Public KeyDB Disc Submissions
sh3nanigans
Post by sh3nanigans »
MrPenguin wrote: Sat Jan 17, 2026 7:16 pm
sh3nanigans wrote: Sat Jan 17, 2026 6:00 pm Have you verified that all submission links are accessible in incognito/private browsing? Yes
Can you make these downloads accessible please?
So sorry, must have copied it from the wrong account. Should be public now!
seakalehorsecomposer
Post by seakalehorsecomposer »
Hi folks,
Disc type: UHD
Disc ID: f76aea38f56184191bb0090c6ab7608b80178f12
Disc dump filename: MKB20_v76_SCOTTPILGRIM_UPK1_3B09
Drive: BD-RE PIONEER BD-RW BDR-UD04 1.14
Drive firmware: 2020-06-15
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/6271WX3D0M#lq6FxHU4tdn8
Disc dump link: https://drive.proton.me/urls/QJJACDXRC0#VUof8EcDClXz
keydb_helper
Post by keydb_helper »
AFK88L wrote: Sat Jan 17, 2026 1:20 pm The below release appears to be missing from the public keydb. I would like to contribute, however for this disc I found it was already natively supported by MakeMKV so the program wouldn't create a disc dump.
I tried following the instructions in this post to force MakeMKV to create the dump, but it would not work for me.
Hey AFK88L, the instructions that I wrote in that post were intended for AACS 2.0 discs rather than AACS 1.0. To be honest, I'm actually surprised that MakeMKV v1.18.2 generated a disc dump for an AACS 1.0 MKBv68 disc. MakeMKV v1.18.2 has native support for AACS 1.0 MKBv1-MKBv81 without the need for external/downloaded title specific keys. So it really should've used one of the AACS 1.0 device/processing keys bundled with MakeMKV instead of generating that disc dump.
AFK88L wrote: Sat Jan 17, 2026 1:20 pm I eventually got a disc dump generated by MakeMKV (below) but only when also running in a VM (Win10 for the VM, vs. Win11 on my main host... not sure if that has a bearing).
I believe the VM aspect is not relevant here.
AFK88L wrote: Sat Jan 17, 2026 1:20 pm In light of this, for discs MakeMKV already natively supports but are missing from the public keydb, what is the process? Is there any consistent way to force MakeMKV to create a disc dump so we can submit the required files?
The main components of a disc dump file are:
1. discatt.dat - Contains the volume ID
2. MKB_RO.inf - Contains the encrypted media key (MK) for your disc and the media key verification data used to validate the media key
3. Unit_Key_RO.inf - Contains the encrypted unit key(s)
4. kv.dat - Contains several encrypted aligned units (6,144 bytes each) from one or more M2TS files. It is important that these are read after bus encryption has been disabled.
Technically all of the title-specific keys can be derived with only the first three files. The kv.dat file is used to validate the resultant unit keys. This also has the effect of validating the volume ID (VID) and the volume unique key (VUK). Any small M2TS file from the disc can be used as a substitute for the kv.dat file as long as bus encryption has been disabled before copying the file.
AFK88L wrote: Sat Jan 17, 2026 1:20 pm Alternatively, is there another way to manually create a disc dump without MakeMKV? What files are actually required in the tgz to have it added to the public keydb?
Rough outline:
1. Use MakeMKV to start creating an encrypted folder backup of a disc
2. Stop the backup once the discatt.dat/discattd.dat file has been created and at least one M2TS file has been copied
3. Make a new folder for your synthetic disc dump
4. Copy the discatt.dat file and the smallest M2TS file out of the (incomplete) encrypted backup folder into your synthetic disc dump folder
5. Copy the entire AACS directory from your disc into your synthetic disc dump folder
6. Zip up the synthetic disc dump folder, upload it to a file host and post a link here
The process isn't too streamlined but there will be improvements made throughout this year as some new tools and drive firmware options become available.
