Public KeyDB Disc Submissions
FrankGrimes2769
Post by FrankGrimes2769 »
MrPenguin wrote:
Fri Jan 16, 2026 3:33 pm
FrankGrimes2769 wrote:
Fri Jan 16, 2026 2:27 pm
MKB_RO.inf link: https://drive.google.com/file/d/1sNKsm9 ... drive_link
You have actually provided the disk's Unit_Key_RO.inf instead of its MKB_RO.inf, but I'm hoping it won't matter in this particular case...
It did work. Thank you again for the assist. This forum is a blessing. Awesome stuff!
zarcone
Post by zarcone »
Lionsgate
Cabin Fever Unrated (2003) - BD-Rom
Disc type: BD ROM
Disc ID: 1ffd3699f4fbe0147dedfc4a4a706ce0c5e1af72
Disc dump filename: MKB_v82_Cabin_Fever_Unrated_Director's_Cut_DE94
Drive: BD-RE BP50NB40
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://gofile.io/d/R5JOAI
Disc dump link: https://gofile.io/d/DuayhP
Rander
Post by Rander »
keydb_helper wrote:
Tue Jan 13, 2026 2:42 am
Thanks to everyone who provided new disc dump files. It is great to see folks remembering to include the correct disc ID.
The following disc variants have been added to the public keydb:
MKB_v82_28_Years_Later_B0CC
Okay, I'm lost...
I downloaded the new keydb.cfg (2026-01-16 19:08:37), but MakeMKV still says the disc is unknown - and now, the dump file name has changed to MKB_v82_28_Years_Later_B0CD (last letter changed).
Grepping the file for the string "MKB_v82_28_Years_Later_B0CC" finds nothing. The DiscID (5ea38005be385f5be9fdcea618c3485eb0f762b8) is in the file, but with another title (Peking Opera Blues UHD).
Oh, and I can only get MakeMKV to generate the dump file by choosing to close it when the status says "Parsing file: /AACS/ContenHash001.tbl" - it I just leave it, there is no dump file. I literally have to clik the X to close the program when it show this status for it to generate the dump file...
Can someone explain to me what is going on here?
keydb_helper
Post by keydb_helper »
Rander wrote:
Fri Jan 16, 2026 7:28 pm
Hey Rander, the disc ID of your 28 Years Later disc is 0x3D72113E6E8CA0B8427D412DFAC938EF692BB82B. You seem to have accidentally copied the disc ID posted by user dave_or_did:
dave_or_did wrote:
Sun Jan 11, 2026 11:55 am
dave_or_did wrote:
Sat Jan 10, 2026 8:47 am
My Pioneer disc dump didn't get added, so I'm trying again:
Peking Opera Blues - Arrow UHD
Disc Label: Peking Opera Blues UHD
Here's the Disc ID - 5ea38005be385f5be9fdcea618c3485eb0f762b8
Rander wrote:
Mon Jan 12, 2026 1:55 pm
Disc ID: 5ea38005be385f5be9fdcea618c3485eb0f762b8
Disc dump filename: MKB_v82_28_Years_Later_B0CC
I've double checked and your particular disc variant fully supported by the public keydb. I'd recommend verifying that you have placed the latest keydb.cfg file in the same directory that MakeMKV places its generated disc dump files.
The following new disc variants have been added to the public keydb:
MKB20_v77_Altered_61D0
mkb20_v82_null_22a4
MKB20_v82_SHE_KILLED_IN_ECSTASY_UHD_3235
MKB20_v82_VSU015UHD_263F
honglong
Post by honglong »
Here are two .tgz files for HD anime BDs:
Learning the Hard Way BDMV from MediaBlasters: https://drive.google.com/file/d/1-pmagz ... sp=sharing
Insatiable BDMV from MediaBlasters: https://drive.google.com/file/d/1JkS9Vq ... sp=sharing
keydb_helper
MKB20_v82_LIFE_FORCE_INT_0E8A
MKB20_v82_Married_to_the_Mob_B809
MKB20_v82_TOGETHER_5E36
taroyamada
Post by taroyamada »
I’m getting an error with AACS v82.
