Public KeyDB Disc Submissions
sh3nanigans
Hello everyone, this is my first time posting here since I just came across a Japanese Bluray I can't rip with MakeMKV. Funnily enough disc 1 and disc 2 of this Bluray were no problem, but disc 3 tells me the following:
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213131341
I did my best but please let me know if any further info is needed.
Disc type: Blu-ray
Disc ID: 0x8D198262B001899A1356321B55E3D7888EDBA612
Disc dump filename: MKB_v82_AVXK_43554_6A8E
Drive: BD-RW BDR-UD03
Drive platform: Pioneer RS8510
Drive firmware: 2015-06-25
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://gofile.io/d/a351dc9f-4395-4a54- ... 87a804b96b
Disc dump link: https://gofile.io/d/a351dc9f-4395-4a54- ... 87a804b96b
Disc type: Blu-ray
Can you make these downloads accessible please?sh3nanigans wrote: Sat Jan 17, 2026 6:00 pm Have you verified that all submission links are accessible in incognito/private browsing? Yes
Tank Girl UHD - Vinegar Syndrome
Already in database...
Thank you.
Thank you.
The latest KEYDB.cfg file already contains this disk.
sh3nanigans
So sorry, must have copied it from the wrong account. Should be public now!MrPenguin wrote: Sat Jan 17, 2026 7:16 pmCan you make these downloads accessible please?sh3nanigans wrote: Sat Jan 17, 2026 6:00 pm Have you verified that all submission links are accessible in incognito/private browsing? Yes
seakalehorsecomposer
Hi folks,
Disc type: UHD
Disc ID: f76aea38f56184191bb0090c6ab7608b80178f12
Disc dump filename: MKB20_v76_SCOTTPILGRIM_UPK1_3B09
Drive: BD-RE PIONEER BD-RW BDR-UD04 1.14
Drive firmware: 2020-06-15
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.proton.me/urls/6271WX3D0M#lq6FxHU4tdn8
Disc dump link: https://drive.proton.me/urls/QJJACDXRC0#VUof8EcDClXz
Disc type: UHD
keydb_helper
Hey AFK88L, the instructions that I wrote in that post were intended for AACS 2.0 discs rather than AACS 1.0. To be honest, I'm actually surprised that MakeMKV v1.18.2 generated a disc dump for an AACS 1.0 MKBv68 disc. MakeMKV v1.18.2 has native support for AACS 1.0 MKBv1-MKBv81 without the need for external/downloaded title specific keys. So it really should've used one of the AACS 1.0 device/processing keys bundled with MakeMKV instead of generating that disc dump.AFK88L wrote: Sat Jan 17, 2026 1:20 pm The below release appears to be missing from the public keydb. I would like to contribute, however for this disc I found it was already natively supported by MakeMKV so the program wouldn't create a disc dump.
I tried following the instructions in this post to force MakeMKV to create the dump, but it would not work for me.
I believe the VM aspect is not relevant here.AFK88L wrote: Sat Jan 17, 2026 1:20 pm I eventually got a disc dump generated by MakeMKV (below) but only when also running in a VM (Win10 for the VM, vs. Win11 on my main host... not sure if that has a bearing).
The main components of a disc dump file are:AFK88L wrote: Sat Jan 17, 2026 1:20 pm In light of this, for discs MakeMKV already natively supports but are missing from the public keydb, what is the process? Is there any consistent way to force MakeMKV to create a disc dump so we can submit the required files?
1. discatt.dat - Contains the volume ID
2. MKB_RO.inf - Contains the encrypted media key (MK) for your disc and the media key verification data used to validate the media key
3. Unit_Key_RO.inf - Contains the encrypted unit key(s)
4. kv.dat - Contains several encrypted aligned units (6,144 bytes each) from one or more M2TS files. It is important that these are read after bus encryption has been disabled.
