Public KeyDB Disc Submissions
honglong
Post by honglong »
Here are two .tgz files for HD anime BDs:
Learning the Hard Way BDMV from MediaBlasters: https://drive.google.com/file/d/1-pmagz ... sp=sharing
Insatiable BDMV from MediaBlasters: https://drive.google.com/file/d/1JkS9Vq ... sp=sharing
keydb_helper
Post by keydb_helper »
The following new disc variants have been added to the public keydb:
MKB20_v82_LIFE_FORCE_INT_0E8A
MKB20_v82_Married_to_the_Mob_B809
MKB20_v82_TOGETHER_5E36
Public KeyDB Disc Submissions KeyDB Download
taroyamada
Post by taroyamada »
I’m getting an error with AACS v82.
Is this AACS dump information sufficient?
https://drive.google.com/drive/folders/ ... share_link
kasko
Post by kasko »
MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8
MrPenguin
Post by MrPenguin »
kasko wrote: Sat Jan 17, 2026 8:49 am MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8
Could you provide the actual TGZ dump file please? The Unit_Key_RO.inf and MKB_RO.inf files are not enough by themselves. At the minimum, you would also need to provide a MakeMKV discatt.dat file that contains crucial disk metadata.
kasko
Post by kasko »
Sorry, I uploaded the wrong file. The correct one is here now.
herrgnatz
Post by herrgnatz »
Disc type: BD-ROM UHD
Disc ID: 8c1abf9b1be74156a84dff8e03aacdc65aa982b0
Disc dump filename: MKB20_v82_FDB
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
LibreDrive status: Enabled
MKB_RO.inf link: https://gofile.io/d/Whf0wh
Disc dump link: https://gofile.io/d/HovK0f
It seems the Disc ID is already present in the latest keydb file. I submit this anyway since this is the only disc I can't open or backup.
AFK88L
Post by AFK88L »
The below release appears to be missing from the public keydb. I would like to contribute, however for this disc I found it was already natively supported by MakeMKV so the program wouldn't create a disc dump.
I tried following the instructions in this post to force MakeMKV to create the dump, but it would not work for me.
I eventually got a disc dump generated by MakeMKV (below) but only when also running in a VM (Win10 for the VM, vs. Win11 on my main host... not sure if that has a bearing). It still would not consistently create the dump though (noting: still following the instructions to disable internet access and remove the _private_data.tar and keydb.cfg files)... only after opening and closing MakeMKV numerous times would it then sometimes create the disc dump.
In light of this, for discs MakeMKV already natively supports but are missing from the public keydb, what is the process? Is there any consistent way to force MakeMKV to create a disc dump so we can submit the required files?
Alternatively, is there another way to manually create a disc dump without MakeMKV? What files are actually required in the tgz to have it added to the public keydb?
Anyway, hopefully the below is usable to add to the public keydb.
The Lord of the Rings: The War of the Rohirrim (2024) Blu-ray
Disc type: BD-ROM
Disc ID: 0x3F40396D3A34E9D73D5C4FD5FF9FBCEC420AC9E0
Disc dump filename: MKB_v68_LOTR_THE_WAR_OF_THE_ROHIRRIM_8358.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.05
MKB_RO.inf link: https://drive.google.com/file/d/1dK6ghj ... sp=sharing
Disc dump link: https://drive.google.com/file/d/17eKbZz ... sp=sharing
GFly91
Post by GFly91 »
Greetings here is my TRON ARES dump file:
https://drive.google.com/file/d/1fUDDHF ... sp=sharing
MKVDUDE
Post by MKVDUDE »
Disc type: BD
Disc dump filename:MKB_v82_AMERICAN_YAKUZA_511C.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-1Y0m0qKXas
Many thanks!
Quarter-Tank
Post by Quarter-Tank »
First time submission. I believe I have everything...
Disc type:UHD
Disc ID:0xC1A8BFCE5CE047336D064C2F55B2FDAD87D221B1
Disc dump filename: MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAB
Drive: BD-RW BDR-XD06U
Drive firmware: 1.11/ID69
MKB_RO.inf link: https://drive.google.com/file/d/1MM-bAG ... drive_link
Disc dump link: https://drive.google.com/file/d/1vnDva5 ... drive_link
sh3nanigans
Post by sh3nanigans »
Hello everyone, this is my first time posting here since I just came across a Japanese Bluray I can't rip with MakeMKV. Funnily enough disc 1 and disc 2 of this Bluray were no problem, but disc 3 tells me the following:
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
DEBUG: Code 0 at K/7I6&O",`|u5 8d:213131341
I did my best but please let me know if any further info is needed.
Disc type: Blu-ray
Disc ID: 0x8D198262B001899A1356321B55E3D7888EDBA612
Disc dump filename: MKB_v82_AVXK_43554_6A8E
Drive: BD-RW BDR-UD03
Drive platform: Pioneer RS8510
Drive firmware: 2015-06-25
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://gofile.io/d/a351dc9f-4395-4a54- ... 87a804b96b
Disc dump link: https://gofile.io/d/a351dc9f-4395-4a54- ... 87a804b96b
MrPenguin
Post by MrPenguin »
sh3nanigans wrote: Sat Jan 17, 2026 6:00 pm Have you verified that all submission links are accessible in incognito/private browsing? Yes
Can you make these downloads accessible please?
razer
Post by razer »
Tank Girl UHD - Vinegar Syndrome
Already in database...
Thank you.
MrPenguin
Post by MrPenguin »
razer wrote: Sun Jan 18, 2026 12:24 am MKB_RO.zip
MKB20_v82_VSU015UHD_263F.tgz
The latest KEYDB.cfg file already contains this disk.
