Thanks. So it looks like my version is not included.keydb_helper wrote: Thu Jan 15, 2026 11:58 am All three of the disc dumps provided by Browneye9999 were added to the public keydb on December 22.
Public KeyDB Disc Submissions
extranet
keydb_helper
If you have configured MakeMKV to use the public keydb and your discs still aren't working that would be a fair assumption.
Feel free to follow the submission template in the opening post of this thread if you'd like your discs to be added to the public keydb.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
LichLordJay
Re: Public KeyDB Disc Submissions - Bleach TYBW Part 3
My apologies if I didn't format this correctly, it's my first time posting here.
Disc 1:
Label: Bleach TYBW S3 D1
Timestamp: 2025-10-15 13:27:23
Protection: AACS v82
Data capacity: 45.99 Gb
Disc type: BD-ROM
Number of layers: 2
Disc 2:
Label: Bleach TYBW S3 D2
Timestamp: 2025-10-15 14:16:27
Data capacity: 46.26 Gb
Disc type: BD-ROM
Number of layers: 2
Dump files here - https://drive.google.com/drive/folders/ ... sp=sharing
Thank you!
Disc 1:
Disc type: BD-ROM
Number of layers: 2
Disc 2:
Disc type: BD-ROM
Number of layers: 2
Thank you!
mattmak464
Disc type: UHD
Disc ID: 0xC6F66EB4DE00D7D5F6A38A8ED2ACF20BAC1907AE
Disc dump filename: MKB20_v82_John_Carpenters_Vampires_DB70
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/12RtpAd ... share_link
Disc dump link: https://drive.google.com/file/d/1pYqSv5 ... share_link
Drive: BD-RE BU40N
RedMax12
Disc type: BD
Disc dump filename: MKB_v82_GOODBYE_COLUMBUS_E3F0
Drive: BD-RE BP60NB10
Drive firmware: 1.02
MKB_RO.inf link: https://gofile.io/d/qc41yD
Disc dump link: https://gofile.io/d/ONLC8j
Rauthr
Disc type: UHD
Disc ID: 0xE20694C8FD2773DB97A941024415E39B32FE0990
Disc dump filename: MKB20_v61_John_Wick_75FB
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1OxGNqj ... drive_link
Disc dump link: https://drive.google.com/file/d/1H8V35h ... drive_link
Disc type: UHD
Disc ID: 0x77FFD4A2F28D457FFC590F0DAF9AFF3CC4080D47
Disc dump filename: MKB20_v68_John_Wick_3-_Parabellum_91BF
MKB_RO.inf link: https://drive.google.com/file/d/1-K4VpL ... drive_link
Disc dump link: https://drive.google.com/file/d/1t8ugns ... drive_link
Thank you so much!
Disc type: UHD
Thank you so much!
xenago
Disc 1:
Disc type: UHD
Disc ID: 7b6ce999cc0969fabb6de71f9f70c5a5b8906394
Disc dump filename: MKB20_v82_Wicked-_For_Good_5DA4.tgz
Drive: WH16NS58
Drive firmware: 1.V5
MKB_RO.inf link: https://gofile.io/d/BTeaS8
Disc dump link: https://gofile.io/d/VYszx2
Disc 2:
Disc type: BD
Disc ID: 3f37ce2a5ea62eae58d793175f313ae9e1630e6b
Disc dump filename: MKB_v82_Wicked-_For_Good_A7F2.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://gofile.io/d/dm4Nki
Disc dump link: https://gofile.io/d/r3x5oE
Disc type: UHD
Drive: WH16NS58
Disc 2:
Disc type: BD
Drive: BW-16D1HT
keydb_helper
Hey LichLordJay, welcome to the forum. Both of your discs were actually added to the public earlier in the week. Check out the instructions I linked in the opening post of this thread to configure MakeMKV. Once you have configured MakeMKV correctly, you'll be able to decrypt your discs. For any future submissions, please refer to the posts from mattmak464, Rauthr, and xenago as great submission examples.LichLordJay wrote: Thu Jan 15, 2026 10:32 pm My apologies if I didn't format this correctly, it's my first time posting here.
The following disc variants have been added to the public keydb:
MKB20_v65_Robin_Hood_EE39
MKB20_v77_OnceUponATimeInTheWest_1E3F
MKB20_v77_UHD_JRMB_FA99
MKB20_v82_310_TO_YUMA_9F3C
mkb20_v82_dantes_peak_e2da
MKB20_v82_null_99D6
MKB20_v82_One_Battle_After_Another_6D10
MKB20_v82_VAMPYROS_LESBOS_UHD_BB53
FrankGrimes2769
Disc type: UHD Blu-ray
Disc ID: 4fa40f411aabc46852b1f255811b497c0f6e8e21
Disc dump filename: MKB20_v61_The_Incredible_Hulk_0FC3
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: https://drive.google.com/file/d/1sNKsm9 ... drive_link
Disc dump link: https://drive.google.com/file/d/1TzwxMY ... drive_link
Thanks once again in Advance!!!