Is this AACS dump information sufficient?
https://drive.google.com/drive/folders/ ... share_link
kasko
Post by kasko »
MKB20_v82_JURASSIC_WORLD_REBIRTH_55A8
MrPenguin
Post by MrPenguin »
kasko wrote:
Sat Jan 17, 2026 8:49 am
Could you provide the actual TGZ dump file please? The Unit_Key_RO.inf and MKB_RO.inf files are not enough by themselves. At the minimum, you would also need to provide a MakeMKV discatt.dat file that contains crucial disk metadata.
kasko
Post by kasko »
Sorry, I uploaded the wrong file. The correct one is here now.
herrgnatz
Post by herrgnatz »
Disc type: BD-ROM UHD
Disc ID: 8c1abf9b1be74156a84dff8e03aacdc65aa982b0
Disc dump filename: MKB20_v82_FDB
Drive: BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link: https://gofile.io/d/Whf0wh
Disc dump link: https://gofile.io/d/HovK0f
It seems the Disc ID is already present in the latest keydb file. I submit this anyway since this is the only disc I can't open or backup.
AFK88L
Post by AFK88L »
The below release appears to be missing from the public keydb. I would like to contribute, however for this disc I found it was already natively supported by MakeMKV so the program wouldn't create a disc dump.
I tried following the instructions in this post to force MakeMKV to create the dump, but it would not work for me.
I eventually got a disc dump generated by MakeMKV (below) but only when also running in a VM (Win10 for the VM, vs. Win11 on my main host... not sure if that has a bearing). It still would not consistently create the dump though (noting: still following the instructions to disable internet access and remove the _private_data.tar and keydb.cfg files)... only after opening and closing MakeMKV numerous times would it then sometimes create the disc dump.
In light of this, for discs MakeMKV already natively supports but are missing from the public keydb, what is the process? Is there any consistent way to force MakeMKV to create a disc dump so we can submit the required files?
Alternatively, is there another way to manually create a disc dump without MakeMKV? What files are actually required in the tgz to have it added to the public keydb?
Anyway, hopefully the below is usable to add to the public keydb.
The Lord of the Rings: The War of the Rohirrim (2024) Blu-ray
Disc type: BD-ROM
Disc ID: 0x3F40396D3A34E9D73D5C4FD5FF9FBCEC420AC9E0
Disc dump filename: MKB_v68_LOTR_THE_WAR_OF_THE_ROHIRRIM_8358.tgz
Drive: BD-RE BH16NS55
Drive firmware: 1.05
MKB_RO.inf link: https://drive.google.com/file/d/1dK6ghj ... sp=sharing
Disc dump link: https://drive.google.com/file/d/17eKbZz ... sp=sharing
GFly91
Post by GFly91 »
Greetings here is my TRON ARES dump file:
https://drive.google.com/file/d/1fUDDHF ... sp=sharing
MKVDUDE
Post by MKVDUDE »
Disc type: BD
Disc dump filename:MKB_v82_AMERICAN_YAKUZA_511C.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-1Y0m0qKXas
Many thanks!
Quarter-Tank
Post by Quarter-Tank »
First time submission. I believe I have everything...
Disc type:UHD
Disc ID:0xC1A8BFCE5CE047336D064C2F55B2FDAD87D221B1
Disc dump filename: MKB20_v77_Aquaman_and_the_Lost_Kingdom_4AAB
Drive: BD-RW BDR-XD06U
Drive firmware: 1.11/ID69
MKB_RO.inf link: https://drive.google.com/file/d/1MM-bAG ... drive_link
Disc dump link: https://drive.google.com/file/d/1vnDva5 ... drive_link
