer.it/t/AHc5cc1VzTja
Drive: BRXL
Rauthr
Disc type: UHD
Disc ID: 0x43E244102D1E35E7A757F32A0BCC4B975D527A9A
Disc dump filename: MKB20_v76_Edge_of_Tomorrow_CB2F
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1mupgGb ... drive_link
Disc dump link: https://drive.google.com/file/d/1LVela3 ... drive_link
As always, thank you
Keloid
Disc type: UHD
Disc ID: 0x883BE25789B157F0218A478670E5A16AA2EC58E4
Disc dump filename: MKB20_v77_LOOKBACK_A456.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.mediafire.com/file/pwzv6ifl ... O.inf/file
Disc dump link: https://www.mediafire.com/file/uqwhbeap ... 6.tgz/file