Drive: BD-RE BU40N
MrPenguin
You have actually provided the disk's Unit_Key_RO.inf instead of its MKB_RO.inf, but I'm hoping it won't matter in this particular case...FrankGrimes2769 wrote: Fri Jan 16, 2026 2:27 pm MKB_RO.inf link: https://drive.google.com/file/d/1sNKsm9 ... drive_link
FrankGrimes2769
I sure did. I will test if it still works. If it does not, I will resubmit. Sorry!! My Bad!
FrankGrimes2769
MrPenguin wrote: Fri Jan 16, 2026 3:33 pmYou have actually provided the disk's Unit_Key_RO.inf instead of its MKB_RO.inf, but I'm hoping it won't matter in this particular case...FrankGrimes2769 wrote: Fri Jan 16, 2026 2:27 pm MKB_RO.inf link: https://drive.google.com/file/d/1sNKsm9 ... drive_link
It did work. Thank you again for the assist. This forum is a blessing. Awesome stuff!
zarcone
Lionsgate
Cabin Fever Unrated (2003) - BD-Rom
Disc type: BD ROM
Disc ID: 1ffd3699f4fbe0147dedfc4a4a706ce0c5e1af72
Disc dump filename: MKB_v82_Cabin_Fever_Unrated_Director's_Cut_DE94
Drive: BD-RE BP50NB40
MKB_RO.inf link: https://gofile.io/d/R5JOAI
Disc dump link: https://gofile.io/d/DuayhP
Disc type: BD ROM
Rander
Okay, I'm lost...keydb_helper wrote: Tue Jan 13, 2026 2:42 am Thanks to everyone who provided new disc dump files. It is great to see folks remembering to include the correct disc ID.
The following disc variants have been added to the public keydb:Code: Select all
MKB_v82_28_Years_Later_B0CC
I downloaded the new keydb.cfg (2026-01-16 19:08:37), but MakeMKV still says the disc is unknown - and now, the dump file name has changed to MKB_v82_28_Years_Later_B0CD (last letter changed).
Grepping the file for the string "MKB_v82_28_Years_Later_B0CC" finds nothing. The DiscID (5ea38005be385f5be9fdcea618c3485eb0f762b8) is in the file, but with another title (Peking Opera Blues UHD).
Oh, and I can only get MakeMKV to generate the dump file by choosing to close it when the status says "Parsing file: /AACS/ContenHash001.tbl" - it I just leave it, there is no dump file. I literally have to clik the X to close the program when it show this status for it to generate the dump file...
Can someone explain to me what is going on here?
keydb_helper
Hey Rander, the disc ID of your 28 Years Later disc is 0x3D72113E6E8CA0B8427D412DFAC938EF692BB82B. You seem to have accidentally copied the disc ID posted by user dave_or_did:Rander wrote: Fri Jan 16, 2026 7:28 pm Grepping the file for the string "MKB_v82_28_Years_Later_B0CC" finds nothing. The DiscID (5ea38005be385f5be9fdcea618c3485eb0f762b8) is in the file, but with another title (Peking Opera Blues UHD).
dave_or_did wrote: Sun Jan 11, 2026 11:55 amHere's the Disc ID - 5ea38005be385f5be9fdcea618c3485eb0f762b8dave_or_did wrote: Sat Jan 10, 2026 8:47 am My Pioneer disc dump didn't get added, so I'm trying again:
Peking Opera Blues - Arrow UHD
Disc Label: Peking Opera Blues UHD
Rander wrote: Mon Jan 12, 2026 1:55 pm Disc ID: 5ea38005be385f5be9fdcea618c3485eb0f762b8
Disc dump filename: MKB_v82_28_Years_Later_B0CC
I've double checked and your particular disc variant fully supported by the public keydb. I'd recommend verifying that you have placed the latest keydb.cfg file in the same directory that MakeMKV places its generated disc dump files.
The following new disc variants have been added to the public keydb:
MKB20_v77_Altered_61D0
mkb20_v82_null_22a4
MKB20_v82_SHE_KILLED_IN_ECSTASY_UHD_3235
MKB20_v82_VSU015UHD_263F