Technically all of the title-specific keys can be derived with only the first three files. The kv.dat file is used to validate the resultant unit keys. This also has the effect of validating the volume ID (VID) and the volume unique key (VUK). Any small M2TS file from the disc can be used as a substitute for the kv.dat file as long as bus encryption has been disabled before copying the file.
Rough outline:AFK88L wrote: Sat Jan 17, 2026 1:20 pm Alternatively, is there another way to manually create a disc dump without MakeMKV? What files are actually required in the tgz to have it added to the public keydb?
1. Use MakeMKV to start creating an encrypted folder backup of a disc
2. Stop the backup once the discatt.dat/discattd.dat file has been created and at least one M2TS file has been copied
3. Make a new folder for your synthetic disc dump
4. Copy the discatt.dat file and the smallest M2TS file out of the (incomplete) encrypted backup folder into your synthetic disc dump folder
5. Copy the entire AACS directory from your disc into your synthetic disc dump folder
6. Zip up the synthetic disc dump folder, upload it to a file host and post a link here
The process isn't too streamlined but there will be improvements made throughout this year as some new tools and drive firmware options become available.
FindVUK on Windows can also be used to generate MKBv1-MKBv81 AACS 1.0 disc keys without MakeMKV or any other commercial tool as long as your drive hasn't been exposed to AACS MKBv82
Hey keydb_helper, thanks so much for your detailed response - this is great information.keydb_helper wrote: Sun Jan 18, 2026 6:25 amThe main components of a disc dump file are:AFK88L wrote: Sat Jan 17, 2026 1:20 pm In light of this, for discs MakeMKV already natively supports but are missing from the public keydb, what is the process? Is there any consistent way to force MakeMKV to create a disc dump so we can submit the required files?
Also, thank you for adding that entry to the public keydb so quickly. I have re-checked and confirmed the disc is identified now and working correctly when just using the public keydb (not MakeMKV). Clearly the dump I managed to generate did actually work after all! (I also don't quite know how I got MakeMKV to do that...)
I'll be sure to follow these instructions next time I come across a disc missing from the public keydb but supported in MakeMKV.keydb_helper wrote: Sun Jan 18, 2026 6:25 amRough outline:AFK88L wrote: Sat Jan 17, 2026 1:20 pm Alternatively, is there another way to manually create a disc dump without MakeMKV? What files are actually required in the tgz to have it added to the public keydb?
Thanks for the info. This may not be an option for me however? Checking "Drive Information" in MakeMKV shows "Highest AACS version: 82" so I guess it has been exposed to AACS MKBv82 already.keydb_helper wrote: Sun Jan 18, 2026 6:25 am FindVUK on Windows can also be used to generate AACS 1.0 disc keys without MakeMKV or any other commercial tool as long as your drive hasn't been exposed to AACS MKBv82
keydb_helper
Thanks to everyone who provided new disc dump files. The following disc variants have been added to the public keydb:
MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAB
MKB20_v82_Black_Phone_2_F484
MKB20_v82_FINAL_DESTINATION_BLOODLINES_5C4C
MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8
MKB20_v82_The_Gambler_D3D3
MKB20_v82_TRON-_ARES_F26E
MKB20_v82_Universal_Soldier_ED18
MKB_v82_AMERICAN_YAKUZA_511C
MKB_v82_年下童貞くんに翻弄されてます_Disc1_8DEC
MKB_v82_年下童貞くんに翻弄されてます_Disc2_F11E
MKB_v82_雨上がりの僕らについて Disc1_249A
MKB_v82_雨上がりの僕らについて Disc2_51B8
MKB_v82_雨上がりの僕らについて Disc3_ADEE
sh3nanigans
Thank you so much, worked like a charm now!keydb_helper wrote: Sun Jan 18, 2026 10:54 am Thanks to everyone who provided new disc dump files. The following disc variants have been added to the public keydb:Code: Select all
MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAB MKB20_v82_Black_Phone_2_F484 MKB20_v82_FINAL_DESTINATION_BLOODLINES_5C4C MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8 MKB20_v82_The_Gambler_D3D3 MKB20_v82_TRON-_ARES_F26E MKB20_v82_Universal_Soldier_ED18 MKB_v82_AMERICAN_YAKUZA_511C MKB_v82_AVXK_43554_6A8E MKB_v82_年下童貞くんに翻弄されてます_Disc1_8DEC MKB_v82_年下童貞くんに翻弄されてます_Disc2_F11E MKB_v82_雨上がりの僕らについて Disc1_249A MKB_v82_雨上がりの僕らについて Disc2_51B8 MKB_v82_雨上がりの僕らについて Disc3_ADEE
Cheetah123
Disc type: UHD
Disc ID: c45ec7fc4f95fde09262a51a6280731fb46b8f13
Disc dump filename: MKB20_v82_Wolf_Children_C9FC
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1qWGrj7 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ddNYZJ ... sp=sharing
Thank you so much!
