Flashing BD-RE BU40N Firmware 1.05
tobyreid00
Post by tobyreid00 » Thu Jan 15, 2026 1:44 am
Hello all & thank you in advance for the help. I have a Product: BD-RE BU40N Revision: 1.05 which came in a Verbatim 43888. I have read through all of the documentation (2026 UHD thread & SDFlasher thread) AI assisted searching also. According to my AI assisted searches, it will work to flash this drive, but I have not found a post from a person who actually flashed the BU40N 1.03MK firmware to this drive w/this 1.05 firmware... I found 1.04 firmware examples, but not 1.05. If anyone has, please let me know. Or, if you know this won't work, please let me know that too.
Here is the full drive info from makemkv:
Revision: 1.05
Serial number:
Highest AACS version: 31
Re: Flashing BD-RE BU40N Firmware 1.05
Post by MartyMcNuts » Thu Jan 15, 2026 5:16 am
tobyreid00 wrote: Thu Jan 15, 2026 1:44 am Hello all & thank you in advance for the help. I have a Product: BD-RE BU40N Revision: 1.05 which came in a Verbatim 43888. I have read through all of the documentation (2026 UHD thread & SDFlasher thread) AI assisted searching also. According to my AI assisted searches, it will work to flash this drive, but I have not found a post from a person who actually flashed the BU40N 1.03MK firmware to this drive w/this 1.05 firmware... I found 1.04 firmware examples, but not 1.05. If anyone has, please let me know. Or, if you know this won't work, please let me know that too.
Revision: 1.05
Serial number:
Yes, no different. I've flashed over a thousand of these Verbatim's with the BU40N v1.05.
tobyreid00
Post by tobyreid00 » Fri Jan 16, 2026 10:07 pm
Thank you MartyMcNuts! (Great pseudonym btw)
SalsaForte
Post by SalsaForte » Wed Jan 21, 2026 3:56 am
I'm in the same situation. So, basically it is 100% safe and it's working to downgrade the drive from 1.05 to 1.04 (MK).
The last answer doesn't explicitly mention those thousands of Verbatim drive were downgraded.
I better be safe than sorry.
Post by MartyMcNuts » Wed Jan 21, 2026 5:27 am
SalsaForte wrote: Wed Jan 21, 2026 3:56 am I'm in the same situation. So, basically it is 100% safe and it's working to downgrade the drive from 1.05 to 1.04 (MK).
Yes, of course they were downgraded. There is no such thing as BU40N 1.05-MK firmware!
BU40N 1.04-MK is not the recommended firmware. I flash them to BU40N 1.03-MK to remove the firmware encryption then to BU40N 1.00 for wider UHD ripping software compatibility. If you only use MakeMKV or Xreveal for ripping UHD discs you can leave it on BU40N 1.03-MK.
SalsaForte
Post by SalsaForte » Wed Jan 21, 2026 12:34 pm
MartyMcNuts wrote: Wed Jan 21, 2026 5:27 am Yes, of course they were downgraded. There is no such thing as BU40N 1.05-MK firmware!
Then, I'll need to find the 1.03-MK firmware. The link available on this very forum led me to a .zip file containing 1.04, not 1.03. I may have misunderstood or misread something.
And can you point me to information on why 1.04-MK isn't recommended? Curious to understand more about this.
Thanks Marty! Your feedback is appreciated.
Post by MartyMcNuts » Wed Jan 21, 2026 10:20 pm
SalsaForte wrote: Wed Jan 21, 2026 12:34 pm
Newer does not mean better. After extensive testing, us drive sellers determined that v1.03-MK was the better of the two firmware version for reading UHD discs. Personally, I downgrade all BU40N's to v1.00 for wider UHD ripping software compatibility as the MK firmware only works with MakeMKV and Xreveal for UHD discs.
If you are looking in the MK firmware pack, 1.03-MK is in the "old" folder. If you grab my "all you need" firmware pack from the same post where you get the SDFtool Flasher, you will also find it.
SalsaForte
Post by SalsaForte » Thu Jan 22, 2026 11:52 pm
MartyMcNuts wrote: Wed Jan 21, 2026 10:20 pm Newer does not mean better. After extensive testing, us drive sellers determined that v1.03-MK was the better of the two firmware version for reading UHD discs. Personally, I downgrade all BU40N's to v1.00 for wider UHD ripping software compatibility as the MK firmware only works with MakeMKV and Xreveal for UHD discs.
Currently ripping my first 4K UHD disk (TENET).
My archiving journey can start.
chocolate27
Post by chocolate27 » Fri Jul 10, 2026 6:41 pm
Hola MartyMcNuts me podrías echar una mano con mi unidad verbatim UHD?
No e flasheado nunca una unidad y hablaís de meter primero una version y despues otra y no veo como hacerlo ni el software que debo usar.
Me ayudas paso a paso? por favor.
Saludos y gracias de antemano.
Hi MartyMcNuts, could you give me a hand with my Verbatim UHD drive?
I've never flashed a drive before; you guys talk about installing one version first and then another, but I don't see how to do it or what software I need to use.
Could you help me step-by-step, please?
Regards and thanks in advance.
Post by MartyMcNuts » Sat Jul 11, 2026 5:32 am
chocolate27 wrote: Fri Jul 10, 2026 6:41 pm Hola MartyMcNuts me podrías echar una mano con mi unidad verbatim UHD?
The easiest way is to use SDFtool Flasher (Windows only): viewtopic.php?p=94848#p94848 The first post contains the download links for both the tool and my firmware pack.
Otherwise you can purchase a flasher. See my signature.
AstralWanderer
Post by AstralWanderer » Sun Jul 12, 2026 7:52 pm
A well-written guide on flashing UHD drives (which refers back to relevant threads here) for Windows and Mac systems can be found at:
Reelbars.com: Flash UHD Drives for MakeMKV: LG BP60NB10, BP50NB40, ASUS BW-16D1HT, WH16NS60
chocolate27
Post by chocolate27 » Mon Jul 13, 2026 10:47 pm
Thanks, I managed to flash my LG 4K Blu-ray drive using the tool and the files. :D :)
