One Battle After Another UHD Dump File
tricolorSystems
Post by tricolorSystems »
I pre-ordered and it arrived early.
MrPenguin
Re: One Battle After Another UHD Dump File
Post by MrPenguin »
tricolorSystems wrote:
Wed Jan 14, 2026 8:04 am
Your dump is not usable because your drive has not yet enabled LibreDrive (LD). However, the latest KEYDB.cfg file already contains an entry for this disk, and so if MakeMKV still cannot decrypt it after you enable LD, you should just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
cheyu
Post by cheyu »
I downloaded the latest KEYDB and put it in the MakeMKV directory and I can see an entry for this movie, but I still get that the volume key is unknown. Does this just mean I have a different pressing of the disc or could it be something else?
MrPenguin
Post by MrPenguin »
cheyu wrote:
Wed Jan 14, 2026 10:10 pm
It depends - Did MakeMKV manage to enable LibreDrive for your drive? If your disk is a different variant then your TGZ dump file would have a 4-character code other than E66E in its name.
cheyu
Post by cheyu »
MrPenguin wrote:
Wed Jan 14, 2026 10:21 pm
0xD46056F20F1EEB4813AC4B4D02B7B4E890B8AA50 = ONE_BATTLE_AFTER_ANOTHER (One Battle After Another) | D | 2025-10-29 | M | 0x0876163613199FC54ABA449AE6861540 | I | 0xE599E65D0023AF451753B5B38497E922 | V | 0x4ECA5B337682502DDAFACAB9C9AE2BE5 | U | 1-0x57FECD4250FBC4D0FFE323C9DDA0D824 ; MKBv82/BEE/FindVUK 1.82 - VolumeSize: 98046574592 (UHD)
Yes, I have LibreDrive enabled and have ripped many discs. My dump file does have a different code and I emailed it to svq. How does the 4-character code relate to the entry in KeyDB? I don't know how to tell from the KeyDB entry whether it's the same disc as mine.
MrPenguin
Post by MrPenguin »
cheyu wrote:
Wed Jan 14, 2026 10:34 pm
A different code means a different disk variant, i.e. the SHA1 hash of your disk's AACS/Unit_Key_RO.inf file will be different to that of the E66E variant.
rhw86
Post by rhw86 »
Submitted dump for USA UHD Disc:
Users/mac/Library/MakeMKV/MKB20_v82_One_Battle_After_Another_6D10.tgz
rhw86
Post by rhw86 »
Any updates about this being accessable would be appreciated; I am not having any luck with public keyDB either.
keydb_helper
Post by keydb_helper »
rhw86 wrote:
Thu Jan 15, 2026 6:41 pm
If you'd like to see your disc added to the public keydb, you'll need to provide a disc dump. Check out the thread in my signature for info on submitting disc dumps for the keydb.
Public KeyDB Disc Submissions
rhw86
Post by rhw86 »
.tgz dump file can be downloaded here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-s1ii9U4X3V
rhw86
Post by rhw86 »
disc AACS folder and.tgz dump file here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-nqDyGwu17G
rhw86
Post by rhw86 »
works! thx
mirrorworld
Post by mirrorworld »
Dump summitted
MKB20_v82_One_Battle_After_Another_E66E.tgz
https://mega.nz/file/vSIC3biR#sSu8z7ejj ... q5ZMdr6iW4
yapmkv
Post by yapmkv »
Dump submitted
MKB20_v82_One_Battle_After_Another_B1EE.tgz
viewtopic.php?p=193451#p193451
lfoust
Post by lfoust »
A user submitted this title to thediscdb here: https://thediscdb.com/movie/one-battle- ... er-another