FindVUK on Windows can also be used to generate MKBv1-MKBv81 AACS 1.0 disc keys without MakeMKV or any other commercial tool as long as your drive hasn't been exposed to AACS MKBv82
Public KeyDB Disc Submissions KeyDB Download
AFK88L
Post by AFK88L »
keydb_helper wrote: Sun Jan 18, 2026 6:25 am
Hey keydb_helper, thanks so much for your detailed response - this is great information.
Also, thank you for adding that entry to the public keydb so quickly. I have re-checked and confirmed the disc is identified now and working correctly when just using the public keydb (not MakeMKV). Clearly the dump I managed to generate did actually work after all! (I also don't quite know how I got MakeMKV to do that...)
Rough outline:
I'll be sure to follow these instructions next time I come across a disc missing from the public keydb but supported in MakeMKV.
keydb_helper wrote: Sun Jan 18, 2026 6:25 am FindVUK on Windows can also be used to generate AACS 1.0 disc keys without MakeMKV or any other commercial tool as long as your drive hasn't been exposed to AACS MKBv82
Thanks for the info. This may not be an option for me however? Checking "Drive Information" in MakeMKV shows "Highest AACS version: 82" so I guess it has been exposed to AACS MKBv82 already.
keydb_helper
Thanks to everyone who provided new disc dump files. The following disc variants have been added to the public keydb:
MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAB
MKB20_v82_Black_Phone_2_F484
MKB20_v82_FINAL_DESTINATION_BLOODLINES_5C4C
MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8
MKB20_v82_The_Gambler_D3D3
MKB20_v82_TRON-_ARES_F26E
MKB20_v82_Universal_Soldier_ED18
MKB_v82_AMERICAN_YAKUZA_511C
MKB_v82_AVXK_43554_6A8E
MKB_v82_年下童貞くんに翻弄されてます_Disc1_8DEC
MKB_v82_年下童貞くんに翻弄されてます_Disc2_F11E
MKB_v82_雨上がりの僕らについて Disc1_249A
MKB_v82_雨上がりの僕らについて Disc2_51B8
MKB_v82_雨上がりの僕らについて Disc3_ADEE
sh3nanigans
keydb_helper wrote: Sun Jan 18, 2026 10:54 am Thanks to everyone who provided new disc dump files. The following disc variants have been added to the public keydb:
Thank you so much, worked like a charm now!
Cheetah123
Post by Cheetah123 »
Disc type: UHD
Disc ID: c45ec7fc4f95fde09262a51a6280731fb46b8f13
Disc dump filename: MKB20_v82_Wolf_Children_C9FC
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1qWGrj7 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ddNYZJ ... sp=sharing
Thank you so much!
Rauthr
Post by Rauthr »
Disc type: UHD
Disc ID: 0xEDA4808AE29669DF7359119A3AA5740C9D5F123B
Disc dump filename: MKB20_v76_The_Hobbit-_An_Unexpected_Journey_(Extended)_9757
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1S9dbiV ... drive_link
Disc dump link: https://drive.google.com/file/d/1i0AWZm ... drive_link
Disc type: UHD
Disc ID: 0x8620D8025D1A3E99B4EFA1267E0B7572E2DF439B
Disc dump filename: MKB20_v76_The_Hobbit-_The_Desolation_of_Smaug_(Extended)_1111
MKB_RO.inf link: https://drive.google.com/file/d/1K63kB3 ... drive_link
Disc dump link: https://drive.google.com/file/d/1w3rNOJ ... drive_link
Disc type: UHD
Disc ID: 0x245F9D281F97925002765A858C495558428F69BF
Disc dump filename: MKB20_v76_The_Hobbit-_The_Battle_of_the_Five_Armies_(Extended)_2CC5
MKB_RO.inf link: https://drive.google.com/file/d/1V32RZV ... drive_link
Disc dump link: https://drive.google.com/file/d/1mmeghE ... drive_link
Many thanks!
