Vampyros Lesbos UHD Dump Submitted (USA / Severin)
MKB20_v82_VAMPYROS_LESBOS_UHD_BB53.tgz
Re: Vampyros Lesbos UHD Dump Submitted (USA / Severin)
.tgz dump file can be downloaded here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-Z9QPWyHaev
Can you also zip the AACS/MKB_RO.inf file from your physical UHD disk and upload it please? The MKB_RO.inf file inside your TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
keydb_helper
As MrPenguin noted, the MKB_RO.inf file will be required for your disc. I'm not on a Mac right now, but I think you should be able to click on "VAMPYROS_LESBOS_UHD" within Finder to browse the disc folder structure. From there, you should be able to open up the AACS folder and it will contain the MKB_RO.inf file.
If you can't easily see "VAMPYROS_LESBOS_UHD" in Finder, you may need to first navigate to the "Volumes" section within Finder.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
disc AACS folder and .tgz dump file here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-AMx7TsSYFO
