One Battle After Another UHD Dump File
tricolorSystems
Re: One Battle After Another UHD Dump File
Your dump is not usable because your drive has not yet enabled LibreDrive (LD). However, the latest KEYDB.cfg file already contains an entry for this disk, and so if MakeMKV still cannot decrypt it after you enable LD, you should just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
I downloaded the latest KEYDB and put it in the MakeMKV directory and I can see an entry for this movie, but I still get that the volume key is unknown. Does this just mean I have a different pressing of the disc or could it be something else?
It depends - Did MakeMKV manage to enable LibreDrive for your drive? If your disk is a different variant then your TGZ dump file would have a 4-character code other than E66E in its name.
0xD46056F20F1EEB4813AC4B4D02B7B4E890B8AA50 = ONE_BATTLE_AFTER_ANOTHER (One Battle After Another) | D | 2025-10-29 | M | 0x0876163613199FC54ABA449AE6861540 | I | 0xE599E65D0023AF451753B5B38497E922 | V | 0x4ECA5B337682502DDAFACAB9C9AE2BE5 | U | 1-0x57FECD4250FBC4D0FFE323C9DDA0D824 ; MKBv82/BEE/FindVUK 1.82 - VolumeSize: 98046574592 (UHD)
A different code means a different disk variant, i.e. the SHA1 hash of your disk's AACS/Unit_Key_RO.inf file will be different to that of the E66E variant.
Submitted dump for USA UHD Disc:
Users/mac/Library/MakeMKV/MKB20_v82_One_Battle_After_Another_6D10.tgz
Any updates about this being accessable would be appreciated; I am not having any luck with public keyDB either.
keydb_helper
If you'd like to see your disc added to the public keydb, you'll need to provide a disc dump. Check out the thread in my signature for info on submitting disc dumps for the keydb.
Public KeyDB Disc Submissions
.tgz dump file can be downloaded here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-s1ii9U4X3V
disc AACS folder and.tgz dump file here for public keydb submission (im on a mac and its difficult to open .inf files):
https://we.tl/t-nqDyGwu17G
works! thx
mirrorworld
Dump summitted
MKB20_v82_One_Battle_After_Another_E66E.tgz
https://mega.nz/file/vSIC3biR#sSu8z7ejj ... q5ZMdr6iW4
A user submitted this title to thediscdb here: https://thediscdb.com/movie/one-battle- ... er-another