FootFungus07
Post by FootFungus07 »
FootFungus07 wrote: Wed Jan 14, 2026 6:52 pm Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file: ...
Hey FootFungus07, thanks for remembering the MKB_RO.inf file but I think you forgot the actual disc dump file. Feel free to post it whenever you get a chance.
Oh jeeze, total brain skip on my end - here it is, it's kinda small though, not sure if this is normal, really not used to seeing MKV spit out TGZ codes for standard blu-rays
MKB_v82_DRAGONFLY_SQUADRON_3D_92AC.tgz
https://drive.google.com/file/d/1lZV5HE ... drive_link
keydb_helper
FootFungus07 wrote: Mon Jan 19, 2026 12:26 am Oh jeeze, total brain skip on my end - here it is, it's kinda small though, not sure if this is normal, really not used to seeing MKV spit out TGZ codes for standard blu-rays
No stress, it is typical for AACS 1.0 disc dumps to be considerably smaller than AACS 2.0/2.1 disc dump files.
Thanks to everyone who provided new disc dump files. The following discs have been added to the public keydb:
If any submissions have been missed, possibly due to the moderation review process for new users, please feel free to bump your posts after trying out the latest public keydb.
Rabster
Post by Rabster »
Alien 40th Anniversary UHD
Disc type:UHD
Disc ID:0x12004AEB144A21A2FE76EEF4127CFD38C2B5C19C
Disc dump filename:Alien 40th UHD Disc Dump with MKB_RO
Drive: BD-RE BU40N
Drive firmware:1.03
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):Yes
Disc dump link: https://1drv.ms/f/c/1ad098b4ac28ce7a/Ig ... w?e=UdybQs
MrPenguin
Post by MrPenguin »
Rabster wrote: Mon Jan 19, 2026 2:13 pm Drive: BD-RE BU40N
Drive firmware:1.03
SDF  v0a4: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO9P5OG1000
DEBUG: Code 2147483648 at 3}LEXDFfdV,&S#:f:121265499
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Your drive has not enabled LibreDrive, which unfortunately means your dump is useless :(.
Try power-cycling your drive?
buffalobossie
Post by buffalobossie »
The Great Silence UHD
Disc type: UHD
Disc ID: 9a052c27bfcbfb78534caaeb135965234d083170
Disc dump filename: MKB20_v82_Great_Silence_1B00.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1kBAWeF ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1IVB6Fd ... sp=sharing
The Great Silence BD
Disc type: BD ROM
Disc ID: 6fe270a60552ca9eac342effb11699f35abfe687
Disc dump filename: MKB_v82_Great_Silence_3ACA.tgz
MKB_RO.inf link: https://drive.google.com/file/d/10AsR6y ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1H60P6O ... sp=sharing
sandman_satx213
Post by sandman_satx213 »
Carrie
Disc type: UHD
Disc ID: CDA5359119D84B0DD99F6D68378C747767F0BE23
Disc dump filename: MKB20_v82_Carrie_UHD_1112
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/10Z6vt6 ... drive_link
Disc dump link: https://drive.google.com/file/d/1IjM3_o ... drive_link
Avatar The Way of The Water
Disc type: UHD
Disc ID: FDB33AF5C03AAA8F1A8B1CAA273E6B8CEF1F6BBD
Disc dump filename: MKB20_v77_AVATAR_THE_WAY_OF_WATER_A18D
MKB_RO.inf link: https://drive.google.com/file/d/1c6z4we ... drive_link
Disc dump link: https://drive.google.com/file/d/1Tb9gNz ... drive_link
MrPenguin
Post by MrPenguin »
sandman_satx213 wrote: Mon Jan 19, 2026 3:40 pm Disc dump filename: MKB20_v77_AVATAR_THE_WAY_OF_WATER_A18D
Can you upload the actual MKB_RO.inf file from your physical UHD disk please? The MKV_RO.inf file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable by anyone except MakeMKV itself. And besides, we already have the truncated file anyway because it's inside the TGZ file you have also provided...