Drive: BD-RE BU40N
Thank you so much!
Disc type: UHD
Disc ID: 0xEDA4808AE29669DF7359119A3AA5740C9D5F123B
Disc dump filename: MKB20_v76_The_Hobbit-_An_Unexpected_Journey_(Extended)_9757
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1S9dbiV ... drive_link
Disc dump link: https://drive.google.com/file/d/1i0AWZm ... drive_link
Disc type: UHD
Disc ID: 0x8620D8025D1A3E99B4EFA1267E0B7572E2DF439B
Disc dump filename: MKB20_v76_The_Hobbit-_The_Desolation_of_Smaug_(Extended)_1111
MKB_RO.inf link: https://drive.google.com/file/d/1K63kB3 ... drive_link
Disc dump link: https://drive.google.com/file/d/1w3rNOJ ... drive_link
Disc type: UHD
Disc ID: 0x245F9D281F97925002765A858C495558428F69BF
Disc dump filename: MKB20_v76_The_Hobbit-_The_Battle_of_the_Five_Armies_(Extended)_2CC5
MKB_RO.inf link: https://drive.google.com/file/d/1V32RZV ... drive_link
Disc dump link: https://drive.google.com/file/d/1mmeghE ... drive_link
Many thanks!
Disc type: UHD
Disc type: UHD
Many thanks!
FootFungus07
Hey FootFungus07, thanks for remembering the MKB_RO.inf file but I think you forgot the actual disc dump file. Feel free to post it whenever you get a chance.FootFungus07 wrote: Wed Jan 14, 2026 6:52 pm Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file: ...
Oh jeeze, total brain skip on my end - here it is, it's kinda small though, not sure if this is normal, really not used to seeing MKV spit out TGZ codes for standard blu-rays
MKB_v82_DRAGONFLY_SQUADRON_3D_92AC.tgz
https://drive.google.com/file/d/1lZV5HE ... drive_link
keydb_helper
No stress, it is typical for AACS 1.0 disc dumps to be considerably smaller than AACS 2.0/2.1 disc dump files.FootFungus07 wrote: Mon Jan 19, 2026 12:26 am Oh jeeze, total brain skip on my end - here it is, it's kinda small though, not sure if this is normal, really not used to seeing MKV spit out TGZ codes for standard blu-rays
Thanks to everyone who provided new disc dump files. The following discs have been added to the public keydb:
Alien 40th Anniversary UHD
Disc type:UHD
Disc ID:0x12004AEB144A21A2FE76EEF4127CFD38C2B5C19C
Disc dump filename:Alien 40th UHD Disc Dump with MKB_RO
Drive: BD-RE BU40N
Drive firmware:1.03
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):Yes
Disc dump link: https://1drv.ms/f/c/1ad098b4ac28ce7a/Ig ... w?e=UdybQs
Disc type:UHD
Drive: BD-RE BU40N
Drive firmware:1.03
